Question about Sony PlayStation Portable (PSP) Console
Scrolling When my son turns on a game like Madden NFL, it will scroll through options without him touching the analog stick. It doesn't matter what game is in at the time. We don't think it's with the analog stick....please, any suggestions?
    Problem Solver:
  • 7 Answers
Use your warranty. If you don't have one take it back to the store and see what they say.
Posted on Apr 23, 2008
SOURCE:
How to get psp games
Try these steps : 1.
Check to see if you have the right firmware. Firmware is the proprietary operating system the PSP requires for functioning. You need Firmware 1.0 or 1.5 to download free games on a PSP. These versions allow you to play PSP homebrews; later versions have protections that avoid use of non-commercial PSP games.
To check your PSP's firmware, press the PSP's "Home" button. Scroll down and select "Settings." From there, select "System Information." The firmware information can be found in the section where it says "System Software." If this section has the number 1.0 or 1.50, you'll be able to play PSP homebrews. If the number is higher, you won't be able to download free games on a PSP.
2.
Format a PSP memory stick. The size of the memory stick doesn't matter since most PSP homebrews are relatively small. Insert the memory stick into the slot located on the left side of the PSP, where the directional buttons are. Pop open the cover and slide the memory stick in, making sure it's face up and follows the direction of the white arrow.
Press the "Home" button and go into the "Settings" section. Scroll down and select "Systems Settings." In the next screen, continue scrolling down until you can select "Format Memory Stick." The PSP will ask you if you want to format the memory stick. Answer "Yes," and the PSP will format the memory stick within just a few seconds.
3.
Download free PSP games onto your computer. Sites like PSP Brew, UR PSP and PSP-Homebrew.eu contain tons of free PSP games. And the downloading process is pretty much the same. You either select an option to download, or you right-click on the file and use "Save As" for downloading. Visit the sites to gain a better understanding; links are provided at the end of this article.
4.
Unzip the files. Usually, when you download free PSP games, you receive files in a compressed (or zipped), format. This allows a developer to send larger files without the hassle of breaking them up into pieces. However, before you can use these games, you will have to unzip them so you can have access to the individual files.
To unzip files, you need to use an unzipping utility. Windows comes with one, and it's relatively easy to use since you just select options from a Wizard. But if you prefer something more sophisticated, consider using WinZip, for the PC, or Stuffit, for Macs. Both of these programs can be downloaded free, though the legal version of WinZip only offers a 30-day trial. Either way, unzipping is as simple as selecting "Extract" and entering in the name of the file you want your games in.
5.
Connect your PSP to the computer via a USB cable. Make sure you place the smaller end of the USB cable into your PSP. Place the larger end into any of the USB ports available on your computer.
6.
Switch to USB mode. The PSP cannot communicate with your computer unless it is in USB mode. This is accomplished by pressing the "Home" button, scrolling towards "Settings" and then selecting "USB Connection."
7.
Transfer the games onto your PSP. This step is the heart of downloading free games onto your PSP, and it is simple. With your PSP connected to your computer, take whatever games you plan on downloading and place them into the PSP > GAME folder. If this folder doesn't appear automatically, you can create one by "right-clicking" in the PSP directory and then entering in the name "Game."
8.
Run the games you downloaded. After you have installed the desired games onto your PSP, disconnect the device from your computer. In the main menu, scroll to the "Game" section. Select the "Memory Stick" option. The PSP homebrews you downloaded will be contained here. Highlight one of them and press "X." Assuming the homebrew is coded properly and you have the right firmware, it should run just like a commercial PSP game.
In case of any problem please revert back
May 22, 2011 | Sony PlayStation Portable (PSP) Console
What is the installation code for Madden NFL 08 PC?
I don't think so, I believe the game is just getting old, this happens on old XBOX games, the disc may get wore out, or it might get to scratched, one thing you might wanna try is to, once you start the game, take out the disc, the game wont stop, and maybe it will run better without the extra process of scanning the disc, I honestly don't know if that will work, but it's worth a shot.
Sep 30, 2010 | EA Sports Madden NFL 08 for Windows
Brand new ps3 doesnt work - i get the menus and can go online, etc but when i insert game (madden 10 in this case) game is supposed to load automatically and it doesnt...
Does it work when you go to the "game" submenu and scroll down to the disc option? If this works then the autoload game setting is turned off in your settings menu
Sep 14, 2009 | Sony Playstation 3 (PS3) Console
PS3 SCROLLS DOWN AND WONT SCROLL UP!!
i have face the the same problem with my ps2 conttroler. In my case it was the problem with the analog (the sticks). May be the spring of your left analog is broken is broken. Do not try to open it yourself and fix, it can disturb the wiring of the remote. Take it to your local ps repair shop or you will have to buy a new one
May 30, 2009 | Sony Playstation 3 (PS3) Console
Psp scrolls down and left Help Plz
Your directional pad is sticking. you can buy a replacement cheaply on ebay
Jan 04, 2009 | Sony PlayStation Portable (PSP) Console
When you barely tap my analog it gets stuck.
as a sony certified technician, i can tell you that these types of problems are caused be what we call a "false Contact". When the psp's analog stick does not touch the motherboard component, the analog stick auto scrolls down. If it auto scolls up then is just dirt biuld up. But if it scrolls down, make sure the screws on the back of the psp are FULLY tightened so that way the analog sticks makes contact with the motherboard. I fix psp's for fun so if you have a question that need to be answered right away, please just call my cell phone Number (773) 351-2426 (USA, ILLINOIS NUMBER) hope that works
Dec 31, 2008 | Sony PlayStation Portable (PSP) Console
Sony PSP problems
the little analog control nub (the circle directional button) is touchy on some systems, make sure it is centered. hope it works for you.
rate plz
Sep 16, 2008 | Sony PlayStation Portable (PSP) Console
Need help!!!!!!!!!!!
A previously released Madden NFL 08 update for the PLAYSTATION 3 was causing an error code (80010009) to appear and prevent online game play.
There has been a fix published by Electronic Arts (EA) on this problem.
This has now been resolved, but if you already downloaded the update, you will need to remove it before the game will work.
Please follow the steps provided by Electronic Arts below.
If you have encountered an '80010009' error message after downloading the most recent Madden NFL 08 update, please perform the following steps listed below:
  1. Press the PS button on the controller and select QUIT.
  2. In the main screen of the XMBTM user interface, select Game.
  3. Highlight the Game Data Utility folder and press the X button.
  4. Highlight the Madden NFL 08 file and press the Triangle button.
  5. Delete the file.
  6. Restart the game.
This will allow you to launch and play Madden NFL 08.
Dec 13, 2007 | Sony PlayStation 2 (PS2) Console
Sony PlayStation Portable (PSP) Console Logo
65 people viewed this question
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
