Question about NetGear WGR614 Router
Nat ports hi i need 3 ports open for my x-box live 1-UDP88 2-UDP-3074 3-TCP3074 can you help me? i have a netgear wireless WGR614 thanks c
    Sergeant:
    Champion:
  • 427 Answers
Go to the port range forwarding page on your router's setup.
It will ask you for the specific port. (88,3074) Enter them in in their own seperate sections. Then select either UDP of TCP for each. Then save the settings and you should be good to go.
Posted on Apr 11, 2008
SOURCE:
Needs nat type open
XBOX
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And Also Make sure that UPnP is Enabled
PS3
You will have to open the following ports in your modem /router
Make sure the firewall is disabled in the Modem /Router
Playstation Network Required Ports
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Playstation Online Game Ports
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
You can use http://whatsmyip.org/ports/ to test if the ports are open.
Regards
Tom
Jan 27, 2011 | NetGear WNDR3300 - RangeMax Dual Band...
Want to set nat type to open
XBOX
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
PS3
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
Jan 05, 2011 | NetGear DGN2000 Wireless Router
Can I change the Nat type? Can't figure out how to change it from type 3?
XBOX
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
PS3
TCP 80
TCP 443
TCP 5223
UDP 3478
UDP 3479
UDP 3658
Call of Duty 3:
UDP 3074
TCP 3074
MotorStorm
UDP 3659
UDP 3660
Jan 03, 2011 | NetGear WNDR3400 N600 Wireless Dual Band...
Cant get full online with ps3
PS3 and Xbox ( NON BELKIN)
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And also make sure that UPnP is Enabled
Jun 17, 2010 | NetGear WGR614 Wireless Router
How to set my xbox360s NAT to OPEN Witha netgear WGR614v7 Router?
Basically you have to open the application port of XBOX on your router. To do that you have to access the router's GUI and forward the ports. To access the router go to http://192.168.1.1 username is admin and password is password by default, click the port forwarding tab and open this ports
  • TCP 80
  • UDP 88
  • UDP 3074
  • TCP 3074
  • UDP 53
  • TCP 53
  • Click add customer service and type xbox for service name and the IP address of the xbox.
    Jun 30, 2009 | NetGear WGR614 54 Mbps Wireless Router -...
    How to change NAT type on sierra wireless 595u aircard?
    • TCP 80
    • UDP 88
    • UDP 3074
    • TCP 3074
    • UDP 53
    • TCP 53
    Feb 15, 2009 | Belkin N1 Vision Wireless-N Wireless...
    Belkin G plus mimo
    Hi never ever disable nat on your router as that is the one which gives ip address to computer , x-box etc. You can make your x-box live work by just opening some ports
    1. open rsp by typing in 192.168.2.1
    2. On the left hand side under firewall you"ll find virtual servers
    3. Click on that --- You"ll find some fields then check on enable for 1,2,3(ie three rows)
    4.Description - x-box for all three
    5.Inbound Port: 88-88 ,connection type : udp ,private port : 88-88 for the first row
    6. Inbound port : 3074-3074 , connection type : udp , private port : 3074-3074 for second row
    7. Inbound Port : 3074-3074 ,connection type : tcp , private port : 3074-3074
    8. As FOR the private ip address it is that of your x-box which you can find on the dash board of your x-box . Same for all three rows .
    9. Best of luck And do rate me
    Jan 31, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
    How do i set my Netgear Routers NAT type to open for playing xbox 360 games?
    I assume you know the ip adress of your xbox.
    First of all check on your router to see if UPNP is enabled.
    Then go to Portforwarding/Port triggering.
    Then add custom service
    service name: the name of how you call it. doesn't matter really
    service type is UDP
    start port 88
    end port 88
    server ip is the adress of your xbox
    then apply and make another custom service
    name it how you want
    service type tcp/udp
    start port 3074
    end port 3074
    server ip adress of you xbox
    this should work
    Jan 03, 2009 | NetGear WGR614 Wireless Router
    NAT set to strict
    upgrade your router to the latest firmware that can be found here:
    http://kbserver.netgear.com/products/WGR614.asp
    after upgrading the firmware, press the reset button for 30 seconds, then reconfigure the router. you will need to re-enable upnp if it is disabled, and open up ports UDP 88 UDP 3074 TCP 3074. i would also reserve the ip for the xbox and if all else fails set the xbox as the dmz host.
    hope this helps,
    trin
    Nov 16, 2007 | NetGear WGR614 Wireless Router
    Optimizing WGR614(v1) for xbox live
    the normal port that requires opening in your router for xbox is TCP3074, you should just type the number in as if there are no options, although there should be, it may know that 3074 is a TCP port.
    Sep 28, 2007 | NetGear WGR614 Wireless Router
    NetGear WGR614 Router Logo
    75 people viewed this question
    Top NetGear Computers & Internet Experts
    Prashant M
    Prashant M
    Ekse
    Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
