Digital Cameras
Problem for Digital Cameras
Generic problem for all Digital Cameras
Blurry picture
By judy515 on Apr 06, 2008
blurry picture
Solution #1
posted on Apr 06, 2008
Somewhat Helpful)
bhiga
Rank: Guru
Rating: 86%, 91 votes
What make and model of camera do you have?
In general, you need to make sure you aren't shaking the camera or focusing on something that's too close. Also, you need to have adequate lighting or enable the flash.
If it's a new camera, make sure you have removed any protective stickers on the lens and display.
Many times people move the camera while snapping the picture. Sometimes they don't even know they're moving until later.
Put the camera on a table or other stable, stationary object.
Point the camera at some large object at least five feet away and make sure no other close objects are in view.
If the camera has a timer mode, engage the timer mode and press the button to take a picture. Otherwise, hold the camera steady on whatever it's sitting on and press the button to take a picture.
If the picture is still blurry after a few attempts, then the check the camera lens to see if it's dirty. If it's clean, the camera probably needs to be serviced. If you have a product repair/protection or warranty from a retailer, check with the retailer on how to get it serviced. If not, check the manual and manufacturer's website to see how to get it serviced or repaired.
Was this helpful?
Yes
No
Solution #2
posted on Nov 08, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
An important thing to keep in mind is that compact cameras use contrast detection algorithm for automatic focusing. This means that if you try to take a picture of a low contrast subject, the camera will probably not focus properly - or (more likely) will focus where it finds the highest contrast, which in many cases will *not* be your subject.
Solution is to use contrast light (eg. sunset or dawn) or let the camera to focus where "it wants" and then, holding the button half-pressed, move closer or farther away to the "right" distance.
With higher resolution cameras (more than 6 Mp) shaking (apart of low contrast) is indeed a major cause of blurring - follow the advice of "bhiga" - or try to force the camera to use higher shutter speeds - this generally, means brighter light. For critical shots you may want to use multiple photo setting - eg. 3 or more in one "go". For 8 Mp and above - *always* use support - at least "ground" the camera or elbows onto something. In "normal" conditions no "shake reduction" will be of any help. Moreover, in many cases - such as eg. moving subjects or even windy conditions, shake reduction (even a proper one - with giro sensors) may ruin your photo - so use with caution and never count on it.
Alex
Popular Solutions for Digital Cameras
Questions and Unsolved Problems for Digital Cameras
Answer
looking for a nice compact camera to fit in my pocket but still have nice zoom thanks guys
Answer
What are the best compact cameras in the $200 range?
Answer
Do you know when I can sell my camera?
Answer
I am getting a lens error and then its says to restart camera..The lens is out and will not go back... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Digital Cameras:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 898
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
