Question about Dewalt DW746X 10" woodworker's table saw with rai
Switch diagram I am trying to replace the switch on a Dewalt 364 Type 3 circular saw. My boss gave me 5 Dewalt Saws to work on..I am having trouble with the wiring diagram..switches from two saws are different...one says the black leads go to the top the pther says no....yuk and help me please..al
    Champion:
  • 313 Answers
As u notice the terminal on the switch has 2 connection like a switch diagram to it.it has normally open & normally close contact. the normally close contact are for red & white wire & the other
contact are for 2 black wire which is normally open contact.hope it helps.
Posted on Sep 19, 2008
  • 25 Answers
Be careful with your wiring as some models have a reset switch. Your best bet is to mount new external metal boxes to the frame and obtain industrial switches capable of carring the amperage load that the motors are drawing. Then you'l have identical controls on all units so future control problems will be esasy to solve. In your wiring, always remember that the black is the hot side and always routes through the switch and then to the motor while the white bypasses the switch and goes direct to the motor. In event you have a reset switch,, your black will go in as well as out of the reset and then through the switch to the motor.
Hope this helps.
Posted on Apr 24, 2008
How do i get to the trigger on a dwalt939 circular saw
The way your saw is built, the only way to get the switch is to split the clamshell. Depending on where the screws holding the two halves together are, you may or may not have to remove the upper blade guard and shoe assembly to do it.
Feb 19, 2013 | Dewalt DW936K 5-3/8 in. 18V Cordless Trim...
Replace gear case dewalt 364
It usually takes longer if the customer "helps" by taking the tool apart first so with that in mind if you try it and cant get it the tech you take it too may charge you more than if you took it there first. Now if you're fairly good mechanically you might do just fine. It's a time consuming job though.
Jan 04, 2013 | Dewalt DW364K 7 - 1/4" circular saw with...
How to replace brushes on a DW362 type 2
There are 2 black caps on either side of the saw that hold the brushes in they are # 5 on the diagram
Oct 13, 2012 | Dewalt Dw362 Circular Saws
Saw is smoking
First I would check to two wire leads coming from the switch to the brushes. They will often melt from too much heat. There is a very good chance that the switch is bad too. Here is the parts diagram. The leads I referred to are items 43 and 44.
DeWalt DC385 diagram
Aug 19, 2012 | Dewalt 18v Dc385 Cordless Reciprocating...
My 18v dewalt cordless circular saw wont run any more,i smelt a burning smell when cutting.could it be burnt out?
The armature could very well be shorted out. You may want to contact a DeWalt service center and ask about the GRC repair program. Here is a parts diagram.
DeWalt DW936K diagram
Aug 06, 2012 | Dewalt DW936K 5-3/8 in. 18V Cordless Trim...
Need to replace the cord. Before I open it up, wanted to verify that it has serveceable connectors inside?
generally they have ring terminals on the switch or the wires need to be soldered to be pushed into and lock into the switch. ON some rare occasions I have seen wire nuts, so you should be OKAY just make yourself a wiring diagram before removing anything, it makes reassembly easier.
Aug 01, 2011 | Porter Cable 345 6" Circular Saw Saw Boss
How to wire switch for Dewalt DW718 Type 1 mitre saw.
Does the switch not have color words on the back of it? They used to. Go to Dewaltservicenet.com and look up your model number and type number. Wiring diagrams will be found there. Lemme know. Please rate me
Jun 17, 2009 | Saws
Dewalt power saw wiring diagram for trigger switch dw-708 type 4 wire colors to swith positions.
The Switching should go like this
(single letters denote wire color)
Y---o o---R
B---o o---B
The contacts where the black wires attach are the points on the switch that break when continuity is checked.
Apr 12, 2009 | Dewalt Saws
Dewalt DW746X 10" woodworker's table saw with rai Logo
700 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
