Hi guys,I have a linksys router hooked up and my desktop connection is fine. My laptop however, tells me my connectivity is limited, despite an excellent signal
  • brian c
    brian c May 11, 2010
    Please specify your internet connection type, as well as the router model number (wrtg4g, etc). The router settings will be different depending on your connection
  • 59 Answers
Go to your desktop and login to the router, the manual should have the default ip and username/password, or google that info, once your in check the number of dhcp leases and make sure it is set to about 2 more than the number of PC's you have, I have a problem with mine like this because i always forget to count for the devices on my network that arent actually PC's and of course the nintendo wii takes an ip as well, then go to the wireless settings, make sure wireless is enabled the channel is set to 6 or higher to reduce interference, 11 is usually the best choice. then head to the wireless security tab, make sure it is all off for now, if your router has SES do not press the cisco logo button on the front of it I recommend not using the SES(its easy setup for wireless security). once this is done grab the laptop, i would recommend bringing to near the desktop and router all in one room if possible, now the operating system on the laptop becomes important, hopefully you have xp and not vista, for many reasons,  first you want to try refreshing your ip. you will need to go to the start menu then to control panel, then switch to classic view, this will make finding things a lot easier, then look for network connections. inside the network connections control panel you should see some items like local area connection and local area connection 2, one of those is your wireless card, generally it will be number 2 but that is not always the case. right click on it and then from the context menu select repair, it may take a minute but then it may be working afterward, if not then try opening  the wireless card connection (double click) then click on the properties button then in the new window double click tcp/ip settings another new windows should appear, it should have radio buttons marked that say obtain ip address automatically and another that says obtain dns auto.... this would normally be just fine try changing to a static address, the use the following address option, now you need to come up with an ip yourself, here how that works... find the default ip of the router, it is the default gateway to the pc, it will probably be something like so you want to keep that address scheme( you absolutely have to, an IP address is like a mailing address, if its not right then you'll never get any communications through) so your  laptops IP should be something like note in this case that the 192.168.1. part must stay in this ip( its a class c) the last section can be anything other than the router, which will either be .1 or .254 unless you changed it or the default is something else which it usually isnt. the subnet mask should end up try using tab to skip it and windows may just set it for you, the default gateway is the routers address, for dns it can be left blank or add the router ip as the preferred, then click ok on the last two windows and close on the status windows, try the connection again, if the problem continues go back to the network connection control panel and do another repair and try again, if it still doesn't work try setting the radio buttons back to automatically get an ip and automatically discover dns server, then go to the start menu and then run and type cmd, a command prompt will open, type ipconfig /release then hit enter and when that finishes type ipconfig /renew then hit enter and it should attempt to get an ip, should be working after all that, sorry it seems so long and complicated after you set a few of these up it becomes almost second nature. it looks and sounds harder than it really is, just read everything carefully and take your time, don't mean to sound condescending or anything but a lot of people who say they aren't any good with computers is usually because they are impatient and expect the machine to know what they want it to do without reading what it displays or even trying to understand what the computer is doing. good job on buying linksys though, its about the best brand for home networking equipment. also to make refreshing your ip easier you can make a bat file containing the following text:
@echo off ipconfig pause ipconfig /release ipconfig /renew ipconfig pause
hope this helps , good luck
Posted on Apr 06, 2008
Computers have limited connection to linksys wrt54g although signal is full strength
Limited connectivity
If you get a 'Limited connectivity" on you wireless connection on your laptop, it means that the wireless card on your laptop probably did not get an IP address from the wireless router.
To fix this problem, right click on the wireless icon on the Task bar and then click Repair.
This will force the wireless router to issue a IP address to the wireless card on the laptop.
Also try resetting the wireless router by turning off the power to the wireless router for a few minutes and the boot up your computers.
Oct 28, 2012 | Linksys Wireless-G WRT54G Router
Im trying to hook my desktop up to the wireless router so that me and my dad (both with laptops) will hook up wirelessly. I tried reseting Linksys Broadband Wireless G Router and made sure all of the...
Try: Clarify - the desktop is connected with an ether net cable? Is working? Install router software on desktop to manage router. Trying to connect desktop wirelessly? Wireless card installed? Radio activated? Network detected?
Dec 31, 2010 | Linksys BEFW11S4 Wireless-B Broadband...
I have a linksys wireless g router that worked fine until yesterday. Now it won't connect to the internet. I have a desktop wired to the router and a laptop used wireless.
Check if you can connect to the internet when hooked directly to the modem. If your connection works fine through the modem, then your router needs to be reconfigured.
May 13, 2010 | Linksys Wireless-G WRT54G Router
LInksys WRK54g-wireless connection works fine, but cannot get LAN
You might have faulty LAN ports on your router or your network cable is bad.
Jan 23, 2010 | Linksys Wireless-G Broadband Router
I have a linksys WRT54g router set up to a desktop. I have 3 laptops on wireless - 2 laptops connect to the network just fine - but the 3rd laptop connects with limited connectivity. What can I do to get...
double check that your router is not broadcasting in only G, make it reverse compatible. There is a chance that the other laptop may not be G compatible. Also check the security key and make sure it is correct. If your blocking connections by MAC address make sure the MAC of the non functioning computer is added. You may want to delete the current connection settings from the laptop and restart with a fresh wireless connection. I hope this helps. Good luck
Sep 25, 2009 | Linksys Wireless-G WRT54GS Router...
I have Time Warner Cable for internet and Vontage cable for my phone thru my internet. I'm trying to connect a Linksys router for my wireless laptop. I also have a Netgear switch connected to Time Warner...
If you purchased a Linksys wireless roter then you shoul not need the switch anymore-
Try going directly from your time warner modem into the Interner/WAN port on the router and then plug your desktop computer and the vontage phone system into 2 of the ports on the router. After everything is hooked up you will probably need to power cycle for it all to work correctly.
Please power cycle in this order:
Reboot modem - then Router- then Vontage phone system.
Hope this helps
Apr 09, 2009 | Linksys -Cisco Wireless-G VPN Broadband...
Link Sys wireless G router, connects with laptop, not desktop
first unhook router and hook up pc directly yo modem and type in and goto config tab and see is modem is ppoe or bridge to ethernet needs to be ppoe second go back into setup on router and do a manually config and tell you have a dynamic dns and finish setup process i had the same problem with att internet and att had me setting it up wrong
Feb 16, 2009 | Linksys Wireless-G WRT54GS Router...
Hi Ive connected my linksys wrt 54g working fine on main puter but can't connect on my laptop .It's showing strong reception but then says cannot connect,Thanks,Guy
Check in the router settings, in your internet browser from your deskyop, type and enter the router config screen by using a blank username, and admin for a password. Look through the settings and make sure it is set to wireless signal on. Also, look to make sure your laptop isn't made specifically for Wireless N technology. Some wireless adapters aren't backwards compatable.
Mar 14, 2008 | Computers & Internet
Cannot connect a second pc
Are you connecting the machine that doesnt work wired or wireless??
Do you know what wireless card you have if it is wireless?
Dec 26, 2007 | Linksys Wireless-G WRT54GS Router...
Computers & Internet Logo
109 people viewed this question
David Payne
David Payne
