Question about LG enV VX9900 Cellular Phone
Battery is required
This morning I was using my phone, put it in my pocket and the next time I took it out to use it, it won't turn on. When I put it on the charger, it says "Battery is required" My enV isn't very old and so the battery shouldn't have died already.
Help!
  • Javannah_m2 Mar 28, 2009
    My Phone was workin yesterday morning. then i put it in my pocket i got it out to text my friend but it would not turn on. So i put it on charge and it said Battery Is Required.
    New Friend:
Its in ******* possible to fix!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Posted on Nov 02, 2009
I already fixed my problem. I'm not sure how...? I just took the battery out a few times and wiped it off with a clean, dry cloth and eventually it started working. Thanks though.
Posted on Apr 07, 2008
SOURCE:
My droid incredible2 won`t turn on. how do i reboot it
Charge the phone for 10 minutes.
Press down the volume up button and hold it and then press the power button for a few seconds . The device will restart.
Dec 16, 2017 | Cell Phones
My phone, the Droid X, keeps randomly turning itself off and also turns off during phone conversations. If I have my alarm set to wake me in the morning if I get a text during the night and I'm not awake...
I have a droid x and keeps turning off and on randomly, I took it to Verizon and they factory reset the phone and reset the battery but it didnt fix it! so I end up getting a new one on the mail!(warranty) but the new replacement does the samething! took it to verizon store and they did the samething, except that this time, they gave me a new battery! but stil does the samething! can someone help me with this?
Jan 07, 2011 | Cell Phones
Katana II
if you are using a new katana you can either memorize or write down teh button sequence to navigate to the bluetooth settings that need to be changed for the data transfer to occur. thats what i had to do with mine after i ran it over with a snow plow. phone still works just no display... and its in two pieces. it took about an hour to get it all right, but it should work.
Aug 24, 2009 | Sanyo Katana SCP-6600 Cellular Phone
I have the same exact problem.
on the Blackberry if you have a problem with it malfunctioning, just remove the battery and put it back in after a few seconds and the phone will reboot. This is how you reset most smartphones.
Jul 15, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
My phone randomly shut off and now will not turn back on...
Well, I'm guessing there's a circuit board problem. One of the Capacitors, or other wires got loose, and now it won't turn on. Don't try to turn it on anymore. You could send electricity through the wire and fry the circuit board (when this happens there will be a certain distinctive smell- the smell of hot solder- this means he phone's life gone. Now, I recommend you take it to the store and tell them to check the wires in the phone to make sure it isn't loose. If there is a loose wire, they'll fix it. Hope this Helped- snowsurfer58
Sep 23, 2008 | Motorola Mobility Q9m Smartphone
Time changing on phone
yes it is an internal issue with the phone you can take it back to the carrier and have them exchange it for you or have them reflash the phones' firmware on the phone.
Jan 24, 2008 | Motorola Mobility RAZR V3
PHONE WONT TURN ON, HELP!!!
Hi, did you try taking out the battery and letting it discharge overnight then pop the battery back in, plug the pda into the power mains and try to turn it on again?
Nov 28, 2007 | HP iPAQ hw6515 Pocket PC
LG enV VX9900 Cellular Phone Logo
1,612 people viewed this question
Top LG Cell Phones Experts
William Norris
William Norris
George Etukudo
George Etukudo
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
