Question about Canon PowerShot A550 Digital Camera
Broken gear wheel in A550 lens
You mentioned an e-bay seller of these wheels.
Do you have a link please?
Thank you in advance.
  • henrik04 Apr 07, 2008
    Thank you for answering. I bought two A550 for my daughters and they now both have the same problem. Really annoying.
    Must be a very common problem as this last tooth in the reduction gear chain is far too fragile to sustain anything.
    Thank you for answering. I bought two Canon A550 cameras for my daughters last Christmas. They now both exhibit the same "Lens error" problem. And both cameras have the same broken wheel.
    Following your very good detailed A550 lens opening method, the last gear wheel in the chain reduction is damaged. Looking at the reduction ratio this last gear should have been made of a much stronger material.
    Henri
    Problem Solver:
  • 6 Answers
Henrik,
I ordered the gears, but unfortunately, they didn't fit. Sorry, I should have posted an update. I'll see if I have any spare from the cameras that I've repaired. I do know that I have spares for a530/a540, but not sure about a550/a560 cameras.
-pk
Posted on Apr 07, 2008
30 in. craftsman snow thrower,model no. 247.883960,pulls to the right
If your blower uses the two wheels to drive which I think it does I would suggest that you have a shear pin on the right side that is broken. If that is the case you will have to pull the wheel off and replace the shear pin. You can tell if it's broken by lifting the right side and trying to turn the wheel by hand.If it turns easily its broken.
This is an idea only. You might want to check both wheels as I'm not sure as far as the steering is concerned.
Feb 07, 2014 | Craftsman 30 In 357cc* Dual-Stage...
Front Wheel noise
Normally when this happen you must exchange the following parts:
ball joints +lower control arm +upper control arm+upper ball joint+arm bushing+ bar link+sway bar.
Of course maybe the coil spring. Since the cars are exposed to dust, and bad care you must proceed according. sincerely.
E.CUADRA
MANAGUA, NICARAGUA. C.A
Dec 05, 2011 | Ford Edge Cars & Trucks
Pentax me super can not advance the film advance
if the re-wind button is not stuck in, then the tab on the advance shaft is broken off. this small piece of metal will jamb the gears eventually.
take or send your camera to a repair shop for a cost estimate before repair as there are no new parts available for this model .
Jun 08, 2009 | Pentax ME Super 35mm SLR Camera
Left rear wheel of my Pliko P3 is broken, lower than right one
does the right side also have a spring? without being able to see it makes it real hard to guess how it works .
Mar 15, 2017 | Nautica Pliko P3 MT Standard Stroller
Telescopic Steering wheel won't move down - I hear a gear spinning
Open the gear motor on the left hand side of the telelscopic assembly. Take the plate off held by 4 philips screws. Using a 10mm socket, remove the bolt holding the platic gear. Remove plastic gear and insert the reverse way. Over the years, one side of the gears get worn out.
Oct 27, 2008 | 1997 Lexus LS 400
96 pontiac trans am
i have a 1996 trans am.i just replaced the optispark distributor cap and rotor,it starts fine,but when i drive for a bit stop the car,then try to restart,then it wont go,but if i leave it for a while it starts up fine again,now i am getting black smoke from my exhaust,any help or suggestions
Thanks Norm
Jun 10, 2008 | 1996 Pontiac Firebird
Problem with fe-210
Lens gears are probably broken off, or other problem with lens. Will need to replace lens, or may possibly be repaired. I've repaired a few lenses with gears broken off, by replacing broken off posts with similar size plastic pieces(drilled holes and super glued in place, being very careful). Still working months after repaired. Olympus repair shops can replace anything needed, but at a HIGH price; sometimes cheaper to replace camera than to have them work on it.
Jun 08, 2008 | Olympus FE-210 Digital Camera
Software
Hi…I have the 3-D Cruiser Software. I’ve actually just put the whole game (original box) up on ebay – username – babadee. I’ve gotten a bunch of emails from people needing just the cd so I’m making copies and offering them for $8.99 plus $3.00 shipping/handling. If you’re interested or know of anyone else, I can be reached at jncarling@aol.com…thank you377428
May 29, 2008 | KB Gear Little Tikes 3D Cruiser (1727)...
Lens error message Canon Powershot A550
Canon A550 and A560 have the same body and most of the internal parts, including lens assembly are the same. Canon won't sell individual parts within the lens assembly. There could be two possiblities. One is (unlikely) that the lens assembly components have been knocked off from their position. The other is that because of a knock, or dropping the camera, the gears in the gearbox of the lens assembly are broken. These gears are the same as the ones in A530/A540, and are available from ebay for $12.50 including shipping. Checkout my site for how to open up the camera and the lens assembly to replace these:
http://pkrobot.freehostia.com/MiscElectronics2.htm
For A550 and A560, if you take it to the professional repair shop, it might not be cost effective, since it might cost around $90. Canon does not sell gears, so they might have to replace the entire lens assembly. The new camera is available these days for around $140.
Jan 07, 2008 | Canon PowerShot A550 Digital Camera
Canon PowerShot A550 Digital Camera Logo
71 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
