My Canon MX700 Series printer's on/off light is blinking, and I cannot get the printer to turn on- no matter how long I press the power button. Help me.
  • 1 more comment
  • Anonymous Apr 06, 2008
    My Canon MX700 is almost new.  When I turn it on I now get a blinking power light, a fairly loud repetitive popping noise and an error code 1500.  I have tried to shut the machine down and recycle but the power switch will not work; I have to pull the plug to shut it off.
  • Anonymous Dec 02, 2008
    I have the same problem. No power when I push the on/off button. I unplugged the power cord, put it in a known working socket and nothing. It just died. Help.
  • brian c
    brian c May 11, 2010
    Silly question... is it out of paper?
Canon mx 700 cant print. paper starts to go in and then jams. Something wrong with the reel
Posted on Oct 20, 2009
My canon mx700 has stopped printing in color
Check the color cartridge to ensure there is is still color ink inside it, remove the color cartridge, shake it and fix it back, now try print, if did not still print color, i will advice you reset your canon printer, Follow this steps to reset your canon printer.
1. Turn off printer.
2. retaining button Resume/Cancel press button POWER - indicator it will catch fire by green color.
3. let go button Resume/Cancel, continuing to retain POWER.
4. press button Resume/Cancel of 2 times, retaining POWER, after which let go all buttons.
5. when indicator will be lit BY GREEN - press button Resume/Cancel of 4 times.
6. turn off printer by button POWER. Power on later to see problem.
Jul 01, 2011 | Canon PIXMA MX700 All-In-One InkJet...
Canon s9000 blinking 7 times. Tried the on and resume button sequence without success. Rob
HI,
Please do a hard reset.Unplug all the cords of your printer for 20min. and then plug it back in.
Let me know the result.
I will be waiting for your reply.
Oct 06, 2008 | Canon Office Equipment & Supplies
Hi i have a problem here IP 1300 canon printer it says that i don't install cartridge properly but i try to reset it and still desame..the orange light still blinking and also the green light please help...
fallow this procedure it will help.
  1. Turn off Canon Pixma iP1300 Printers
  2. Hold down Resume button and press Power button.
  3. Keep holding down Power button and let Resume button go.
  4. Press Resume button 2 times then let BOTH buttons go.
  5. Green lights will flash and then stop blinking.
  6. When green lights are solid, press the Resume button 4 times.
  7. Press the Power button and the Canon Pixma iP1300 Printers should turn off, if not, press the Power button once more.
  8. Your Canon Pixma iP1300 Printers should respond as normal
Apr 20, 2011 | Canon PIXMA iP1300 Printer
It was showing error code 5200, I did the fix of removing the print head and when I re-installed it , now it is showing that print head is incorrect. It is the original one that came with the printer and...
1. The printer is turned off and plugged the power cord.
2. Press Resume button 2 seconds
then press the POWER button until the green light on (when pressing the POWER button, Resume button ... jgn released first)
3. Then release the RESUME button, but do not release the POWER button.
4. While the POWER button is still depressed, press the Resume button 5 times. Led will light turns green orange with the last glow orange. (do not be mistaken 4x because the printer will die completely, but it is temporary too) Then ...
5. Release both buttons simultaneously.
6. Led will blink briefly and then will glow GREEN.
7. And the computer will detect new hardware, just ignore ...
8. Press the POWER button, then the printer will die.
9. Press the POWER button again then the printer will flash
Mar 17, 2011 | Canon PIXMA MX700 All-In-One InkJet...
My MX700 printer tries to send faxes instead of printing page(s).
hi
change your default printer your mx700
1 - start menu
2 - printer and faxes
3 - right click on your printer
not on your fax icon
Jun 09, 2010 | Canon MX700 Office All-In-One InkJet...
Canon mx700 has a code 6502, what I have should?
code 6502 Please do the following:
1. With the printer unplug, remove the ink cart to the right ,
2. Plug in the printer
3 Press the POWER button and do not release the POWER button
4. Press the RESUME button twice in succession.
5. Now release the POWER button
6. Ppress the RESUME button 4 times.
The printer may beep. Unplugg the printer, reinstall ink and plug it back in. This should clear the issue.
All the best Pineworks
Apr 27, 2010 | Canon MX700 Office All-In-One InkJet...
I refilled my canon pixma ip3000 black ink cartridge and now the black will not print. Can you help?
Canon 3000 INK counter reset
1. Turn off printer
7. Press the Power button and the printer should turn off, if not,
8. Your printer should respond as normal..
Jan 14, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Would not print, oraqnge light blinks 5 times then one green flash. Open the door to ink and the head does not move to center as it used to.
This is a waste ink code and needs to be reset. follow instructions below.
Canon pixma iP90 released almost at the same time with canon Pixma iP 1880. Canon iP90 is printer with single function. Cartidges which used in canon Pixma iP90 is BCI-15BK, BCI-115C dan BCI-16C. Resetting procedure canon iP90 almost the same as manual reset canon iP1880. You can use combination of button in the printer to reset the printer.
Following step by step resetting canon Pixma iP90 :
  • Before resetting printer canon iP90, start with printer power off .
  • Press resume button coincide with power button.
  • While pressing power button, release resume button.
  • Press resume button 2 times and then release both button
  • Green LED indocator will blinking and then stopped blinking.
  • When the Power LED lights in green, press resume button 4 times.
  • Press power button and the printer power will off. otherwise off, depress again power button.
  • And the turn on the printer again, your printer canon iP90 should be response as normal.
Please rate my help++++Thanks for using FIXYA
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad); google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
Nov 24, 2009 | Canon PIXMA iP90 Mobile Printer
Can not clear memory on PIXMA Canon MX700
dear david
try this
) With the machine power turned off, while pressing the Stop/Reset button, press and hold the ON/OFF button. (DO NOT release
the buttons). The Power LED lights in green to indicate that a function is selectable.
2) While holding the ON/OFF button, release the Stop/Reset button. (DO NOT release the ON/OFF button.)
3) While holding the ON/OFF button, press the Stop/Reset button 2 times, and then release both the ON/OFF and Stop/Reset buttons.
(Each time the Stop/Reset button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green,
starting with Alarm LED.)
4) When the Power LED lights in green (and "Service Mode Idle" is displayed on the LCD), press the Stop/Reset button 4 times.
5) Press ON/OFF, press Stop/Reset 2 times
6) Press ON/OFF. Unplug printer and plug back in. turn on and should be cleared
oke , post me back
cropp
Mar 31, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Canon i560 printer
I have similar problem. I found this solution that may help you. My problem insists tho.
>>> 5 flashes indicates a faulty printhead or possibly a problem with the p/head contacts. Try removing the head which is easier if you take the cartridges out first(no tools required) and re-seat it having checked the contacts for dirt.
If that doesn't work it may be that the waste ink tank is full. Try this ...
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
May 28, 2008 | Canon BubbleJet i560 InkJet Printer
336 people viewed this question
jasbo
jasbo
