I have a 2 year old CTX S760A monitor, when I switch on the computer the monitor switches on and off several times about 25-30 times before stabilising. It works well after that. This has been happening for over 3 months now.
    Problem Solver:
  • 15 Answers
First, I would try connecting a different monitor if possible. If the problem persists, it would be a problem with your computers video card. If the 2nd monitor works fine, then your monitor is at fault and may need to be replaced.
Posted on Apr 06, 2008
6ya staff
SOURCE:
My lcd screen switch goes green and a message appears "going to sleep" and the switch light goes yellow
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or flashing, but nothing displays, borrow a monitor from a friend. If that works, your monitor needs replaced.
May 10, 2014 | CTX S762A 17" LCD Monitor
'No signal input and power down' message after switch on.
Remove the data cable from the back of the monitor check what message its giving ? If it shows some message like No VGA cable etc.. it means the monitor is fine.
Checked the computer in safe boot
It could be windows issue
Nov 04, 2010 | CTX P922E (Silver) 19" LCD Monitor
My BenQ FP71G powers on and off, repeatedly, by itself no matter whether connected to computer or not. Everything else is fine. Sometimes it stays on for a minute or so, but usually for just a few...
my BenQ FP71G 17 in goes on after hundreds of times pushing on off switch and when it's on it does not go off, I have checked the on/off switch which is working oke and when the moniter is on the auto adjust message (brightness and contrast)pops up frequently and the screen adjusts itself.
Oct 12, 2010 | BenQ FP71G 17" LCD Monitor
I have a ctx moniter says undectected mode
CTX 15"1024x768 TFT LCD-Black Monitor · i have a ctx moniter says ... Answer. i have a ctx moniter and wen i plugnitin to pc tower itsays undeceted mode watdoes this mean. Close Close. ASUS Eee PC 1000H
Dec 03, 2009 | CTX 15"1024x768 TFT LCD-Black Monitor
Dell flat screen monitor does not come on after
Sounds like a capacitor on the power strip inside the monitor is failing.
The cost to repair can run $400.00. A tv repair shop may be able to fix it, but most technicians recommend buying a new monitor.
However, if you are experienced in electronics, you can disassemble the monitor and replace the capacitor. Radio Shack sells them for between $15 to $20.
Oct 10, 2009 | Dell E173FP 17" LCD Monitor
No display on SyncMaster 920NW after reboot from power failure
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of the monitor. If you are good at electronics repair/soldering you can usually fix the problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. Look in our monitor repair section for step by step repair guide for this model it should be the same power supply as the 930. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jul 22, 2009 | Samsung SyncMaster 920NW Monitor
Windows multiplied not solved
did you try the mode reset switch on the monitor after going back to 800x600? also try 640x480/16 colors since that is one of the default modes for all vga monitors.
Jun 29, 2006 | CTX Value VL 510 15" CRT Monitor
Open Questions:
Computers & Internet Logo
Ekse
Marvin
Marvin
