Packard bell easynote L4
Charging jack is loose need to solder it, how do i open case?
  • froggychops Jul 27, 2008
    I have the same problem but am as about as technical as a cabbage. Any ideas where I could get this repaired at a reasonable cost?
  • 46 Answers
I found a PDF document that's a service manual for an Easynote H3. It takes you to the point of removing the motherboard. I know it's a different model, but maybe it's close enough. If you want me to email it to you, send me an email at [email protected]. It's a 1.3-MB file.
There are a lot of steps involved. I would recommend using a multicompartmented tray to hold the removed hardware. Be aware that some notebook ribbon cable sockets release the cable after you lift up on the outer shroud slightly.
If you do this job, look at the solder points first. If they look solderable, FIRST epoxy the power socket to the motherboard. When the epoxy has fully set, THEN resolder the joints. Use a low-wattage iron, not a gun.
I look at it this way: You can't make it work any less, and if you succeed, you'll be proud, and will have saved a lot of money.
Posted on Apr 11, 2008
SOURCE:
Do you need to manually turn wireless on on laptop?
Yes there is a switch for enabling and disabling wireless on laptops. For Packard Easynote L4 the wireless can be enabled by doing the following actions:
1.press the Fn key (which is in the bottom lefthand corner of the keypad) and press F1(function) key together (Fn + F1)
2. this should enable wireless on your computer.
May 21, 2012 | Packard Bell Computers & Internet
Packard bell easynote r1938 laptop powers on then turns off
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Sep 10, 2011 | Rain Recording LiveBook L4 Notebook
HI, Packard Bell Easynote L4, switches off after 5 seconds
no..this is a motherboard issue. if the power won't stay on, even without a battery, then it's the m/b..replacement is a bit dicey, but not impossible. The hard drive with data should be fine.
Nov 28, 2009 | Office Equipment & Supplies
Packard Bell easy not wont turn on
it is not charged or its battery has a loose connection
Jul 22, 2009 | Toshiba A15-S1292 Notebook
Packard Bell Easynote R1802 Switch Off When Battery is plugged in
The battery is probably faulty, try a different one. If it does the same thing with a different battery, then must be a short in behind the battery socket on the laptop. In that case better take it to service.
regards
Mar 05, 2008 | Computers & Internet
Packard Bell Easynote L4 Intermittent Power Problem
When ever i have run into these symptoms you discribe the power supply is on it's way out.
Oct 24, 2007 | Packard Bell Easy One Silver 2101 Notebook
Open Questions:
Computers & Internet Logo
706 people viewed this question
Ekse
Alun Cox
