Question about Dryers
Dryer won't start
When I turn the start button, it just hums.
IT COULD HAVE LIFT BUILD UP ON THE MOTOR PREVENTING THE CONTACTS FROM CONNECTING.
Posted on Apr 08, 2008
SOURCE:
  • 221 Answers
SOURCE: when you press the start button the dryer hums and doesnt turn
check the fuse's and or breaker's to make sure on of them is not blown or tripped, check the belt to make sure it's not broken and check the tensioner, check to see if the drum spin's with little or no friction, if there are no blown or tripped fuse's and belt and tensionet are good the motor may be burned out.
Posted on Apr 18, 2009
  • 58 Answers
SOURCE: My dryer stopped working yesterday. When I press the button to start the dryer it hums, but it doesn't start turning. If I push the button 3-4 times in a row, it hums each time until about the 4th pre
Sounds like the motor is cutting out on its thermal fuse. The only cure is to change the motor.
Posted on May 05, 2009
Maytag317
  • 1136 Answers
SOURCE: Kenmore Series 80 Gas Dryer only Hums when start button pressed, but won't start
Hi, Does the dryer only hum when you push the start button?
Might be a bad motor.
Does the motor hum but, the drum doesn't turn?
Please let me know and get me a model # so I can assist you further.
Vic
Posted on Jun 01, 2009
  • 15 Answers
SOURCE: dryer wont start when start button is pressed, but humming sound
I'd sure start by making sure the belt isn't broken. You can usually see the belt with a flashlight after accessing the panel (some are in front, others in the rear) - don't go probing around bare armed without unplugging the unit....
Posted on Jul 20, 2009
  • 66 Answers
SOURCE: press the start button on dryer, it hums but wont
Sounds like a weak motor. You'll have to get a new motor installed. They are fairly inexpensive and easy to install yourself on that type of machine if you are handy. Motor is located in the bottom right of the machine, attached to the drum belt through a small pulley underneath the drum next to the motor.
Posted on Dec 27, 2009
Dryer won't tumble but gets hot
try holding the door switch with your finger and turning the drum with your hand after you push the start button , if this does not start it then you will have to replace the motor
Feb 24, 2013 | Dryers
Kenmore 90 series dryer..motor won't turn..hear the klicking sound..kind of hums...but won't turn. changed motor..same problem
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 11, 2011 | Dryers
My dryer won't turn on and it makes a humming
heatman101
Aug 11, 2011 | Kenmore 600 6965 Electric Dryer
When I push the button to turn on its making a a humming noise and won't turn on. Its less than 2 years old
heatman101
Aug 11, 2011 | Frigidaire Dryers
AEQ6000ESO frigidaire dryer won't start but when you push the start button it hums.
heatman101
Jul 19, 2011 | Dryers
I've got a 4 yr old Roper electric dryer that won't start up. The belt is fine and the drum spins freely. When you push the button to start it will hum but won't turn the drum. I've got...
heatman101
Jul 03, 2011 | Roper RGX4634KQ Gas Dryer
My whirlpool gas LGB6300PW0 dryer won't start. I press the start button and hear a humming noise, but no motor turning over. Please tell me that my 5 yr old dryer doesn't already need a new motor!...
heatman101
May 18, 2011 | Whirlpool LGV4634JQ Gas Dryer
Vic
Jun 01, 2009 | Dryers
Dryers Logo
Top Dryers Experts
Marvin
Marvin
paul
paul
