Is the Hitachi 60FX32B projection TV an HD TV?
No it is not
Posted on Apr 08, 2008
SOURCE:
Focus hitachi 60fx32b was watching this tv and it suddenly turned off and wont power back on
Try to plug it into a different electrical socket and try it without any extension cords or power strips (sometimes the socket or extension cord is to blame)
Oct 19, 2013 | Samsung PCJ522R 52" Rear Projection...
How to move red line on a hitachi 60fx32b
Convergence is adjusted with Hitachi remote and to get into mode you remove speaker grill (on model indicated) and locate small blue button on front of chassis--with set on press button and grid of lines comes on.
If red is really bowed and will not adjust----the convergence chips need to be replaced.
Feb 19, 2012 | Hitachi Televison & Video
Hitachi 60fx32b out of focus how can i fix it
If not a convergence issue: each tube (back of set) has a large black lens with a wing nut on side----loosen nut and rotate lens slowly until red is in focus.
Feb 19, 2012 | Hitachi 60FX32B 60" Rear Projection...
BLOWN RESISTORS
you can download your schematic that will tell you resistor values and the rest of the circuits and IC indentifications as well as test procedures and more , this is a ten part zip that can be opened with winzip and read with adobe just click here http://www.eserviceinfo.com/downloadsm/12926/Hitachi_50FX30B.html
then to order resistors you can get them here http://www.nteinc.com/
or look for an electronic parts supply store around you , but alot of the time they too have to order the parts, ecspecially certain valued resistors or other special valued parts
if you need more help just ask !
Dec 11, 2008 | Hitachi 60FX32B 60" Rear Projection...
Hitachi 60fx32b is dead with no lights on front panel
The two other fuses look like resisters. My suggestion would be to check them first and if bad use a temp of the same rating to see if it was just a power surge.
Apr 14, 2008 | Hitachi 60FX32B 60" Rear Projection...
Tune up for Hitachi 60FX32B
Remove rear cardboard cover....can you see tops of red / green /
blue tubes ? Clean lens' with soft , dry cloth......Do you smoke ?
If not , replace back. Picture should now be clearer but not
necessarily brighter.......Next, remove front speaker grill and find
the RGB focus / screen adjust block....turn RGB screen controls
SLIGHTLY clockwise to achieve more brightness....not too much
or you will have retrace lines in background of picture.......Let me know after these steps are done........T.
Mar 02, 2008 | Hitachi 60FX32B 60" Rear Projection...
Hitachi 60fx32b rear projection
When you turn on the TV do you hear 3 clicking noises then the TV turns off?
Jan 12, 2008 | Hitachi 60FX32B 60" Rear Projection...
Hitachi 60FX32B picture
Replace vertical output IC with first quality part,check caps
in vertical power supply......If you don't have access to parts,
then solder pins of IC,should hold for awhile.
If you need further assistance, let me know.....T.
Oct 26, 2007 | Hitachi 60FX32B 60" Rear Projection...
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
Ekse
