Question about Palm TX Handheld
Palm tx Iceman I can not get my palm tx to connect to my wireless router on my home compter.I have it conneted direct to 2 other computers and they work fine.My up link on my palm works as long as I am pluged in.(linksys) Can you walk me through the steps to get my Wi-Fi network working. thanks Stan
  • 2,794 Answers
Does your linsys router have MAC filtering turned on in the WI FI settings?
Posted on Jun 09, 2008
Hi I am using Belkin router & unable to connet through wireless, if I connect directly from wire I am able to connect pls help. My username that is moon sam is not detecting its showing some other name
you are able to go online when the computer is wired that means wired connection is working.
open the router setup page and check the wireless settings of the router
Click here for more info
Dec 05, 2009 | Belkin Computers & Internet
Netgear WGT624 router won't connect to the internet
I am in the UK and have found through experience the Netgear's seem to work perfect on a BT line (equivalent of AT & T)
but not on the cable.
I would suggest purchasing a Linksys by Cisco WRT54GL Wireless-G Broadband Router as these seem to install in minutes,
saves me hours of wasted time when setting up wireless networks.
Jan 18, 2009 | NetGear WGT624 Wireless Router
WiFi not connecting to cisco router
most likely the Palm "listens" on another frequency.
Make sure your cisco is running the Wireless b standard as that is what the Palm Tx needs.
Mixed mode is another option (b and G at the same time)
Let's say your router is supporting the b standard. Knowing the cisco APs a bit, it is also possible to have a channel selected that an older device cannot see/or it is set for another region (which in fact is the same, as frequency ranges are different for each continent).
There are many tools for WIFI analysis, many are free. They will tell you what your router is transmitting at, etc... withouth having to go into the cisco IOS.
Jan 01, 2009 | Palm TX Handheld
Changing router settings from 802.11G to mixed w/802.11B
Switching the wireless mode is easy, and, if you choose "mixed," the other computers in your home can continue to use the G mode unaffected. How you adjust the mode depends on the brand of router. Since Linksys is the most common, here is how it works on a Linksys router:
1) Open your web browser (IE, Mozilla, etc.)
2) Type the web address 192.168.1.1 (default for Linksys routers).
3) You should be asked for a username and password. The default for Linksys is username "admin" and password "admin" OR username "admin" and password [blank].
4) You should then see the Linksys setup screen. The tabs across the top include Setup, Wireless, Security, etc. Click on Wireless.
5) Pull down the menu next to "Wireless Network Mode" (which shold be set to "G -Only" and choose "Mixed." Then click "Save Settings."
This should allow your B-capacle Palm to use the network without a password while still allowing your encryption-capable computers to use the G mode.
I hope this helps - please let me know if I can be of any further assistance.
H2H
Dec 14, 2008 | Linksys (WMP54GS) 802.11g/b Wireless...
Need to change Linkys 802.11G to a 'mixed' 802.11B
Thanks for choosing fixya.com
Changing to "mixed" mode should not cause any problems with your other system. It simply tells the router to transmit and receive using both B and G.
First you will need to log into the routers web interface. If you have the manual it will help greatly in doing this.
Otherwise it is usually default of 192.168.1.1 or 192.168.0.1. Some routers use alternate ip's the exact model would let me look up more information.
By putting one of those ip's in the address bar of your web browser your should be taken to your routers web interface. From here you can change all the settings you'll need.
You will want to find and click the "Wireless" tab at the top of the page. In here it should have a drop down menu for B-Only, G-Only, Or "mixed".
Set it to "mixed" and press save.
Here is a link to a screenshot of what the page should look like
http://i303.photobucket.com/albums/nn133/techiedesign/wireless.jpg
I hope this helps you.
Jei
2wire xbox 360 wireless
My 2 wire is a home portal 1000 which doens't have wireless. So the easiest way to solve this is to get a wireless router and plug it into your 2 wire router (I did this) then connect the xbox 306 to that.
Sep 24, 2008 | 2wire (1000-400108-001) Router
Actiontec Wireless Router not providing internet connection
hi firend
there thats the way but if u have wireless connetion in your router & if u have wireless in your laptop then u can use easy in your home
Apr 27, 2008 | Computers & Internet
Palm TX wireless configuration
Using a computer that is currently able to connect to your router, open a web browser and go to http://192.168.1.1/ or http://192.168.0.1 (whichever works), and log in to your router. The default username and password might be "admin", or just "admin" for the username with no password, or check the manual to find out the default username and password. Once you've successfully logged in, you should be able to get the security settings where you can see what the WEP key is.
Let us know how you make out.
Jan 02, 2008 | Palm TX Handheld
Cannot print images from Palm TX--Notebook section
Not sure what you mean by "Notebook section", but you need to have a print software installed on the TX to print directly to a printer (without a computer). You can use PrintBoy: http://www.palminfocenter.com/view_story.asp?ID=1651 It will enable you to print wirelessly from your TX. Otherwise, try using CardReader http://software.palminfocenter.com/product.asp?id=2062 and your USB cable to connect your palm as a usb card reader, to your computer. Then you can transfer the images or any needed files to your PC.
Nov 28, 2006 | Palm TX Handheld
Palm TX Handheld Logo
150 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
