Question about Frigidaire 24 in. FDB510LC Free-standing Dishwasher
Dishwasher won't run
No power to dishwaser, won't start. I checked fusebox, not the problem. I want to know if there is a fuse somewhere in the dishwasher, I looked and could not see anything, also manual is no help. model #FDB510LCB0 Asko, Dishwasher Model # D1776. No power and won't run. Circuit Breaker is fine. Is there a cut-off switch or reset in the unit??
Ron L.
    Genius:
  • 1,142 Answers
I can help you in getting the resolution, please give me some more details
Posted on Apr 06, 2008
  • Maanita Chadha
    Maanita Chadha Apr 06, 2008
    Please check the basic wirinig or you can use an extension wire which can power up the dishwasher on a different wall socket.
I need a diagram for a 2001 VW Cabrio relay. I thought number 6 was for the blinkers/hazards but it's not and its empty. 413 is in there and blinkers and hazards just stopped one day. I don't know if I...
A2Resource
a great vw resource site
Relays:
Num.Relay Arrangement and Pinout (with control number stamped on relay)
1A/C Relay (13 or 140)
1A/C Switch
2Radiator Cooling Fan
3Fan Switch High Speed
4Battery, Fuse 23
5A/C Clutch (via pressure and temperature switches)
6Main Fusebox Battery Power, Fuse 19
7Main Fusebox Ground
8Fresh Air Fan
2Rear Wiper Relay (72)
1Main Fusebox Ground
2Main Fusebox Run Power, Fuse 4
3Rear Wiper Motor
4Wipe/Wash Signal from Switch
3Digifant Control Unit (30 or 32), Motronic OBD1 Control Unit (109)
2Tachometer
3Main Fusebox Start/Run Power
4Main Fusebox Battery Power
5To ECU (relay ) (1990 G60, ABA/VR6 OBD1 only)
6To ECU and Engine Electronics
4Load Reduction Relay (18)
1From Ignition Switch Run Power
2To Main Fuse Box Run Power
3Main Fusebox Battery Power
4Main Fusebox Ground
5Low Coolant Level Control Unit (43)
1Main Fusebox Start/Run Power
2Low Coolant Level Sensor
3Coolant Temperature Sensor, Gauge
6Flashers (21)
2Flasher Output
3Flasher Input/Power
4X/6 (Trailer Light)
7Headlight Washer (33)
1Main Fusebox Ground (B/4 to C/3 to Ground)
2Headlight Washer Pump
3Headlight Switch Pin 56 (headlights) (B3 to D4 to light power)
4Main Fusebox Battery Power (B/5 to Y/2)
5Windshield Washer Pump (B/1 to B/2 to washer pump power)
8Wash/Wipe/Intermittent Relay (19 for standard relay, 99 for variable intermittent module)
2Intermittent Switch
3Main Fusebox Run Power, Fuse 5
4Park/Low Signal (ground when parked, positive when on low speed)
5Wiper Motor Low Speed Output
6Wash Switch (positive for front wash)
9Seat Belt Warning Control Unit (4 or 29)
2Seat Belt Switch
3Door Switch
4Seatbelt Light
5"Key In" Power from Ignition Switch
6Main Fusebox Start/Run Power
7Automatic Shoulder Belt Controller
9Radio/Lights Buzzer (36)
1Main Fusebox Ground (not used)
2A1/4 (Left Parking Lights)
3Vehicle Speed Sensor
4Seatbelt Light (not used)
6Main Fusebox Start/Run Power (not used)
7A2/2 (Right Parking Lights)
10Fog Light Relay (110 for fog lights with low beam headlights only, 53 for parking light/high beam fog lights)
1Parking Light Power
2Headlight Switch Headlight Power (Low/High)
3Fog Light Switch Power, Fuse 10
5Main Fusebox Ground
6Low Beam Headlight Power
11Horn (53)
2To Horns
3Main Fusebox Ground
4From Horn Button
12Fuel Pump Relay (80, 67 or 167)
1Main Fusebox Starter Power (not used)
2Main Fusebox Start/Run Power
3To ECU (Fuel Pump )
4To Fuse 18, Fuel Pump, Oxygen Sensor Heater
5G2/6 (not used)
6Main Fusebox Battery Power From 30B
7G2/7, T1 (not used)
8Main Fusebox Ground (not used)
9M/4, U1/8, G2/5 (not used)
12Glow Plug Relay (102 or 104)
3Engine Temp Sender (preheat)
4Glow Plugs (Z1)To Fuse 18 (not used)
5G2/6 (not used)
9Water Separator, Glow Plug Light
remember to check out the website below for more help
http://www.xjamiex.com/mk2resource/electrical/CE2.html
Dec 30, 2014 | Cars & Trucks
Amana dishwaser adb1100aww won't start is there a fuse in dishwasher
If you are able to set the wash program on the panel but the start does not produce any action, then the door latch is causing a problem. There is a switch behind the latch that detects if door is shut. If this switch is not closing then dishwasher will not start.
Check items 4, 6 and 9 in this diagram. Make sure the mains power is disconnected as high voltages come to the door panel.
http://www.searspartsdirect.com/partsdirect/part-model/Amana-Parts/Dishwasher-Parts/Model-ADB1100AWW0/1268/0130000/W1302287/00002?blt=06&prst=&shdMod=
Apr 19, 2014 | Dishwashers
I have a Bosch SHU9955US/14 (Integra) dishwasher. There is currently a 0 with and asterisk showing on the display and the unit will not run.
see this causes and fix it. God bless you
Thermal Fuse If the dishwasher won't start the thermal fuse might have blown. The thermal fuse helps to prevent damage to the dishwasher by turning off power so that it doesn't overheat. Once blown, the thermal fuse will have to be replaced for the dishwasher to work.
Door Switch The door switch, or switches, are sometimes called interlock switches. The door switch prevents the dishwasher from running while the door is open. If the dishwasher won't start, the switch or switches might be defective. To access the door switches, remove the control panel or inside door panel - depending on the model. They can be tested for continuity.
Main Control Board The main control board provides power to nearly every component of the dishwasher. If the dishwasher won't start the main control board might be defective. YOU should first check for more common parts. Many times control boards are replaced unnecessarily because the problem was not diagnosed properly.
Touchpad and Control Panel If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced. On some models the touchpad and control panel are sold together and will need to be replaced at the same time.
Touchpad If the touchpad is defective, the control board might not get the signal for the selections made. If the dishwasher won't start and the display doesn't seem to change properly when the buttons are pressed, the touchpad might need to be replaced.
Timer The timer allows power to flow to the proper parts at the proper times. If the dishwasher won't start, the timer might be defective. Keep in mind that timers are often misdiagnosed as the cause of a problem. Check other components first before replacing the timer.
Sep 29, 2012 | Bosch Dishwashers
My Beko MW5104 is frozen and does not respond to any settings. It is permanently on at spin/end with the green light on. I can switch it on and off. I have unplugged it from the mains and switched it off...
Sep 28, 2012 | Dishwashers
Jenn air. Quiet seriesii won't start. Lights on panel flashing. Tried turning off power for fifteen minutes at breaker.
Dishwaser won't start
Check the door interlock switch. They normally run the L1 line through the door switch and if the door switch shorted, the dishwasher appears dead. Good Luck, Eric Campion
Mar 24, 2012 | Dishwashers
Unit just quit. won't start up. press start button and won't even light up
please provide the model number of the Samsung dishwasher.
if none of the lights light up, then a fuse might be blown somewhere. If the problem is the start buttion does not start the dishwasher , then the door latch switch could be faulty.
Jun 23, 2011 | Samsung Dishwashers
GE Twenty-Eight Hundred Dishwaser says blocked washarm, but isn't Code C5
If you've checked that nothing is in the way (no spoons hanging down, etc) just press and hold start and it will start up again and probably won't reoccur for the rest of the cycle. Our dishwasher started doing this near the end of its life....
Feb 23, 2011 | GE Dishwashers
you could try checking the door latch/switch. if it is burnt and not engaging, the machine may not start and will appear to have no power. i don't know the color of the machine, the letters after the LC will help with this, however maybe this brea250kdown will be helpful.
Oct 26, 2009 | Frigidaire 24 in. FDB510LC Free-standing...
Frigidaire 24 in. FDB510LC Free-standing Dishwasher Logo
306 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
