My toshiba tv when it come on it says speakers are off I need to know how to turn them back on
Toshiba television has no sound
  • 8,617 Answers
Sounds like the audio output IC has failed. I would try to resolder first to see if that helps.
Posted on Apr 06, 2008
How do i connect hammacher wireless speakers to a toshiba smart tv
Model of both the TV and speakers, please. For example, without the model of the TV how is anyone supposed to know which inputs/outputs it has?
Edit: Dan, Thanks for providing the model numbers. I was hoping the solution would be something simple like switching the audio from internal to external speakers in the TV settings. However, when I looked at the owner's manual it appears that the rca jacks you tried on the back of the TV are inputs for old VCRs, DVD players etc. rather than an output which would be needed to send an audio signal to your speakers. In this case you will need to use the DIGITAL AUDIO OUT on the back on the TV. In order to use this you will need to purchase an Optical Digital Toslink Coaxial to Analog RCA converter. Make sure it uses a larger Toslink connector and not a mini one. The Toslink cable will plug into the DIGITAL AUDIO OUT on the back of your TV and then be plugged into the converter device. Your white and red RCA cables will go between the converter and your speaker transmitter unit. In addition the converter will have a power adapter that needs to be plugged into a wall outlet. There may need to be some audio settings changed in the TV menu to get this to function properly. It's best to buy from a retailer with a good return policy just in case it doesn't work.
Hope this helps.
Dec 15, 2016 | Toshiba Televison & Video
External sound to sound bar
Me too. Toshiba 32C11OU LED. PLEASE let me know if you solve this. The menu does not let me highlight the speaker choice (TV speakers is the default setting). Thnaks a million!
Jan 27, 2013 | Toshiba 50" 1080p 120Hz LED-LCD HDTV...
Toshiba 50A61 have sound but no picture
Make sure correctly hooked up in back of TV. Then in menu go to audio and be shure that speakers are set to ON. Most TV's you can turn the speakers on and off in the audio menu. If they are still off you might have bad speakers and need to replace them.
Mar 12, 2011 | Toshiba 50A61 50" Rear Projection...
I have a Toshiba 50HX70... I fixed the convergence issue around 6 months ago. Now the sound does not work... I turn it all the way up and you barely hear anything... I did move it recently, did I know...
Best best would be to try the following:
Start with taking the back cover off of the tv.
1) Verify if you can hear any sound whatsoever out of the speakers. If so, that would indicate that the speakers are still connected to the circuit board. If not, then trace the wires from the speakers to where they plug on to the board.
2) if you hear sound (hiss) in the speakers, but not the audio signal from your program you are watching, then look to ensure all connecters are fully seated around the RCA jacks in the back.
If those two do no produce results, then could be a solder joint on the board finally failed after moving the tv, or the amplifier for the speakers has failed. If you hear sound though as in step 1 above, i would doubt it is the amplifier IC.
Feb 20, 2011 | Toshiba 50HX70 50" Rear Projection...
We have Toshiba Regza 52XV645U. We have dish network hd channels and ever since hd channels were installed after tv plays for few hours the speakers get a funny sounds like channel sound is scrambling. It...
This sounds like what may be causing it is the cable going from the tv to the receiver box. If it is only happening on the sat channels, you know that it's not the tv. I would replace the cable, if that does not work, then it may be that the receiver needs to be replaced.
Becki Barned
DISH Network Customer Service
Dec 16, 2010 | Toshiba Regza 52XV645U LCD TV
Toshiba 57H83 and no longer get any sound. Any
Most often No Sound with Toshiba 57H83 is:
1. TV has a Sound on-off switch on the input panel at the rear of the TV. Very hard to see, black on black. Used to turn off speakers if you use a separate or external sound system for speakers. Usually gets moved while connecting hd cables or dusting and vacuuming in cramped space at the rear of the TV.
2. Someone accidentally changed Sound settings with remote to CC (closed caption) or SAP. Turn off in sound menu and save preference.
3. Sound input plugs from external cable or sat box unhooked or wrong input.
Toshiba 57H83 no sound fault is not common. If you still have no sound, get local service.
Or troubleshoot yourself to determine if Tuner, IF, processing, sound demod, switching or sound output circuit is smoked. Then make an installation plan.
Feb 28, 2010 | Toshiba 57H83 57" Rear Projection HDTV
Have a 32" Toshiba LCD TV with no sound
go into menu look for sound click inside speakers or try to use outside speakers. i fixed 3 or 4 witk same trouble... good luck & happy 4th
Jul 03, 2009 | Toshiba REGZA 32RV530U LCD TV
Speaker hookup on back of tv
I looked up the specs on your TV and Toshiba says that all of the A/V jacks on it are inputs. It doesn't list any outputs for external speakers other than the Coax digital output jack for surround sound systems. This would explain why you don't get any sound. The website where I got this information is as follows...
Sorry for the bad news.
Jan 02, 2009 | Toshiba MW24FP1 24 in. TV/VCR/DVD Combo
How to connect my Logitech X-540 speaker system to my dvd player or tv
On the logitech speakers, connect all the colored cables to their coordinating colors on the back of the subwoofer EXCEPT the green need the special Y connector that came with the speakers. (the red, white and green little one). Connect one end of the green cable to the subwoofer, connect the other end to the Y connector. Now you just need to correct the red and white cables from your tv or dvd player into those red and white cables and MWAH!!
Mar 01, 2008 | Logitech X-540 Computer Speakers
No sound on my toshiba television
just be basic....dvd is ouput goto tv the color yellow to yellow ,red to red etc, got tv ,look for audio output to anything input to home theatter etc.if u hook in to aux set home theater to aux etc, input to output and output to input ok? hope i help u..
May 08, 2007 | Toshiba CN32G90 TV
Televison & Video Logo
Top Televison & Video Experts
