Question about Whirlpool Heating & Cooling
Whirlpool elect. heater / energysmart box.Heater model #ee3250rdo55v.Ser #0421104939 [50] gal.Box light indicatorwill not stop blinking,even after reset. Any problems like this ?
larryyb
  • 291 Answers
SOURCE: hot water heater overflow
check the pipes on top for leaks and if non then your water heater is leaking from inside and that cant be repaired / larryyb
Posted on Dec 11, 2008
gary1121
  • 332 Answers
SOURCE: I have a electric whirlpool 50 gal. energy saver
the thermostat should be replaced it only has one on the upper eloement, it has the dial on it to set the temp, but if it is only 3 months old it comes with a 1 year parts 6 year tank warranty, if you call whirlpool and tell them about this problem they will have there own teck or sub contractor that they use to come out and fix it for free,,, first go to there web site and put in your serial number and it will tell you how old the unit is, sometimes they sit for a while and are actually out of warranty before it is installed,, also did you install it your self?? if you did di you fill it with water all the way till the water came out of the hot side on your faucet full force before turning on the electric,, if not you have fried the whole unit, you will need to replace both elements and the thermostat, the elements must be completely submerged in water before they have the power turned on,,,
Posted on Jun 27, 2009
SOURCE: Clean LED is blinking, manual says check heater
Heater element shorted, a resistor on the control board is visibly fried which makes it inoperable. Estimate to replace both is at least $300. This is terrible design, should be a protection fuse on the control panel. Chances are this will happen again after the repair, design has not been modified. We invested our money in a replacement w/a one year warranty. Rather than 90 days for parts and service.
Posted on Nov 11, 2009
  • 17 Answers
SOURCE: Whirlpool Water Heater problem model FG1F4040S3NOV.
I will bet that it has to do with the gas. Probably not breathing right. First check to see if you have the right water heater; inside or outside. Call the manufacturer and have the model and serial number ready. If it is the right one, make sure that it is vented properly, both intake and exhaust. The intake is located on the bottom, probably covered by a plastic screen, make sure that it is clean. Won't hurt to vacuum the immediate area. If it is in a closed off space, it needs to have sufficient enough air to breathe. There needs to be a vent through the door or wall. If this does not solve the problem, have a qualified technician pull the burner out and clean it.
Posted on Mar 21, 2010
  • 1122 Answers
SOURCE: no heat whirlpool electric dryer imperial 70 1986 vintage
replace cut off switch fuse at the top of heater box
Posted on May 03, 2010
I have a whirlpool water heater model 333j50rd045v no green light on control box and no hot water do have 220 into the unit the unit is about 12 yrs old
You have energy-smart electric water heater?
Control box might be bad.
Copy following link for troubleshoot manual, and whirlpool phone number for replacement parts etc:
http://waterheatertimer.org/Whirlpool-Energy-Smart-electric.html
Gene
Aug 22, 2013 | Water Heaters
Water heater heats water and then cuts off. I replaced the lower element with a guaranteed for life element. It still heats up and cuts off. There is a control box on top that allows for an easy reset. ...
1) Bad thermostat or thermistor depending on model.
Whirlpool/Craftmaster/American energy smart has control box on top, and you can order parts from Whirlpool.
2) Copy following links to help identify product.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
3) Add a comment with more detailed information:
You have electric water heater.
Unknown brand, possibly energy-smart.
Unknown control box.
Cut off? Do you mean 'reset' is tripped?
4) Whirlpool energy smart requires 10 gauge wire and 30 amp breaker.
Control panel may not function with undersized electric supply.
Control panel has blinking-light errors ... if no error code then maybe the control box is bad.
Jan 18, 2013 | Water Heaters
My hot water heater will not light
Open following link to identify specific gas control anddownload possible service manuals for that specific product.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
May 19, 2012 | Water Heaters
Need a manual for a maytag electric water heater. model # HE2950S
More information is needed about this heater.
The label located on side of tank should show manufacturer.
Maytag does not manufacture water heaters.
Maytag is a brand name used to market water heaters made by other companies.
Maytag offers a phone number for water heaters:1-866-362-9898
Other resources:
-If the water heater has electronic control box on top, then following American Water Heater Company manual might be suitable:
http://www.americanwaterheater.com/support/manuals/energysmart.pdf
-Electric water heater instruction manuals can be found on following link:
Each is basically the same, unless there is electronic control box.
http://www.americanwaterheater.com/support/manuals.aspx
-If you have ordinary two-element 240volt water heater and are having problems, or want information on maintaining water heater, then following link is useful:
http://waterheatertimer.org/DIY.html
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html#cleanelectric
Sep 28, 2011 | RELIANCE ELECTRIC WATER HEATER
Energy saving devise light blinking and no hot water
Water heater is not identified.
Add a comment with information that appears on label on side of tank for possible help.
You might be talking about Whirlpool energy smart electric.
The error diagnostic lights flash a code: the code decipher is printed on the diagnostic control box on top of heater.
Call Whirlpool: you need model number and serial number from label located on side of tank.
1-877-817-6750
Open following links for energy-smart resources and typical manual:
http://waterheatertimer.org/pdf/Whirlpool-energy-smart-electric-manual.pdf
Aug 04, 2011 | Whirlpool Water Heaters
Our whirlpool Ee 3j50rd045v keeps releasing water from the discharge line.We have it set on energysmart and seems to discharge in the afternoon after it hasn't been used for a few hours. We have taken it...
This sounds like the Themal Relief valve is not working properly. Some of these valves have a lever that you can lift to PURGE the valve of debris. If there is too much debris in the valve it lodges in the valve seat and caused blow-by / leakage. In the evnt that your thermal relief valve does NOT have a purge lever and you can not get the valve to seat after going as far as remving it to clean it then it should be replaced. The relief valve is Item 8 of this link:
http://www.searspartsdirect.com/partsdirect/part-model/American-waterheaters-Parts/Water-heater-Parts/Model-EE3J50RD045V/3274/1081000/50028188/00001
Thanks for choosing FixYa,
Kelly
Feb 22, 2011 | Whirlpool Water Heaters
I have a Reliance water heater - 40 gal Model
In my first 15 years as a plumber I never saw a pilot light issue on a gas WH that a new thermocouple didn't fix. Since the government mandated a redesign of the fire box, I've seen three that nothing ever fixed - two Whirlpools and one (my usually ultrareliable) AO Smith - including replacing the entire burner assembly and the regulator. And I've heard of many others.
Check the thermocouple connection for tight. (Don't strip.. threaded soft metals.)
Check the microvents on the bottom ? of the burn box for dust, even if it is new.
Call Reliant and demand new units until you get one that works.
Try another model. Consider a 52gal electric.
I've always recommended gas over electric, and AO Smith and Rheem were my recommendations (and "Reliants" were "lumber yard" water heaters. Sorry.)
Since the mandated redesigns, I don't really have a "proven reliable" model to suggest. I increasingly believe the restricted air flow design is the ultimate culprit, including any changes to the thermocouple/regulator construct to accommodate the restricted air flow design. Just my hunch.
Offered for what its worth. -- plumber in Indiana.
Jan 10, 2011 | Reliance Natural Gas Water Heater Control
I have a Whirlpool 40 gal. electric water heater with a box on top that lights up and blinks to let you know of any problems. The other day it blinked that the upper element was defective, I installed a...
It sounds like the box is bad.
For second opinion:
Call Whirlpool number that shows in manual.
Person answering phone will want product number and serial number that is located on label on side of tank
Manual says:
1-877-817-6750
When calling for assistance, please have the following
information ready:
1. Model Number
2. 7 Digit Product Number
3. Serial Number
4. Date of Installation
5. Place of Purchase
Dec 27, 2010 | Whirlpool Water Heaters
Have 10 gal. gas and electricatwood Gas works. no elect. with switches on and lights on. has motor aid that works.Where is the element access?
ON THE BACK SIDE OF THE WATER HEATER IS A METAL BOX HELD ON WITH 2 NUTS. UNDER THERE YOU WILL FIND THE "BIG" NUT THAT THE ELEMENT IS AFFIXED TOO.
Dec 28, 2009 | RTO Atwood DSI-RV Water Heater-6 Gallon
Heating & Cooling Logo
78 people viewed this question
Top Whirlpool Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Tim Whalen
Are you a Whirlpool Heating and Cooling Expert? Answer questions, earn points and help others
