Question about LG enV VX9900 Cellular Phone
Lg enV LCD replacement
Was it difficult to replace the screen?
  • purplerosse Mar 31, 2009
    i bought a replacement screen from ebay and was trying to change the screen but got stuck on the speaker part... how do u do the "soldering" ???
  • 113 Answers
Not bad,
here are some instructions
http://howardforums.com/showthread.php?t=1257681
Posted on Apr 06, 2008
    New Friend:
Here's a site that sells a VX9900 disassembly "repair guide" for $4.99 by PayPal. The instructions are sent by e-mail in a message.
http://www.ioffer.com/i/-VERIZON-LG-eNV-ENVY-VX-9900-DISASSEMBLY-Repair-Manual--38315441
Posted on Dec 14, 2009
2 Suggested Answers
SOURCE:
SOURCE: replacing LCD screens
ok just fixed one screen. the outside one. GET YOUR SOLDER GUN READY!, your gonna have to de-solder the speakers. to get the phone open theres 4 screws phillips head on the inside. Use a razor blade to pry the black tabs up and take the screws out. the 2 silver tabs have to come off completely. then take your razor between the top and bottom covers. theres 4 big clips on each middle section of the 4 sides. i first start on the edge that opens up. U put the razor in and very very carefully pry the top half out towards yourself it should then POP up separating the 2 sections. then i move to the top and bottom of the phone then the back side. after u got all 4 edges poped u slowly work your way around prying the top part OUT from the edge not up. Ull see what im saying when u start working on it. once the top cover starts to come off be careful that u dont pull the wires off the ear piece speaker. just take it off the top cover.
Next: theres a silver bracket that has to come off next. it holds the buttons and light on. theres a ribbon cable that i dont see any way of getting off that conects to be buttons so be careful. then u have to pry the plate that holds both LCDs in place. I only had to replace the smaller lcd so my job was faster. But if u have to replace both screens, the next step you'll have to do is.
Take the speakers out of there places buy prying them out but be very careful again. they are glued in and u can ripp the speaker covers off. but they come out easy. You also will notice that the speakers are soldered on. after that then i think both lcds will come out and u can just solder on the speakers to the new lcds. The +- are labeled. S is for speaker R-is for the mic and ear piece. took my about an hour just to replace the small lcd but i take my time and dont rush. Hope you guys have patience and a steady hand and good eyes. Good luck
Posted on Dec 05, 2007
The internal screen on my LG Env Touch remains blank after opening. The interenal keypad lights up when opened, but not the screen. The phone did not get wet, to my knowledge, and was functioning properly...
Hi, most screen problems usually happen after a fall or a knock against a solid object. There are two things that might have happened here. One might be, the screen got a hairline crack and the connection to the lcd is broken. The other is that the lcd did not crack, but the connector flex cable is disconnected. The first requires a replacement lcd. The second requires an inspection to see if the flex is disconnected or broken. (You will have to open the phone). If you cannot DIY, then take it to a repair shop. Replacement lcd can be found on ebay.
Jul 09, 2011 | LG enV Touch VX11000 Cell Phone
Inside screen not working properly
if the actual lcd is non functional the phone needs to be repaired or replaced. if the screen has black spots or jagged lines it means the lcd is cracked.
Mar 07, 2011 | LG enV Touch VX11000 Cell Phone
My internal screen is broken but when i press a couple buttons it goes on. how can i fix it?
You can get a replacement screen from Ebay for about $30.
http://cgi.ebay.com/LG-VX9200-ENV3-ENV-3-LCD-Replacement-Display-Part-OEM-/300435667053?pt=PDA_Accessories&hash=item45f35c786d
Oct 26, 2010 | LG enV3 VX9200 Cell Phone
How to replace lcd on env touch vx11000
This one is VERY tricky. I wouldn't let anyone touch it unless they had a lot of experience taking apart phones and putting them back together. Basically, the LCD screen (all LCD screens) is stuck on your phone by a really strong adhesive sticker. I DO NOT recommend trying to pry it off because it will only break or crack a screen. What you have to do is unscrew those tiny little screws that connect the surrounding body of the phone to the LCD screen, then pop off the body of it. Then, CAREFULLY unstick the screen, replace it, and put it back together.
Jun 18, 2010 | LG enV Touch VX11000 Cell Phone
Front lcd screen not working
there is a magnet inside the plastic of the case the sixe of a lego mans hand. it tells the other side when the phone is closed by closing a contact. It may be damaged.
Or the front screen seperated from the inside screen and wont work. This can ghappen from dropping it or hard impact.
You have to take it apart and make sure its pressed together riht. It can be difficult.
Nov 19, 2008 | LG enV VX9900 Cellular Phone
Broken screen and spac bar
Replacement screen:
http://ucables.com/ref/LG-B2050-LCD-RIBBON-O-R17209
Oct 23, 2008 | LG B2050 Cellular Phone
Replacing the front LCD display of an LG EnV phone. My Daughter dropped it and the front screen cracked and now only half of it displays.
I think its better to bring it to your nearest celphone repair shop. And let the technician do replace the lcd.
Oct 16, 2008 | Cell Phones
LG enV VX9900 Cellular Phone Logo
3,102 people viewed this question
Top LG Cell Phones Experts
William Norris
William Norris
George Etukudo
George Etukudo
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
