Wireless connection lost
We have an Acer 5630 laptop loaded with Vista. The wireless connection has dropped off and we don't know how to get it back - can you give me an easy to follow instruction on how how to do this? Thanks.
I asked for the wrong model number previously - thanks!
    Sergeant:
  • 313 Answers
Wireless connection lost - 948c84d.gif Make sure #4 is switched to the ON position.
Then, double click on the wireless indicator located on your taskbar, near the clock in the lower right hand corner of your screen. That will tell you if it "sees" any wireless connections available to it.
You can download the manual for this laptop here: http://csd.acer.com.tw/acer/URMUL1.NSF/1af87a750eeeb70f0825628f006e0bfc/a9b67d2003ba6822482571f8000f317e/$FILE/AS5680_5630_3690-ENG-OLM_0727.pdf
Let me know if this helps.
Posted on May 09, 2008
THE WIRELESS CONNECTIVITY SIGNAL STRENGTH IS VERY POOR
I don't know the make of the wireless access point that you are using. First I would unplug the wireless access point, unplug the computer, remove battery, plug in the wireless access point, it will do a self test, when it completes plug in the laptop. You may have interference in your area? Is your wireless access point secured with a passcode? You can also change channels from defaults. I am not sure why you would reformat a machine due to wireless connectivity? You could re-set the wireless access point to defaults by pressing and holding for 30 seconds the reset will return the device to defaults, of course you would have to reconfigure the SSID and security core.
Nov 16, 2012 | Acer Aspire 5920-6727 Notebook
Wireless connectivity is very poor to my acer aspire 5920
I don't know the make of the wireless access point that you are using. First I would unplug the wireless access point, unplug the computer, remove battery, plug in the wireless access point, it will do a self test, when it completes plug in the laptop. You may have interference in your area? Is your wireless access point secured with a passcode? You can also change channels from defaults. I am not sure why you would reformat a machine due to wireless connectivity? You could re-set the wireless access point to defaults by pressing and holding for 30 seconds the reset will return the device to defaults, of course you would have to reconfigure the SSID and security code.
Nov 16, 2012 | Acer Aspire 5920-6335 Laptop
Cannot connect my acer 5600 wirelessly. WIFI is not lighted on. It says to turn on wireless switch.
The wireless switch is on the front edge of the laptop. With the lid closed, its position on the front edge is just under the right latch of the lid. Turn on by sliding the switch to the right momentarily. You should see Wireless LAN Enabled in large green letters appear briefly at the bottom of the screen. A single screen icon should appear in the desktop's Toolbar at the bottom right of the screen. If the icon doesn't appear, then likely the Wireless Network Connection is disabled. To enable do the following steps....
1. click start button at bottom right of screen
2. click Control Panel
3. in the Control Panel window, click Network Connections
4. right click Wireless Network Connection
5. on the drop-down menu click enable
If there is no Wireless Network Connection in the Control Panel's Network Connection, then the setting up of the Wireless Network Connection was skipped when the laptop was first unpacked and setup. In Control Panel, click on the Wireless Network Setup Wizard to setup the Wireless Network Connection.
Feb 14, 2011 | Acer Aspire 5600 Series 5630-6951 Laptop
My acer aspire 5630 wireless divices wont turn on
have you tried opening it on the control panel? please do try.
Mar 29, 2010 | Acer Aspire 5630 Notebook
How do I turn the wireless connection back on
either with the switch on pc or in control panel. wifi wizard should be used if possibe thre make new connection
Oct 06, 2009 | Acer Aspire 6930-6771 Laptop
Lost wireless connection
try to turn on the wireless bottom on your front-panel.
if that not work. go the connections and check if wireless connection is deactivated.
CS.
May 19, 2008 | Acer Aspire 5630 Notebook
We have an Acer 3650 laptop loaded with Vista. The wireless connection has dropped off and we don't know how to get it back - can you give me an easy to follow instruction on how how to do this? Thanks.
First make sure the Wi-Fi connector didn't get accidently turned off.
On the front of the computer, (right in the midde) is the wireless button, Press to enable/disable it. Try that first.
PS - you can download the manual here: http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=caf09f1c3e92ebda8a9d9dcd8625b7f0&q=Acer+Aspire+3650
Apr 06, 2008 | Computers & Internet
Settings in laptop for wireless connection
Most of the time the encryption key is typed wrong. make sure that yours is correct.
Dec 31, 2007 | Acer Aspire 5630 Notebook
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
