Question about Mitsubishi WD-52525 52" Rear Projection HDTV
How do i clean the fans?
I have sound but no picture.  Lately I've noticed the fans seemed to hum louder when the tv is off when they are cooling.  The bulbs dont come on. if i clean the fans will that help? Or do Ineed a pro?
Thanks drumor
  • oatesy1 May 04, 2008
    the fan on my rear projection tv hums really loud, is this because of dust in the fan. if so how do i clean it out?
    model 44dlw617 (thomson)
    Sergeant:
    Champion:
  • 301 Answers
There is only one fan inside the tv that is on all the time. it is the chassis. fan located on top of the chassis on the left side on tv looking from back.
Posted on Apr 09, 2008
SOURCE:
My refrigerator makes a loud humming sound.
sounds like its bearings in a fan motor probably your evaporator fan motor it is located behind the plastic shell in your refrig. you have to take out the lining and then you will see the fan, evapartor and etc.
Jul 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Making a lot of noise
Sounds like a bearing in the cooling Fan
Thanks for using FIXYA
Sep 21, 2009 | Samsung DLP HL-P5663W 56" TV
Cooling Fan noise
Another possible source for the noise is the Color Wheel. It is spinning at a high rate and the noise will get louder as it wears out. You should be able to replace the part yourself. Take a look here first: http://www.fixya.com/support/t372149-samsung_hlp4663w_color_wheel_replacement
Aug 04, 2009 | Televison & Video
Samsung hln 61 make loud humming
yes this is a very common issue with Samsung DLp's, and it will get louder and louder until TV will not turn ON anymore. You can replace it yourself is very simple, here is kind of a guide for that http://guides.fixyourdlp.com/samsung/bp96-01579a.php and http://guides.fixyourdlp.com/samsung/bp96-01854a.php
Jun 25, 2009 | Samsung HL-P6163W 61" TV
Deep Humming Noise
if the noise continues after you power down its the cooling fan
Jan 22, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Humming noise from tv
Yes a humming noise on that model is usually related to the color wheel It will get progressively louder
Jan 17, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Tv makes humming noise when on. how can I eliminate or reduce the nose?
Some of the larger TV's are DISH ready, meaning that they have the tuner inside for SAT TV. The SAT tuners often have an internal fan that makes a humming noise. If it sounds like something other than that, you might have a bad component in your sound circuit that allows 60 HZ hum through the speakers.
If it is a rear projection LCG TV it has a fan in it to cool the bulb. You will hear the fan if you listen closely. It usually cannot be heard over the volume.
The fluorescent bulb and electronics inside make humming sound naturally. Kinda like when you turn on a lamp, and some lamps make a low humming sound.
Apr 03, 2008 | Televison & Video
Toshiba 46HM95 Buzzing
I have the same thing, mine is the cooling fan for the lamp. If the sound continues for a short time after you turn off the TV then this is the most likely cause as the cooling fan will continue to run for a short time to cool off the bulb. I have looked into replacing mine, the part runs around $50 but I can't say yet how easy it is to replace yet.
Apr 02, 2008 | Toshiba 46HM95 46" HDTV
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
203 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
