Question about ASUS K8N Motherboard
Similar problem after ASUS relacement
We were running Win XP (Cyberpower case) when the original MB failed. ASUS replacement is acting essentially the same way - system will not complete the boot process, no video feed to monitor (so can't get to BIOS), fans and HDD spin up and power supply is fine, but we get no beeps.
    Scholar:
  • 50 Answers
Your first solution would probably be to find your CMOS jumper and reset the BIOS. Remove excess peripherals, like modem cards and the like. Make sure only the bare essentials are connected. As a last resort, pull all of the RAM and see if it beeps at you - if you don't get a long POST code, then the board is probably toast. I'd take a look at that power supply if that's the case.
Posted on Apr 09, 2008
6ya staff
SOURCE:
When i power on my system it getting error of ' reboot or insert media device' what can i do? help me. motherboard is asus m3a78-em. win xp
Open the case and check the connections to your hard drive. You may have a faulty cable to the drive(usually the data cable) on the other hand your hard drive may have failed. Also check you don't have a disc in the optical drive(CD or DVD). Make Sure The Power Is Off before you open it.
Apr 04, 2013 | ASUS M3A78-EM Motherboard
What are the required package for microsoft security essentials for my xp
The following are the system requirements for Microsoft Security Essentials
Operating System: Genuine Windows XP Service Pack 3 (SP3); Windows Vista (Gold, Service Pack 1, or Service Pack 2); Windows 7*
  • For Windows XP, a PC with a CPU clock speed of 500 MHz or higher, and 256 MB RAM or higher.
  • For Windows Vista and Windows 7, a PC with a CPU clock speed of 1.0 GHz or higher, and 1 GB RAM or higher.
  • VGA display of 800 × 600 or higher.
  • 200 MB of available hard disk space.
  • An Internet connection is required for installation and to download the latest virus and spyware definitions for Microsoft Security Essentials.
  • Internet Browser:
    • Windows Internet Explorer 6.0 or later.
    • Mozilla Firefox 2.0 or later.
  • Microsoft Security Essentials also supports Windows XP Mode in Windows 7. For more information see the system requirements for Windows XP Mode in Windows 7.
*Your PC must run genuine Windows to install Microsoft Security Essentials.
http://www.microsoft.com/en-us/security_essentials/default.aspx
Jun 13, 2011 | Microsoft Computers & Internet
Asus mother board audio driver download realtek i cannot download
hello
try this link for win 2k XP and 2003
http://www.driverstock.com/ASUS-P5RD1-VM-driver-download/6-9-10174-81137/index.html
or
ftp://dlsvr02.asus.com/pub/ASUS/mb/socket775/P5GL-MX/4150.zip
or if you use XP(64) 2003(64) try this link
http://www.driverstock.com/ASUS-P5RD1-VM-driver-download/6-9-10174-81138/index.html
or this one
ftp://dlsvr02.asus.com/pub/ASUS/mb/socket775/P5GL-MX/4150_64bit.zip
it works
omnittron
Mar 13, 2010 | ASUS P5RD1-VM Motherboard
Win XP driver
The manual can be found by navigating to Graphic Card> EAX1900 Series at:
http://support.asus.com/download/download.aspx
Haven't found the driver yet, though.
Mar 07, 2010 | ASUS EAX1900XTX/2DHTV RADEON X1900XTX,...
P5b-e mother board: USB ports on MB stopped working with operating system (have tried win & and XP). All ports work if running op system from disk
I would update the bios, uninstall the drivers for the ports, download the latest, and reboot. If the machine recognizes the ports, it will begin searching for drivers. Interrupt the search and manually install the drivers. If this does not good, I would reinstall the operating system. Also, use the drivers from ASUS...
Jan 03, 2010 | ASUS P5B-E Motherboard
No sound after reinstalled windows xp pro
Yes you will need to re install the audio driver. If you do not
have the original cd for the motherboard, here is a link to the
Audio Driver that you will need.
Download Link:
http://www.driverstock.com/ASUS-P5S800-VM-driver-download/6-9-10176-81148/index.html
Let me no if i can be of anymore assistance.
Mar 15, 2009 | ASUS P5S800-VM Motherboard
ASUS P5GPL and 4 modules DDR-400 512 Mb Hynix - not work correctly
I CAN NOT LOAD WINDOWS XP IS THERE BIOS PROBLEM ?
MY MOTHER BOAD IS 815E ( P 3 )
WIN 98 EASILY WORKING BUT NOT WIN XP
Nov 04, 2008 | ASUS P5GPL Motherboard
Replacement Motherboard (ASUS) P4S533
try using a bare system only means motherboard, psu, processor, ram then connect a speaker, does it make any sound ?
Oct 17, 2008 | ASUS A7S8X-MX Motherboard
AUDIO DRIVERS
If your drivers are from trusted source just click ok continue when the windows signing for drivers pop up window appear.
Now if you click ok and then the system fails to load and then give you a blue error screen, its caused by either
  1. The hardware or its drivers cause conkflict to the system, because your drivers are not from a source you can trust and they are not in compliance with windows OS features and as a result can not run in a windows OS. So get a fresh copy of the drivers from a trusted source preferably the product manufacturer
  2. The hardware itself is faulty and on installing to XP it causes a conflict in which case you can try the Sound card on a different PC and see if it runs, otherwise you need to replace it.
  3. (Assuming XP has finished loading the OS) Sometimes XP fails to unistall the previous drivers, if this is that case goto the device manager (windows icon >right click > properties >hardware > device manager) select ypur current sound card unistall the driver that is there and then restart your machine and load the new drivers again
Mar 25, 2008 | ASUS NVIDIA nForce Chipset A7N266-VM...
Open Questions:
See all ASUS K8N Motherboard Questions
ASUS K8N Motherboard Logo
83 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
