CANON iP3000 PRINTER FAULT!
JUST CHANGED THE BLACK CARTRIDGE 3eBK - now the printer is making a juddering sound when it prints! also, it is not printing anything in BLACK!
It's printing in red only!
i've tried cleaning the heads/nozzle/re-aligning everything it tells me to do and more, but i'm still unable to get it to print in black!
i've even uninstalled the printer and re-installed it!
this is one big shout for help.
Posted on Apr 07, 2008
Mergatroid My Canon MP780 printer has stopped printing 3eBK. Do you have a repair shop in Canada? Can you provide the contact info?
It sounds like you just need to replace the black cartridge.
If I recall, I believe you can use a 3e or a 6e (longer lasting) BK (black) cartridge in this unit.
Mar 15, 2011 | Office Equipment & Supplies
After replacing black ink cartridge, black ink will not print
check the cartridge contacts in the printer \
a lot of time they geet covered in ink this will not allow the cartridge to print properly and cause headaches
clean with a baby wipe or a paper towel with soap on it
dry thuoly with hair dryer and try again
Aug 03, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Black ink 3eBk wont print
Ok what you need to do is make sure that the ink cartridge is properly inserted all the way. If it's not then you won't be able to print out black ink at all.
Jun 17, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Canon i860 printer is not printing from the 3eBK cartridge. I changed the cartridge and have deep cleaned the nozzles. any ideas
Are you using OEM cartridges or reloads? Sometimes the reloaded cartridges gum up the nozzles especially the black ink. If you have not tried an OEM black cartridge I woud try it.
Apr 28, 2009 | Canon Office Equipment & Supplies
Canon ip4000r doesn't print 3ebk (black)
First of all... have you tampered with the printer's firmware? If not, it's unlikely it became corrupted. But if replacing the ink cartridges with fresh ones, and using a new print head did not fix your problem, you may be out of luck.
Is this a new problem, or has it always been like this?
Could it be that the print driver is always printing photo? In that case, it uses the narrow black ink cartridge instead of the fat 3eBK cart. You should print a nozzle check pattern and verify that you see the 3eBK cartridge pattern. If you do, the problem is likely SOFTWARE... your driver settings, not the printer itself.
I hope this helps.
Dec 24, 2008 | Canon PIXMA iP4000R InkJet Printer
PIXMA MP780 printing trouble
If you haven't done so, I would try another new cartridge. It is entirely possible (and occurs frequently) that you got a bad cartridge. Assuming you removed the tape from the cartridge before putting it in, this is generally indicative of either a bad cartridge, bad print head, or that heads or ink tanks may need cleaning.
The Canon support page for this printer is at:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=10444
However, as Canon pages come up as generic pages (without the text I input for you), you will have to type in "missing black ink" (without quotes), to see the material they have posted in this regard. You will find instructions there in regard to how to clean the print heads, etc., if that is necessary. However, I would definitely try another cartridge first, especially if you haven't had that much use on the printer, such that you think these other measures may be necessary.
Please post back if you need further help, otherwise thanks for rating FixYa!
May 27, 2008 | Canon PIXMA MP780 All-In-One InkJet...
93 people viewed this question
jasbo
jasbo
