Question about LG WM-2277HW Front Load Washer
Law Suit Can you let me know more on the Law Suit, I have this washer and I cannot get the awful smells out of our laundry. I have tried everything
  • acurtis May 08, 2008
    I have had the washer for a year and it has developed a very bad mildew odor inside. i'm using the correct he detergent and very small amounts. I've also added clorox to some loads and run empty washer with clorox to no avail. II've cleaned out the front filter at the bottom. I'm wondering if this is a health hazard. I need a solution, count me in.
  • adora May 09, 2008
    bad smell from washer also permiates clothes
    washer has stopped working has LE message flashing
  • 3 Answers
I heard also that if you were to put a bit of baking soda in the soap dispenser for the powder detergent, and replace the blue tub for the liquid that it will freshen the machine. No more bad smells
Posted on Jul 12, 2008
Also open the door after each use to air it out its just as same as a shower to avoid mold and etc like the smell just air it out after each use
Posted on Apr 29, 2008
  • 489 Answers
I don't know anything about a lawsuit with LG but the proper solution to this is to have a qualified LG tech disassemble the washer drum and tub assembly and wash it down with a garden hose.  Once it is cleaned out, the smell is gone.  To avoid the smell from returning, do not put more than 2 tablespoons of detergent per wash.  The reason is that the washer can produce excessive sudsing and line it throughout the tub.  The front load washer cannot rinse this excess suds off by itself and will in time, cause that nasty odor again.
Posted on Apr 27, 2008
Our laundry smells moldy since we bought cabrio several months ago. We've done everything we know to fix problem ,, but are not happy with the service of this machine or smell of our clothes at all!!
have you tried the super cleaner that works to clean just about everything--- vinegar
I dont know for sure if it affects several washers of that model but i have been a appliance tech for 30 years and haven't been to service that problem ever, the cabrio is what i have in my home and love it,cleans well without any foul smells
Jul 31, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Awful smell! I drain it every cycle, I use the washer cleaner, everything! I am so sick of my towels smelling awful.
Sounds like the little flexible apron just in front of your washer drum has mildewed. Take a look and see if it is holding water, and look for mold while your'e at it. Use a good bathroom mold and mildew remover to kill the mess and deodorize it.
Mar 24, 2010 | LG WM-2277HW Front Load Washer
The smell of my laundry
Try putting one more sheet in the dryer as far as the Tide with Downey it`s propbably getting rinsed out when your washer goes through the rinse cycle.
Feb 20, 2010 | Whirlpool Dryers
LG washing machine has AWFUL mildew smell
have you tryed a boil wash with nothing in the washer to soften and expel any caked powder in the drum?i know this does help
May 27, 2009 | LG WM-2277HW Front Load Washer
Musty smell
try following tips:
  1. Check that the drain line is clear
  2. Check the drain hose for kinks or blockages
  3. Check pump for blockages
  4. Check for build up of soap in the outer tub
  5. Check for article of clothing stuck in the outer tub
please rate my suggestion...
May 21, 2009 | GE WBSR3140DW Top Load Washer
LG TROMM - awful smell while washer is running
Use the aafesh tablets as instructed, this will clear hoses that have developed some mold, also inspect drain at the wall, these get moldy and as machine runs, smell comes out of there as well.
Jan 20, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Strong mold smell inside washer
Powder is tuff on a front loader, liquid is the way to go. One solution is to use a ratio of 2 Tbls of soap to 1 Tbls of softener as this machine uses 70% less water and this makes the solution of soap much stronger causing a build in the back bottom of the tub. Every one I have rebuilt has had to be scrapped out because of excess soap, liquid or powder. This stuff turns black and is awful. I usually use washer magic only and knowing that one use will not remove even 3 years of build up but is a process of reversing the junk. So I will by one from Walmart for about 4 bucks and pour the contents into the machine will empty of clothes and water and let it sit over night to start breaking the stuff down, then in the morning I will run hot water in the closet sink to the machine so when I start the cycle the water is hot. So after soaking you want hot water with a heavy agitation plus a second rinse and that will remove half of the junk. I usually do this every month on my top loader because of hard water and my clothes do smell much better for it
Sep 20, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Same problem and I was told to only use detergents with "HE" on the front of them for high energy. the soap without HE is too foamy and hence never truly drains out and causes a mildew smell. I also purchased something called "A" Fresh that I run in the washer every 6 weeks to keep the smell out. I got it at an appliance store for about $11.00 for 3 tablets
Sep 04, 2008 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer Logo
192 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
