Power supply How do I begin to tackle changing the power supply on my westinghouse w3213hd tv? Thx, Manny
  • 1 more comment
  • Mannylove May 01, 2008
    I took the power supply out with no problems whatsoever! I just need to find a replacement....anyone know where I can get part number 4900253180?
    Thanks in advance!
  • agolden23 Oct 26, 2008
    Were you ever able to get this issue fixed. I have the same TV. When i press power the blue LED comes on but the TV doesn't power up. If you had the same issue and the new power supply was able to fix it then i am going to do the same. Please email me at [email protected]
  • gigimas Feb 13, 2009
    ilo32
    Scholar:
  • 72 Answers
Best place to look is ebay and see if anyone has one up for sale. Usually get one really cheap compared to getting a new one. But if u want a new one do a internet search for one type manufacture and power supply and part number. Or u can check parts.com
Posted on May 03, 2008
SOURCE:
My westinghouse 46" led tv will not turn on, tested the ac power supply and its good
The problem might be of its mother board itself. Contact any experienced service technician to make it confirm before change it. There are so many adjustments should be done after changing a new mother board. It is not a user reparable work.
Jan 16, 2013 | Westinghouse Televison & Video
My new Westinghouse LD-4695 LED TV changes the channel by itself, sometimes just one at a time and other times rapid both up and down? Also shows me that the speakers are off as I use my surround sys
Several issues here so to begin with remove power from the set and a box of any kind if used for several minutes and then power back to see if a reboot helps or not.
Dec 23, 2012 | Westinghouse 46" Class LED 1080p 120Hz...
I have a westinghouse sk32h240s. wont turn on and no amber light.
First try a new power cord for the TV. If that doesn't solve the problem, the power supply has failed. (Possibly one or more capacitors on the power supply board have failed. Alternatively, a fuse, zener diode or resistor that works as a fuse has failed) You will need to open the tv and inspect the power supply. Westinghouse TVs use a number of different boards. If you want to replace the entire power supply, you will need to note that exact part number on the label. ShopJimmy has refurbished and used power supplies for this model: http://www.shopjimmy.com/westinghouse-sk-32h240s . The used ones are from TVs that were damaged in shipping and thus have minimal use. http://www.partstore.com/Model/Westinghouse+Digital+Electroni/Westinghouse+Digital/SK32H240S/Other+Remotes.aspx also has replacement parts.
I hope this helps.
Oct 03, 2011 | Westinghouse SK-32H240S Television
My Westinghouse tv shuts off when I'm watching after about 15 minutes what is wrong with the tv
I'm not sure but I think it could be the power supply, probably swollen capacitors, they can be changed but ownly by a good tech.
Jan 04, 2011 | Westinghouse 32" Flat Panel LCD HDTV
Westinghouse LTV-32w1 32 in. HDTV-Ready LCD Television I have a 32" tv Westinghouse, it was on went I hear a sharp pop like glass breaking, I unplug it for a willy plug it back in and nothing happen what...
Ur power supply board is dead.Take ur tv aparts,replaced the power supply board.Ur tv will get ur power back an the tv will work again.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 06, 2010 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
No power on Westinghouse sk-19h21os flat screen monitor tv
I found a 2200microfarad @ 10v capacitor in the switching power supply that was bad. In these supplies, precision is crucial and tiny changes in the circuit will make them fail. Good luck !
Jun 02, 2009 | Westinghouse SK-19H210S Television
Westinghouse 32 inch screen goes blank
replace capacitor c162 on power supply
power supply was a delta electric dps210ep-2c rev01
reheat any solder joints that don't look 100% as well .
such as c310 .
this is a known working fix . try before you buy a supply .
Dec 25, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Power up problems
Does anyone know what the part number for this elucid power supply would be? My TV is doing the same thing, so I'm trying to find one so I can swap it out.
Apr 09, 2007 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Televison & Video Logo
422 people viewed this question
Top Televison & Video Experts
Ekse
