Question about AOpen vKM400Am-S Motherboard
Bios version i have version R1.09 already for my motherboard but it still wont pick up the sempron. any other ideas? i have managed to overclock to 1.8ghz 147mhz bus speed but cant get the 166mhz it should be. many thanks bones
    President:
  • 2,351 Answers
Hi bones, you're sempron's revsion may not be compatable with you're board. I suggest you call AOpen's tech support.
For US Technical Support Line: 1-510-489-8928
For other AOpen numbers click the link & scroll down the page.
http://www.aopen.nl/about_ContactUs.aspx?Top=Y
Luck!
Mike
Posted on Apr 06, 2008
  • Mike Peluso
    Mike Peluso Apr 11, 2008
    Hi bones, you're missing the point here chief. The revision number of the CPU may not be supported by your board. AOpen does not list a supported CPU's list. Of course you're sempron 2800 is supported (as you're manual shows) but the revesions of you're sempron must not be supported other wise you're bios would report it at the correct speed.
    This is a common issue with newer CPU rev's & older boards.
    The only way to check this issue is for you to call AOpen. Please make sure you still have the box the sempron came in. The reversion number is on the box.
    Mike
SOURCE:
Cmos bios bad asus p5ld2-x/1333 i945gc. how i fix?
http://majorgeeks.com/ASUS_Update_Utility__d4435.html
ASUS Update Utility - an utility that allows you to save, manage and update the motherboard BIOS
The ASUS Update is an utility that allows you to save, manage and update the motherboard BIOS in Windows® environment.
The ASUS Update utility allows you to:
· Save the current BIOS file
· Download the latest BIOS file from the Internet
· Update the BIOS from an updated BIOS file
· Update the BIOS directly from the Internet, and
· View the BIOS version information.
You need an Asus motherboard in your system.
Rules for Safe BIOS update:
1. For safety reasons, always use the most updated BIOS utility!
2. Do not overclock the system/CPU during BIOS update!
3. Load "Setup Default" in BIOS menu before BIOS Update.
4. Make sure you have "Administator" privilege on your Windows system (WinNT4/2000/XP).
5. Close all application programs under Windows.
6. Disable any existing Anti-Virus applications in the system.
7. Reboot the PC after the BIOS update is complete.
8. Switch on the PC and load "Setup Default" in BIOS again.
Hope this helps
May 23, 2011 | ASUS P5LD2-X/1333 - motherboard - ATX -...
Im trying to decide what video card to get with this mother im a huge gamer and i play all games from CoD4 to wow. also does this board already come factory overclocked? how do i configure overclocking ?
motherboards do not come overclocked, unless you bought it from a person that has already done that. For overclocking, you go into the BIOS but make sure you have adequate cooling in your machine. When you overclock you want the CPU cooler fan to blow away from the CPU instead of onto it. Also you want more fans blowing out the rear of the case if you have one intake fan in the front, two in the rear/side panel. Overclocking causes more heat, and shortens CPU lifetime. I believe you press F2 at boot to get into BIOS on your motherboard. in the BIOS settings you can change the multiplier, but if it doesn't add up correctly, your computer will just hang instead of boot and try a different setting. Although this mobo supports Hyper-Threading and supports Untied Overclocking Technology, so it should be simpler to overclock rather than some mobos are tricky to get it going right.
As for the graphics card with this board: it's an Intel processor so you need a graphics card made by ATI. I would recommend a Radeon graphics card with this motherboard. The motherboard is compatible with Front Side Bus 1600/1333MHz CPUs, so make sure your Graphics card you select doesn't have a FSB faster than that, otherwise you will be wasting money.
Jan 02, 2010 | Intel ASRock Penryn1600SLI-110dB LGA 775...
Overclocking
Overclocking is set from the BIOS configuration. Not all BIOS allows overclocking, it may need a BIOS upgrade.
Check the ASUS WEB site for your model motherboard.
Overclocking the CPU (ie running at a higher clock speed) and increasing Frontside bus speed will give better performance BUT there is a downside too, if you overclock too high you could overheat the CPU and it could fail.
Sep 01, 2009 | ASUS P5GC-MX/1333 Motherboard
Possible overclock
Overclocking is now set on bios.
Just change the multipliers for desired speed, but be careful
Jun 22, 2009 | Computers & Internet
Overclocking locked on 945gct-m2 mobo
There is no overclocking settings for this motherboard, the CPU speeds and core settings are automatically determined. You may be able to find a modified bios somewhere, but i would strongly suggest this not be done. A bad bios, or bad flash can essentially turn the motherboard into an expensive paperweight.
May 30, 2009 | Intel Computers & Internet
BIOS problem!!
Why do you want to overclock it? Have you changed the cooling system? Overclocking might fry your processor if the cooling cannot keep up with the heat. Does your motherboard support overclocking? The option might be locked. There might be a jumper on the board that you have to mingle in order to enable that setting.
Sep 21, 2008 | Computers & Internet
Sandrew
There are different ways to overclock, however some methods might harm the CPU I am adding the link which shows the methods. here is the link
http://www.amdboard.com/ocspecial.html
Also please make sure your BIOS supports overclocking
Good Luck
Jun 19, 2008 | AMD Sempron 2800, 2.0 GHz 2800+...
Some Help Please...
You can try picking up a BIOS for a PC Chips M810DLU from the company's website here. You need to remember all the usual precautions when flashing.
Please do not expect much improvement or stability when overclocking a PCChip motherboard.
Good luck and kind regards.
Nov 04, 2007 | PC Chips M810DLU (M810DLUV75C) Motherboard
Overclocking failed
Hi, If you have overclocked: 1. CPU or motherboard not up to it - run at default speed; or 2. Memory - try using other memory; or 3. Video Card - see if you can run the Video card at default speed and not with overclock speed; or 4. You may need to up the CPU B+ a bit. If not overclocked: a. Set BIOS/CMOS to default settings; or b. Disable any overclocking feature (even if not used); or c. Lower you CAS latency. Hope this be of some help/idea. ood luck and kind regards.
Sep 01, 2007 | ASUS P5RD1-VM Motherboard
Open Questions:
-\&;-OPTONLINE Customer Care Phone Number #{+ I8OO-828-O294 } AB .U.S.A This Optonline USA phone number is ranked #2 out of 2 because 7,728 Optonline USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:828O294 is to reach the Optonline USA Customer Care department for problems like Where to buy, Complaint, Customer care, Repairs, Returns. As far as we can tell, Optonline USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. Optonline USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O30294 and ways to call or contact Optonline USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling Optonline USA Calling Optonline USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from Optonline USA Customer Care can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with Optonline USA's Customer Care department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare Optonline USA's phone numbers against each other. Contacting Optonline USA in General While I8OO8280294 is Optonline USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8280294 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact care for you to look at as well. One thing to keep in mind as you try to reach Optonline USA help by calling them, is that other customers give their customer care at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact Optonline USA.
Oct 16, 2019 | Best Computers & Internet
-\&;-COMCAST Customer Care Phone Number #{+ I8OO-828-O294 } AB .U.S.A This Comcast USA phone number is ranked #2 out of 2 because 7,728 Comcast USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:828O294 is to reach the Comcast USA Customer Care department for problems like Where to buy, Complaint, Customer care, Repairs, Returns. As far as we can tell, Comcast USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. Comcast USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O30294 and ways to call or contact Comcast USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling Comcast USA Calling Comcast USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from Comcast USA Customer Care can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with Comcast USA's Customer Care department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare Comcast USA's phone numbers against each other. Contacting Comcast USA in General While I8OO8280294 is Comcast USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8280294 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact care for you to look at as well. One thing to keep in mind as you try to reach Comcast USA help by calling them, is that other customers give their customer care at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact Comcast USA.
Amazon Best pHoNe NUmber #{+1-85O-8I2-4OO9 how to get refund from amazon prime Amazon Prime Refund Phone Number +1-85O-8I2-4OO9. While +1-85O-8I2-4OO9 is Amazon's best toll-free number, there are 7 total ways to get in touch with them. The next best way to talk to their customer support team, according to other Amazon customers, is by telling about your issue above and letting us find somebody to help you. Besides calling, the next favorite option for customers looking for help for Customer Service. If you think this information is inaccurate or know of other ways to contact Amazon please let us know so we can share with other customers. And you can click here if you want to compare all the contact information we've gathered for Amazon. AMAZON PRIME Tech Support Number +1-85O-8I2-4OO9 to resolve all AMAZON PRIME products. End Your Amazon Prime Membership You can end your Prime membership by clicking the End Membership button on this page. Paid members who haven't used their benefits are eligible for a full refund of the current membership period. [1``85O`-8I2`-4OO9``] UsA Amazon Prime Technical SuPpOrT Number +1-85O-8I2-4OO9 to resolve all Amazon Prime products. Amazon Prime is an American multinational company which was founded by Michael Amazon Prime using its company headquarters in Round Rock, United States of America.Contact Amazon Prime for Setup & Installation Amazon Prime Setup Support & Installation Amazon Prime Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere.
Oct 16, 2019 | Amazon Computers & Internet
See all AOpen vKM400Am-S Motherboard Questions
AOpen vKM400Am-S Motherboard Logo
81 people viewed this question
Top AOpen Computers & Internet Experts
Ekse
Gustavo Ortiz
Gustavo Ortiz
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
