Treadmill problems. I have a fairley new treadmill (it's a rebok) that has stopped working. when i plug it in, turn it on, and press start, the motor that spins the tread will spin almost once around and then stop. If I press start again it wont even spin once again-I have to cut power then press start again, it will then spin one more revolution. I took the motor apart. It is fine. I tried the motor w/o the belt- no difference. There is also no binding noise or smoking. there is however a red light on a circuit board that flashes weakley when i hit the start? I also cant get the treadmill to incline or decline, and that has nothing to do with the motor. what do u think? Fuse, loose connection? where should i begin?
  • adamwes Apr 06, 2008
    no habla espanol
En la pantalla no aparece la iagen y si le esta llegando el voltaje por ke no se ve??
Posted on Apr 06, 2008
When I turn on says stuck button
reset the treadmill, follow this step and fix it. Merry Christmas
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Dec 17, 2013 | Exercise & Fitness
Can not calibrate a true 850 ztx treadmill. has error code E5:sensor. aborts calibration saying no speed sensor. is the speed sensor located within the main motor? What lights should be seen on the...
However reset the treadmill
    • 1
    • 3
    • 4
    • 2
Oct 24, 2013 | True 850 ZTX-P Treadmill - Serviced
When turn it on just beeping noise
reset the treadmill. follow this steps and fix it. God bless you
1.
    • 1
    • 3
    • 4
    • 2
Oct 23, 2013 | Reebok Exercise & Fitness
After attaching key all lighs come on but none of the buttons work except foe pulse feature. also belt won't move.
rests the treadmills, follow this steps and fix it. God bless you
replace old batteries ( if your system has batteries, clean the contacts batteries from oxide, dirty, etc) put a new one. Tight the ribbon cable inside the display board+tight the upper and lower connector too.
    • 1
    • 3
    • 4
    • 2
Oct 18, 2013 | Nordic Track C2255 Console (treadmill)
Treadmill displaying temperature over for an mbh fitness.what are the possible causes?
The cause of this problem is because your powerboad need big power (Amp) to turn the motor (and the belt) This usually happens if your treadmill belt is not lubricate well or needs change. So, first try to lubricate your treadmill belt with silicone oil and be sure that treadmill deck is clean. If the problem continues you must change your treadmill belt.
Greetings from Greece
Oct 18, 2013 | Horizon Fitness Exercise & Fitness
Rebok i run RE14301, plain blue screen. It was working until my son played with all of the buttons! We have tried turning it on and off and pressing the reset button but this does not seem to have worked
Instructions 1.
    • 1
    • 3
    • 4
    • 2
Oct 15, 2013 | Exercise & Fitness
Norditrack a2550 model stopped working while I was on it. The control panel will beep then light up like a Christmas tree but just goes into a nonperforming demo mode. Treadmill wont work! Help
1.
    • 1
    • 3
    • 4
    • 2
Oct 06, 2013 | Nordic Track NordicTrack Treadmill, A2550
My proform treadmill turns on and the inlcline works however the belt does not move. Any suggestions?
Enter calibration mode and do a calibration first.
Press the stop & speed up key, insert the safety key/magnet. Press stop 1 more time. Press speed up, the speed display should start to increase in value. By 30-40, the motor should be running. If not, you either need a motor or motor controller PCB. What model is the treadmill?? PCTL???
Dec 14, 2010 | Proform Exercise & Fitness
Everything works. but the treadmill motor won't start when I press the on button.
If you press start and the belt will not turn, but your incline is working, the time is counting and the speed #'s change. The problem would most likely be the lower control board. It could also be your motor. Have a professional test the motor with a DC voltage source. If it tests OK the problem is almost certainly the control board. Depending on the brand, some control boards have a fuse. Have the fuse checked and if it is bad replace it and try starting the treadmill again before you buy a new control board.
Nov 23, 2010 | Proform CrossTrainer Treadmill
Stops running
LED Blink Patterns on the Control Board Treadmill Treadmill Maintenance How To Lubricate Treadmill Belt
Try to do this steps in order to fix it.
However if the problem persist.
Time to replace the Controller board Motor.
This board has 3 power supply control:1) Console Board 2) Elevation Motor 3) Main Motor.
One of IGTBs is faulty.
Blessing.
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
Oct 01, 2017 | Proform iLog 750 Treadmill
Televison & Video Logo
128 people viewed this question
Top Televison & Video Experts
