When i switched on my laptop on the display appeared checking disk c,but there 3 hours and it is still 7%
    Scholar:
  • 59 Answers
Shut it off either hold the power button a few second or remove the battery and power cord, power it back on and it it says anything about a problem with a disk and checking it  press any key to cancel then key a key or two see if it comes up also if you have any usb drive connected remove them they will occasionally cause this but normally the message will be checking a higher letter c is probably where windows is, if there is a serious issue that this needs to run then the computer will probably not start if you skip the disk checking, hopefully this helps, if not or if the problem is more serious than windows wasting your time then you may want to post any details you have, the version of windows, make of the laptop, specs if possible, anything that you have or have had changed, any previous problems you had, anything acting strange on the laptop, etc. there are lots of factors that can cause this including viruses and hardware failure. good luck.
Posted on Apr 06, 2008
Trying to restore to earlier point but even in safe mode wont let me
Try running the check disk utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Jun 02, 2012 | Computers & Internet
ASUS P5B blue death screen after rebooting windows 7.
May 27, 2012 | Computers & Internet
My lenovo s10-3 has turned a black screen after i go to system restore
Run the Check Disk Utility.
May 25, 2012 | Computers & Internet
I have a Toshiba laptop with a Windows 7 operating system AND A BLACK SCREEN WITH AN ARROW(curser) ON IT
May 21, 2012 | Toshiba Computers & Internet
Dell D510 still on dell display
Yes, you either have some corrupt or missing boot or system files. Run the Check Disk Utility.
May 02, 2012 | Dell Latitude D510 Notebook
Displays welcome!
Apr 27, 2012 | Computers & Internet
Hi I connected an "S" cable from my laptop to my
Thank You Mr. David,
For choosing my services.
I will try my level best to help you,
First start with very basic Troubleshooting steps
1. Switch off both devices.
2. Make connections S-Videos
3. Now switch on Laptop (As you mentioned its dell)
4. Now switch on TV or monitor.
5. Now hold (fn key) and simultaneously press f8 or f7) f8 for dell. (key which contains display icon on it).
6. Fn and f8 key helps in toggling displays in 3 modes-
7. Laptop display
8. Monitor /TV display
9. Both of displays
If you are Using Windows 7 then follow these settings after above troubleshooting steps
  1. Click "Start," access the "Control Panel" and then select "Appearance and Personalization." Find the option that says "Adjust Screen Resolution" and click once. A small window displays with two monitors labeled "1" and "2."
  2. Click on the "Identify" icon and a large "1" appears on one monitor while a large "2" appears on the other.
  3. Select the drop-down menu next to "Multiple Displays." Select the "Extend these displays" and click apply. The desktop is now extended. Adjust the "Resolution" and "Orientation" to complete the customization.
  4. Control Panel\All Control Panel Items\Display (You can choose magnification of your screen. (Medium-100 % recommended) check and set it to medium.
Now Let Me know the status and Exact problem You are facing right know.
Thank You Regards
Sunil Pratap Singh
Feb 05, 2012 | Dell Computers & Internet
How do I program a Micronta programmable timer--I set the time to have it go on, but how do I set it to go off?
LCD Programmable Timer (630-0892) Operation Faxback Doc. # 17153 Setting The Time and Day Follow these steps to set the current time and day. 1. Slide RUN/PROG/TIME SET to TIME SET. 2. Press HOUR to set the hour digits. Pressing and holding down HOUR rapid- ly advances the hour digits. NOTE: P appears to the left of the hour digits to indicate P.M. hours. 3. Press MIN (minute) to set the minutes digits. Pressing and holding down MIN rapidly advances the minute digits. 4. Press DAY until the correct day abbreviation appears. 5. Slide the RUN/PROG/TIME SET switch to RUN. The colon flashes to show the clock is running. NOTE: Keep this switch set to RUN to prevent accidentally changing the time. Setting The Timer The timer has 14 settings (1-14). Odd numbered settings specify a time to turn on the appliance and even numbered settings specify a time to turn off the appliance. Follow these steps to set your timer. 1. Slide the RUN/PROG/TIME SET switch to PROG. The display shows the first setting. If you have not entered any setting, the display appears as shown in the illustration. 2. Press Event to select a setting to enter or change. 3. Press Hour to set the HOUR digits and press MIN to set minute digits to the correct time. NOTE: Be sure P appears to the left of the hour digits when you want to set a P.M. hour. 4. Press Day to select the day of the week for this setting. If you want the setting to apply to every day of the week, repeatedly press DAY until all day indicators appear on the display. 5. When you finish entering the setting, press EVENT. The timer advances to the next setting. 6. Repeat Steps 3 through 5 to enter additional settings. NOTES: Be sure to set the timer to turn off the appliance. The appli- ance remains on as long as there is power if you do not set a time for the appliance to turn off. To replace an existing event, select its setting number and set the new event time. To clear an event, select its setting number and press CLEAR twice. Be sure to clear both the on time and the off time for an event. If you set the timer to turn on the appliance every day, be sure to also set the timer to turn off the appliance every day. 7. Set the RUN/PROG/TIME SET switch to RUN. NOTE: You must set this switch to RUN to turn on or off the appliance either automatically or manually. When the timer automatically turns on the appliance, ON appears on the display and the indicator lights red. When the appliance turns off, the indicator turns off. Reviewing The Settings To review the settings in your timer, set RUN/PROG/TIME SET to PROG. Setting 1 appears on the display. Repeatedly press EVENT to view the other settings. NOTE: To determine event being programmed, pull the power for a period of 5 minutes. Then re-power the unit. The first event will be "ON" and the next will be "OFF", etc. There will be a number to the side of the display that tells you which event you are programming, The even numbers are "OFF" and the odd numbers are "ON" events. (EB 3/17/97) (EB 7/16/97)
Privacy Policy
Sep 10, 2010 | Vacuums
I have acer aspire 5520. When I try to turn it on, I can hear disk drive spinning but then it turns off again, no image on the screen.
1. Check your power cord & adapter.
2. If its working then check the battery, reseat the battery & check.
3. If available then check with another battery
4. If no, then remove the battery & switch on the PC in AC mode.
5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
7. If still no display, connect an external monitor, check if display is comming.
8. If Display is coming then your LCD need to replace.
Aug 21, 2010 | Acer Aspire 5500 5570-2609 Laptop
When I turn on my laptop the on button lights up and the fan starts but absolutely nothing happens. The screen still appears off. The laptop has been working perfectly so not sure what might be wrong.
Aug 21, 2010 | Fujitsu AMILO PC Laptops
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
