Question about E-Machines eMachines Refurbished EMA SYSTEM BOARD MODEL T2984 eMachines (102257) PC Desktop
Motherboard Config Emachines T2984
I have been tried to power up this emachine T2984 but no such luck. I accidently pulled the power switch and LCD switch for the hard drive and I dont know how to replace the wires on the motherboard. Can't find a system board diagram online. Does any one know how the connectors fit on the motherboard?
  • 3 more comments
  • bozo Apr 28, 2008
    I made this diagram, hope it helps.
  • meltdownmike Aug 30, 2008
    Is the pin layout the same on a T2682 replacement motherboard (aftermarket)?
  • Anonymous Sep 01, 2008
    I have been tried to power up this emachine w3619 but no such luck. I accidently pulled the PWR S/W, and PWR Led for the hard drive and I dont know how to replace the wires on the motherboard . Can't find a system board diagram online. Does any one know how the connectors fit on the motherboard?
    thank you for your help .
  • ttocs65elad Jan 18, 2009
    i need to know how the power switch leds connect to the motherboard.
  • sam l Mar 23, 2009
    I have a T2984 is there a reset of any kind we thought the power board burned out because it stunk,replaced it and still no fans and motor but light on mother
  • 30 Answers
I made this diagram, hope it helps!
Posted on Apr 28, 2008
I have been tried to power up this emachine T3958 but no such luck. I accidently pulled the PWR S/W, HDD Led and PWR Led for the hard drive and I dont know how to replace the wires on the motherboard . Can't find a system board diagram online. Does any one know how the connectors fit on the motherboard?
Posted on Jul 26, 2008
I have the same problem with t3958
Posted on Apr 02, 2010
The lower red wire led is below left, the power switch black wire is right, & the top led blue wire is upper left.
Posted on Feb 06, 2009
I have the same problem is there a diagram for the W3619 motherboard?...i need to plug in my power button and lights
Posted on Sep 14, 2008
Is the T3830 wired the same way?
Posted on May 09, 2008
    Scholar:
  • 59 Answers
Try looking at another motherboard most are the same or very close, the led cable probably goes toward the back, the power switch normally goes near the beginning with the missing pin just in front of it if i remember correctly, I work with a lot of strange hardware so i could have it wrong right now. if i refer to the manual from the motherboard in my new pc.... it's and MSI K9N6GM there are two areas near the front (by the front of the case) where these cables plug in, they are labeled jfp1 and jfp2, you will probably want to look for something similar, there are usually just a group of pins arranged in a rectangle with one missing at one end, some pc's will have a special connector, this is really popular with dell, but it makes it harder to upgrade your hardware.if your look around and think you find the right pins, look for the missing pin and the power switch goes on the two pins after that, since this is an off the shelf pc it might not have the pins labeled if it does its very small print. when you look at it it will resemble an equal sign = the power switch goes on the side with the missing pin only normally, the reset switch if there is one goes on the next row over in the same spot, leaving one pin exposed on that side, the power led goes behind the power switch and the hdd activity light goes behind the optional reset switch. that should be close to what you have, also to test if it will come on at all before going through all that trouble try running a small screwdriver across the pins  rather quickly but gently, it should power up, it make take a few tries but one you are used to it you'll get it to work almost every time, hope this is in someway helpful, good luck.
Posted on Apr 06, 2008
IM connecting a OKIA LC-8460BTX POWER SUPPLY TO MY EMACHINES T2984. I cannt figure out where the wires are placed.
There should be a photo of the board and instruction on where the leads are fitted if you browse the manufacturers web site and input the model of the unit you are refitting.
I have found this site, which may be of use to you. Regards.
http://www.techsupportforum.com/hardware-support/motherboards-bios-cpu/302350-e-machine-t2984-motherboard.html
Jan 04, 2011 | E-Machines eMachines Refurbished EMA...
Install a AU31 E machine Motherboard I need to know exactly where each of the tiny power wires go on the motherboard that controls the power.
from the power supply there's a wires with 16 or more pins / connected as 1. insert the in corresponding socket on the motherboard. on the casing there's a wire that has a label of power or power switch. insert that in the motherboard with an indicator power (pins like)
Jun 02, 2010 | E-Machines eMachines Refurbished EMA...
I have a emachines t2984 i press the power button and doesnt turn on i replaced the power supply with different ones and nothing and the light turns on (power button) but the when i press the button the...
Ok, test the power button pins. First disconnect any power source to the computer. Then, find the power pins on your motherboard (the one that your case's power button connects to. Usually two wires, one red and the other black). Grab a jumper a connect it to those two pins, they usually have the letters "pwr" or "power" printed next to them. Then, once you've done this, with the jumper connected, connect the power cord to your power supply. It should turn on by it self. If it does, then the problem is the power button. If it does not do it, then the problem is the motherboard. Good luck.
Jan 22, 2010 | E-Machines eMachines Refurbished EMA...
Motherboard config for Emachines W1640
i don't know too much on this but here is website that is sure to help you: link
Jun 27, 2009 | E-Machines eMachines Refurbished EMA...
2 emachines won't boot
Are you attaching them properly
if so then it is something other then power supply
something has caused both power supplies to blow
have you installed anything in the first emachine you talk about
Jan 17, 2009 | E-Machines eMachines Refurbished EMA...
I have an emachine T2984 that won't boot. No noise of any kind. I had another emachine T2625 that was working. I took the power supply out of the T2984 (that wouldn't boot) and put it in the T2625 and it...
Power supply sounds fine. If the pc won't power up it could be your motherboard. If the pc is powering up and you get a 'no signal' on your monitor it could be your gpu.
E-Machine will not power up after being moved
system board model t2984 emachines pc does not power on. how much for replacement board.
May 09, 2008 | E-Machines eMachines Refurbished EMA...
Emachine T2984 won't power up
First, Check your ram. If not seated, it will not power up. Also, do you hear a series of beeps or not? Need a better & more exact description of problem and what occurs
Apr 14, 2008 | E-Machines eMachines Refurbished EMA...
Dead motherboard on emachines t2984
I hope that you took it back to them.
Have them check the power supply, too. Besides, a bad power switch and connections that would be the only thing that would be keep it from starting.
Mar 12, 2008 | E-Machines eMachines Refurbished EMA...
Motherboard manuel
i need manual for motherboard 14319 imperial_gv 20030812 thankz
Dec 25, 2007 | E-Machines eMachines Refurbished EMA...
E-Machines eMachines Refurbished EMA SYSTEM BOARD MODEL T2984 eMachines (102257) PC Desktop Logo
6,735 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
