Question about Whirlpool Dryers
My dryer Mod# WED6400 SB is displaying a code AF. What is the problem?
2 Suggested Answers
  • 958 Answers
SOURCE: Dryer is displaying AF
i got this from the other site.
The code AF indicates that the control senses a restricted air flow. To clear the code, press STOP once and the estimated time remaining countdown will return to the display. The AF code will continue to appear with each cycle until the low airflow condition is resolved.
Try the following troubleshooting to resolve the air flow problem:
  • Clean the lint screen.
  • Check at the outside of the home to make sure that the vent exhaust hood is not blocked.
  • Check the flexible vent connection behind your dryer. Make sure that it is not kinked or clogged.
  • You can disconnect the flexible vent and start a cycle with the dryer venting directly into your laundry room. If the AF code does not appear, this will verify an exhaust vent duct problem. Otherwise you may have a component failure.
  • Have your home dryer venting run cleaned professionally.
hope i was able to fix your problem,
tnx 4 using fixya,
drcool
Posted on Oct 04, 2008
SOURCE: the dryer display for the time is displaying "AF".
"AF" means there is an air flow problem within the venting system. There is either a restriction in the hose, outside vent cover, the front vent, or maybe the lower blower assist isn't rotating.
Posted on Nov 15, 2010
It will not dry it say the lettrs af
The airflow is restricted as indicated by the AF code. Check for clog lint filter and/or restricted vent system as lint build up in these areas cause airflow restriction and hence the AF code. Another possible reason is a faulty exhaust thermistor located on the blower housing. It is likely a thermistor fault if the lint filter including the vent system are all clear from lint built up but the AF code persists.
Disconnect power then remove the rear access panel and locate the thermistor on the blower housing. Disconnecting the thermistor and running the dryer will cause E1 to appear on the display to indicate an open circuit thermistor and E2 if the thermistor wires are connected together. Replace the thermistor if this is the case. Click on the links below for additional troubleshooting information.
Error Code E1
Error Code E2
Error Code AF
Jun 18, 2011 | Whirlpool Dryers
My kenmore elite mod. # 110.67062600 keeps flashing af
It is due to low air flow (AF),clean the vent tube out. The easiest thing to do is disconnect the vent and run the dryer, the AF will not be displayed, you can take the back top panel off an on the inside is a sheet with codes and how to take apart your dryer, as you have lint inside the dryer as well and should be cleaned out at least twice a year, varies on usage. Hope this helps Tim
Apr 07, 2011 | Kenmore 67032 Dryer
I have a whirlpool electric dryer (cabrio) every now and then it displays a code of AF what does that mean
I checked all the obvious things posted throughout the internet about this code on my 5 month old WED7800XL and none of them were the problem. What I found on my dryer was the belt that drives the fan had come off. After further inspection I also noticed that the pulley on the top of the fan was missing. After removing the front panel from the dryer I found the pulley, reinstalled it and the belt, the removed panels and it was fixed.
Also FYI, underneath the electronic panel there is a service manual for the dryer.
Dec 26, 2010 | Whirlpool Dryers
AF error will not go away after cleaning vent and lint filters
Thank you for contacting Fixya.com.
AF is an error that will flash if a restricted air flow is sensed by the dryer control. If three consecutive cycles have low airflow the control will flash the AF error.
The AF error code can be cleared by pressing the Drying Temp pad for 5 seconds while in stand-by mode. AF will flash in the display for 1 second then "on" will appear in the display. If you press Drying Temp again and "of" will appear in the display indicating the AF error display has been turned off. Try this procedure and see if the "of" error goes away. If the "of" came up in the display by itself then the keypad may be stuck. However After cleaning the dryer's lint screen, ensure that the exterior exhaust hood connected to the dryer is unblocked, ensure that the vent connecting the dryer to the wall is clear and see that the vent is cleaned professionally.
Please get back to us if you have any further query.
Nov 29, 2010 | Kenmore 67062 Dryer
The dryer display for the time is displaying "AF".
Nov 13, 2010 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Display is flashing AF what does that mean?
depends on dryer but problibly air flow prob, check house venting system
Apr 24, 2010 | Kenmore 67032 Dryer
I have a whirlpool cabrio dryer and it is showing AF on the display and it isn't drying. what could be the problem?
AF Error Code for the Whirlpool Cabrio Dryer is a Air Flow problem. Check your dryer vent and the outside exhast vent.
Jan 13, 2010 | Dryers
tnx 4 using fixya,
drcool
Oct 04, 2008 | Kenmore 67082 Electric Dryer
Dryers Logo
42 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Richard Roth
Richard Roth
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
