Question about Epson Stylus Photo 820 InkJet Printer
Epson Stulus photo 820
Installed on Vista. Initially OK but now prints everything green. Nozzle check is good.
  • 353 Answers
A very strange effect new to me (and I'm ****** old). All I can suggest is to uninstall the printer, reboot and reinstall. Report back.
Posted on Feb 01, 2009
HOW TO CLEAN ROLLERS FOR EPSON RX680 PRINTER
Follow these steps to print the nozzle check:
  1. Make sure plain, letter-size paper is loaded in the sheet feeder.
  2. Make sure the CD/DVD tray is not inserted in the Epson Stylus and the CD/DVD guide is in the paper printing position.
  3. Press the Setup button.
  4. Press cp_button_41_er.gif or cp_button_42_er.gif to select Maintenance and press OK.
  5. Select Nozzle Check, then press OK.
  7. Press cp_button_6.gif Start to print the nozzle check.
Oct 28, 2010 | Epson Stylus RX680 Color All-in-One InkJet...
After changing the color ink, a photo was not prin...
the problems are :-
  • cartridges are not recognised or installed
  • there is a paper jam.
May 21, 2010 | Epson Stylus Photo 820 InkJet Printer
I'm using an iMac G5 with an Epson an Epson RX595 printer. Everything worked well for a long time. Now ... the printer just shoots paper through constantly without printing. I've re-installed the newest...
hi,,
the nozzles of the printer might be clogged by dried inks thats why when your printing, its feeding the paper, as if its printing but no inks on the paper. print a nozzle check to see which part or color have clogs, if there are gaps or breaks, do head cleaning untill no more gaps then try printing.
click this link to see how to print a nozzle check and run a head cleaning, click the search box and type nozzle check, select "check the print head nozzles"
type head and select "clean the print head nozzles"
http://files.support.epson.com/htmldocs/rx595_/rx595_ug/wwhelp/wwhimpl/js/html/wwhelp.htm
pls come back and give me a vote. I would really appreciate that,thanks in advance. good luck.
Dec 03, 2009 | Epson RX595 Photo All-In-One Printer
Stylus Photo 820 printing magenta lines
did you clean the communication ports , where the cartridges "talk" to the printer, the ports can get covered with paper dust and erronus signals can cause the printer to activate the magenta cartridge causing your problem. reomve the cartridges and Gently clean the comm ports with a q-tip and rubbing alcohol let dry then reinstall the ink cartridges.
Jul 12, 2009 | Epson Stylus Photo 820 InkJet Printer
C88 printing green
Hi,are the catridges genuine? try head cleaning and check the nozzle .
Jul 01, 2009 | Epson Stylus C88 InkJet Photo Printer
Epson Stylus Photo R340 Faces in photo are printing day-glo green
Possible printhead or driver issue.
Are you using Adobe photoshop? Please try to print also using a different application to isolate the issue.
Make sure that you are using correct epson cartridges.
Please print a nozzle check pattern. If you see gaps, missing colors or missing lines on the pattern, clean the printhead using the driver.
If the nozzle check pattern printed out successfully, please trash and re-install the drivers. The driver is available on epson.com
Apr 29, 2009 | Epson Stylus Photo R340 InkJet Printer
My pictures are green when I print them
Possible hardware / driver or application issue.
Do a printer check first. Print a nozzle check pattern, if you see gaps or breaks or if any color is missing, clean the printhead. make sure that you are using an epson cartridge.
If ok, make sure that the print settings are correct.
If that does not resolve the issue. Trash and re-install the drivers.
Mar 19, 2009 | Epson Stylus Photo 1400 Printer
Epson cx9400 printer/scanner/fax
Follow these steps to print a nozzle check:
  1. Load letter-size paper in the sheet feeder.
  2. Press the cp_button_1.gif On button to turn on the Epson Stylus CX.
  4. Select Maintenance and press OK.
  5. Select Nozzle Check and press OK.
  7. Press the cp_button_6.gif Start button to print a nozzle check.
  8. Shown below are some examples of what the nozzle check may look like.
Mar 01, 2009 | Epson Stylus CX9400 Photo Printer
Printing Problems with Photos
you can try this one just to isolate if it is an issue with the software or with the hardware itself
it is just for windows users only
1) Make sure the printer is turned on but not printing.
NOTE: You cannot clean the print head if the any of the cartridges are expended. Replace the appropriate ink cartridge before proceeding.
2) Load letter size paper.
3) Click on START.
For Windows 95/98/ME: Click SETTINGS, PRINTERS, then RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PROPERTIES from the drop-down menu. Proceed to Step 4.
For Windows 2000: Click SETTINGS, PRINTERS, then RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows XP: Click CONTROL PANEL, PRINTERS AND FAXES. RIGHT-CLICK your EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. If this icon is not showing, select VIEW INSTALLED PRINTERS. Then RIGHT-CLICK the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
For Windows Vista: Click CONTROL PANEL,HARDWARE AND SOUND then PRINTERS. Note: these steps may vary depending on how Vista is setup. RIGHT-CLICK on the EPSON STYLUS PRINTER ICON. Select PRINTING PREFERENCES from the drop-down menu. Proceed to Step 4.
4) Click on the UTILITY or MAINTENANCE tab, then click on HEAD CLEANING.
5) Follow the instructions on the screen to clean the printhead. Cleaning takes about 30 seconds, during which time the printer makes some noise and the power light flashes. Never turn off the printer while the power light is flashing, unless the printer has not moved or made noise for more than 5 minutes.
6) When the power light stops flashing click PRINT NOZZLE CHECK PATTERN and then click NEXT.
7) If the nozzle check pattern has no gaps in its lines, click FINISH. If the pattern has any gaps, click CLEAN to clean the printhead again.
8) If the situation continues after three cleaning cycles and nozzle checks, replace one of the affected ink cartridge(s).
9) Once the cartridge(s) has been replaced, please follow steps one through seven up to three times.
If the nozzle check still has gaps after you have run at least 3 consecutive cleaning cycles and replaced the affected ink cartridge(s) with genuine Epson inks, your printer will require service.
Mar 07, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson Stylus Photo 820 InkJet Printer Logo
44 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
