Question about Proscan 19LA25Q 19 in. LCD Television
Model 19LA25Q Tv turn off by its self. Has red power indication but will not turn on by button or remote.
  • 2 more comments
  • Anonymous Apr 24, 2008
    My tv also will not turn on by remote or buttonon tv
  • fixpro May 18, 2008
    Yes...Just within the hour. Have noticed odd behavior, lateley i.e., flickering screen. I thought it was my cable provider. Tonight I have red indicator on but nothing. Only purchased not a year yet. It just appeared to have expired.
  • Anonymous May 24, 2008
    Red light is on, but when I press the power button, it flickers green for a moment then back to red. Holding the button makes the red light flicker.
  • redwlf1971 Jul 09, 2008
    flicker. unplugged tv for a few minutes then plugged back in. no change!
Unplug. Wait 15 seconds then plug back in.
No guarantees, but it might work.
Posted on Apr 06, 2008
Why does my flat screen tv turn on and off by it self and the only way to stop it is unplug power cord?
This is an indication that they capacitors in the power supply are going bad.
Jan 20, 2015 | Televison & Video
Have a mitsubishi model 73640 and the power light turns on makes some noise thens turns off by it self.
The red indicator merely shows power is getting to the set. Probably the power supply has failed.
Jul 17, 2014 | Televison & Video
Front panel locked by accident- no original remote, only universal, code unknown. tv has since been turned off by unplugging, now it won't turn on. remote has also been unprogrammed because batteries were...
Hello
Three digit universal remote code for RCA are:-
000/ 003/ 004/ 005/ 007/ 009/ 011/ 048/ 078/ 082/ 083/ 094/ 096/ 098/ 099/ 101/ 102/ 103/ 107/ 113/ 129/ 133/ 167/ 179/ 181/ 187/ 188/ 194
Four digit universal remote code for RCA are:-
0031 0004 0048 0054 0094 0100 0102 0107 0129 0191 0005 0009 0000 0162 0163 0342 0003 0015 0022 0096 0113 0125 0179 0187 0188
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Other ways to unlock RCA tvs
  1. Hold down MENU on the remote and VOLUME DOWN on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 on the remote and the VOLUME DOWN buttons on the TV its self at the same time for at least 4 seconds. The set won
Nov 22, 2010 | RCA 27R410T 27" TV
I bought my 19" Proscan LCD (19LA25Q) used from a
The Proscan 19LA25Q came with a remote originally. Unless the IR receiver has failed, it should work with a universal remote. (Note: if the TV is newer than the remote (or released less than 6 months before the remote was programmed), the remote codes for your TV may not be included.) Since the code lists on universal remotes do vary depending on the age and model, please give more information than just the brand. GE remotes usually have a version code label in the battery compartment. This version code is needed to look up the correct code lists. Some GE universal remote built by Jasco codes are here: https://byjasco.com/support/ge-universal-remote-codes.
The Proscan 19LA25Q was probably built in 2007, since there are reviews from 2007. That was also the year when this size TV had to have an ATSC tuner. So if your remotes were programmed before July 2007, they may not be compatible. Some of the current Proscan TVs probably use the same parts as some Sylvania, RCA and Curtis TVs.The 19LA25Q was warranted by On Corporation which has control of the RCA brand now. However, I don't know when they bought the label.
Amazon lists a few direct replacement remotes for the 19LA25Q. See https://www.amazon.com/Original-Proscan-Control-E20F-19LA25Q/dp/B00KQVDRNK and https://www.amazon.com/PROSCAN-Replacement-Remote-Control-19LA25Q/dp/B009H5QVIO . Remotes.com also has a replacement remote: http://www.remotes.com/SearchResults.asp?Search=19LA25Q .
I hope this helps.
Apr 21, 2017 | Proscan 19LA25Q 19 in. LCD Television
LED goes from red to green then back to red, when
led goes from red to green and back to red when turning tv on
Dec 27, 2009 | Proscan 19LA25Q 19 in. LCD Television
Green power light comes on for a split second, then red.
The power supply (AC adapter) is bad. It has enough power to light the red LED, but not enough to power the TV.http://shop.ebay.com/?_from=R40&_trksid=m38&_nkw=12+volt+5+amp+power+supply&_sacat=See-All-Categories
May 23, 2009 | Proscan 19LA25Q 19 in. LCD Television
Proscan 19la25q 19in lcd
Is there a red L-E-D power light beneath the screen? that is the power off light(red). Watch closely to see if that red light momentarily turns green and then immediately red again when you are attempting to turn the tv on, that indicates a bad power supply. There are replacement power supplies on ebay. Be sure that the positive (+) is the center hole of the plug. Most likely all of them are. The output plug is 5.5mm x 2.5mm in size.
Mar 08, 2009 | Proscan 19LA25Q 19 in. LCD Television
The Tv won't turn on at all.
Needs a new power pack...had the same problem
Feb 26, 2009 | Proscan 19LA25Q 19 in. LCD Television
No picture or sound. MODEL #19LA20Q
The faint light indicates that there is not enough power being provided to the other circuitry as well the humming sound is a good indication that the power supply needs ot be replaced or repair. If your TV is less then a year old, still under manufacturers warranty.
Let me know if you require further assistance.
Dec 03, 2008 | Proscan 19LA25Q 19 in. LCD Television
Universal remotes for proscan
remotes.com (1-800-remotes) has a remote for this tv. One for all remotes and radio shack remotes do not have a device code for this tv. Proscan is not made by GE, RCA, Thompson any more. They are marketed by oncorpus.com now.
Nov 02, 2008 | Proscan 19LA25Q 19 in. LCD Television
Proscan 19LA25Q 19 in. LCD Television Logo
93 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
