TX SR-702 Sound Problems
Our system works for Tuner as well as DVD. When we are in Video 1 I get picture but no sound. I have moved the cables in the back from Input 1 to Input 2 and 3 but I get no picture or sound when I move into those jacks.
  • 682 Answers
Please check your system with a new cables fist .and check that the input is assigned to your media(sound or video)
Posted on Apr 06, 2008
Problems with optical input. I am having intermittent problems with the optical sound input on my Onkyo. I am using a DVR with optical output for the source. Sometimes when I turn the DVR and Onkyo on I...
sometimes with cable, satellite, or any dvr, the digital signal actually is intermittent and there is little we can do about it but add an analog audio connection for each device as a backup. per se, and put the receiver in auto input mode. the receiver will utilize the analog signal to fill in where the digital signal fails
good luck
Dec 07, 2009 | Onkyo TX-DS747
Marantz SR-18 NO Sound No Data error for DSS (Directv) only
You need to check the connection of the lead that carries the audio from the DSS to the amp, move it to one of the other channels ie vcr and see if it can be heard when set to and switched to vcr. Then we know if we are dealing with the Amp or the source..
Dec 23, 2007 | Marantz SR-18EX Receiver
What kind of subwoofer cabel or wires do i need for the sr 702
Just plug the rca cable from the Onkyo into either of the 2 RCA's on the subwoofer. It'll be fine.
Geno
Aug 02, 2008 | Onkyo TX-SR702 Receiver
Loss of video signal from Onkyo TX SR 875
Go to hardware set up and turn off the hdmi audio output,sounds daft but it should work,also make sure the B speakers are not on as this puts the menu up the left.
hope this helps.
CABLE GUY.
Jun 30, 2008 | Onkyo TX-SR503 Receiver
Onkyo TX SR 702 AV Receiver
don't run you video from the projector to the reciever. just run it to the dvd and run the sound from the dvd through the reciever
Jun 01, 2008 | Onkyo TX-SR702 Receiver
Tuner Omits No Sound - Onkyo TX-SR605 7.1 Channels Receiver
Make sure your receiver is hooked up to proper AM and FM antennae. Try switching to AM, scan stations. If you hear AM static and/or weak signals the problem could be antennas are not hooked up. FM has AFT which blocks out weak or noisey stations and you wont hear anything without ant.
May 06, 2008 | Onkyo TX-SR605 Receiver
Sound no picture on cable
sweetkiss, if it works through the dvd player and not on cable/satellite box then the tuner is bad, if you have any type of cable/satellite box try running A/V cables out of the box to video input on the back of the tv and switch the tv to that video input, ie; vid 1, vid 2 etc. (your using one of those inputs for the dvd) this will give you your picture back, you can of course also replace the tuner in the set, good luck, BMW Rider
Feb 10, 2008 | Sony KV-27V22 TV
Onkyo tx sr 605
well most dvd aint 7.1 are using dolby digital cable in digital mode ect on sterio set output on ps3 audio setting to digital
Feb 03, 2008 | Onkyo TX-SR605 Receiver
Onkyo HT-SR750
Check out Onkyo's website: The HT-SR 800 description says "a separate audio connection is necessary" Maybe it is true for the --750 too.
Jan 01, 2008 | Onkyo TX-SR605 Receiver
Dell 32 LCD Flat Screen multiple problems
I have checked all the connections and replaced all the cables with the highest quality I could buy.  I think the problem is in the TV tuner itself.  I live in a MDU so I am stuck with a rooftop satellite/master antenna.
Oct 23, 2007 | Dell W1900 19 in. HD-Ready LCD Television
75 people viewed this question
 Grubhead
Grubhead
