Question about Beko Dishwashers
Beko 5410w Dishwasher Salt Light Doesn't Go Off
The dishwasher is less than a year old and for some reason the Salt light will just not turn off, I have put in several kg of salt now in case it was just really really empty and also used the more expensive brand in case it didn't like the cheap bag I first used but still no joy.
Anyone got any clues or am I going to have to fight with Beko or Comet to come and fix it under its years warranty?
  • 641 Answers
SOURCE: dishwasher salt
Cooking salt contains ingredients that could damage your dishwasher. It could increase water hardness and they are likely to clog when wet. Suck out as much water as you can from the salt cup,enter there dishwasher salt and run your washer few empty cycles on the lowest temperature. Good luck
Posted on Aug 18, 2007
SOURCE: Salt indicator light comes on?
Check the instructions which are freely available from www.miele.co.uk or the relevant site for your country. Browse to the current models and you should find the PDF for your model. For non-current models, instructions are under the link "Customer Support".
In general, the instructions are as follows:
If the water in your area is very soft and constantly lower than 0.7 mmol/l (4 °d) you do not need to add dishwasher salt. The water softener must, however, still be programmed to correspond to the water hardness level in your area. (The salt indicator light will still come on, but should be ignored).
Important: Before filling the salt reservoir with dishwasher salt for the first time, you must fill it with approx. 2 litres of water to enable the salt to dissolve. Once the dishwasher has been used, there is always sufficient water in the reservoir.
Inadvertently filling the salt reservoir with powder or liquid dishwasher detergent always leads to serious damage to the water softener. Make sure you have picked up the correct packet of dishwasher salt before filling the salt reservoir!
Only use special coarse grained dishwasher salt for reactivation. Do not use other salts such as cooking salt, agricultural grade or gritting salt. These may contain insoluble additives which can impair the functioning of the water softener.
To refill:
* Remove the lower basket and unscrew the salt reservoir cap.
* Fill the reservoir with approx. 2 litres of water (first use).
* Place the funnel provided over the salt reservoir and carefully fill with salt until the reservoir is full. The salt reservoir holds approx. 2 kg of salt depending on the brand used.
As the salt reservoir is filled, displaced water will overflow.
* Clean any excess salt from around the reservoir opening and then screw the cap on again firmly.
* Run the "Pre-wash" programme immediately to remove any traces of salt water from the cabinet.
For the Miele, the salt reservoir is usually under the bottom basket, the cap is usually grey in colour. [Only the latest models have the refill cap in the door itself].
You should be able to find dishwasher salt just about anywhere, I've even found it in Malaysia, sold at good ol' Tesco!! Brands of salt include Calgonit (Finish) & Somat.
Posted on Jan 09, 2008
stephanos18
  • 144 Answers
SOURCE: dont know where to put the salt and how salt indicator goes off
it should have a dispenser in the bottom of the tub you just need to unscrew the lid
Posted on Mar 27, 2009
  • 12 Answers
SOURCE: Salt lasts only a very short time in dishwasher
is there any funny noises while using the machine that are new? if there is it may conclude that there is a leak in the machine and needs urgent assistance that may flood so act now! good luck!
Posted on Sep 30, 2009
SOURCE: 1.5 year old Maytag Legacy Series Quiet Series 300 Lock Light on
Hold down the heated-dry button for 3 seconds and the light will clear.
Posted on Dec 19, 2009
Dishwasher salt beko
Rinse aid and salt are not necessary if you use powder that is similar to the tablets. The lights are warning you that you havent added them, you know that so ignore the lights. If you live in a hard-water (limescale) area salt can be used as well as tablets or powder to make the water kinder to the machine, but most people just use tablets without rinse-aid or salt.
Dec 14, 2013 | Dishwashers
Hi, I have a BEKO GS5323 Dishwasher that has just
sounds like the sault filter has broken. it is in the base at the bottom its a thin plastic filter type. will need to be changed.
Sep 29, 2013 | Dishwashers
Salt light stays on
There is probubally an sensor in the machine that senses salt levels, it is not uncommon for and sensor to be faulty out of the box, I would contact the manufacturers on their 1-800 number nd consult with them and if be order the replacement part from them directly. Hope this helps
Sep 08, 2012 | Amana Dishwashers
Salt light stays on all the time -salt is full
The sensor that detects the salt level is faulty, it shouldn't affect the actual operation of the dishwasher though.
Mar 10, 2012 | Hotpoint Dishwashers
Smelly dishes
The problem is hard water. There is a new product out called the dishwasher filtration system. It filters the water before it enters your dishwasher. It works amazing and has a money back guarantee. You will love the way your dishes look after the first load. It is also very affordable (like 70 bucks). Go to www.dishwasherfilter.com to find out more info.
Aug 17, 2009 | Zanussi 18 in. DE4744 Free-standing...
go 2 the inside of dishwasher ull find settings from 1 to 6 simply turn back
Jun 29, 2009 | Beko 24 in. D3421F Free-standing...
Salt light displayed on machine? What do I do?
the machine is asking you to put dishwasher salt into the machine as its running low
Jun 16, 2009 | Beko Dishwashers
G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
Aug 11, 2008 | Miele 24 in. G665 Built-in Dishwasher
Salt in the dishwasher
Run a full wash without any salt in it and then try I think you may have over filled the salt tank.
Thanks J
Jan 13, 2008 | Beko 24 in. D3421F Free-standing...
Rins aid and salt light wont cone on
They are alerts that only come on when you DON'T have enough rinse or salt.
Aug 31, 2006 | Beko 24 in. D3731F Free-standing...
Dishwashers Logo
617 people viewed this question
Top Beko Dishwashers Experts
Eric Taylor
Paul Carew
Are you a Beko Dishwasher Expert? Answer questions, earn points and help others
