Question about Philips DVDR980 DVD Recorder
DVDR980 DVD RECORDER
When i turn on the recorder it automatically locks u out and showsABFFCF2F on display
  • 1 more comment
  • olly08 Apr 06, 2008
    have tried turning it off from wall and leaving over night still same problem when i turn it back on in morning
    this problem has been reoccuring for the last few months i have turned dvd off and left it over night i have actually only plugged it back in this week hoping problem would have rectified itself with no joy
  • 796 Answers
Try to keep the recorder off for an hour
and then again turn it on
Posted on Apr 06, 2008
How to remove childlock
Hello
To unlock the receiver from child lock, Press '/Power ON button on the recorder. The recorder turns OFF and ' CHILD LOCK' appear on the display. The timer indicator remains lit if there is a timer setting. The recorder will not workexcept for timer recordings.
To unlock the recorder, Hold Down '/Power button on the front panel of the recorder itself, until the "CHILD LOCK" display disappears from the front panel display.
Mar 02, 2012 | Sony RDR-VX515 DVD Recorder/VCR
Tip
How to record a program you are watching on your cable satellite receiver.
Hello,<br /><br />Most of the time we watch TV programs with our cable satellite receiver/decoder. And sometimes we would love to record these programs so that we can watch them again. You can learn how to record your TV program while you watching a TV program. <br /><br />All you will be needing is a DVD recorder or VCR (Video cassette Recorder). It all depends on the one you prefer.<br /><br />There are two methods of doing this connection. 1. is RF connection and the other is RCA. But I will start with the RF connection method;<br /><br />This is how is works. Get a RF cord, check the back of your TV, you would see RF in, connect the RF into TV in, then connect the other part to RF Out at the back of the Cassette or DVD Recorder.<br /><br />Turn the Cassette or DVD Recorder and the TV on. Go to Channel 1 or any channel on the TV, search the TV stations automatically or manually in order to get a display of the Cassette or DVD Recorder on the TV. To easily get the Cassette or DVD Recorder's station, play a movie on the Cassette or DVD Recorder while you search for the station. Once you see the display of the movie on your TV, you would easily know that that's the Cassette or DVD Recorder station. <br /><br />Once you have gotten a display from the Cassette or DVD Recorder, save the channel on the TV.<br /><br />Then get another RF cord, connect it to "RF out" at the back of the Satellite/cable decoder/receiver and the other part to "RF in" at the back of the Cassette or DVD Recorder.<br /><br />Now with the Satellite/cable decoder/receiver turned on and the Cassette or DVD Recorder also turned on, press the Cassette or DVD Recorder's channel, you should find search. Scan for channel/stations on the Cassette or DVD Recorder just like you did on the TV and you will find a display of the Satellite/cable decoder/receiver showing on the TV via the Cassette or DVD Recorder. Note that on some Cassette or DVD Recorder, you will have to select "Source" to RF before you can get a display of the channel.<br /><br />Now since the Satellite/cable decoder/receiver program is now showing via the Satellite/cable decoder/receiver, insert a black disc or cassette into the Recoder and press record. The Satellite/cable decoder/receiver programs showing on the TV via the player will be recorded and that would be all.<br /><br />For some recorders that has internal hard drive, you can just press record without inserting a blank disc......<br /><br />USING RCA CONNECTION METHOD.<br /><br />You could also achieve this by using a RCA (yellow, red and white cord).<br /><br />The connection procedure is the same with the RF explained above.<br /><br />Connect the Recorder to the TV. That is, from "Video and audio Out" of the recorder to "video and audio in" of the TV accordingly. Press AV or source on the TV to confirm that there is a display from the recorder on the TV.<br /><br />Now connect the RCA cord to "OUT" from the Satellite/cable decoder/receiver to "IN" at the back of the Recorder.<br /><br />Then, press source on the recorder to "INPUT" (RCA) and the Satellite/cable decoder/receiver's program will automatically display on the TV. <br /><br />While the Program is being displayed on the TV via the recoder, insert a blank disc and press record on the player and it will automatically start recording. You will see the record or record symbol while the recoding is in progress.<br /><br />I hope you understand the above. Please follow steps closely and you won't have any problems.<br /><br />Good luck.
on Mar 09, 2011 | Televison & Video
Problems with Sony RDR-GX300 DVD Recorder....I HAVE THE ORIGINAL REMOTE FOR THIS UNIT AND IT WILL NOT CONTROL IT...BNUT WHEN I POINT IT AT A SONY T.V. IT WILL WORK ON THAT UNIT????
Try changing the "command mode" switch on bottom right corner of remote. Setting 3 is the default code. This setting must match the setting in the system setup menu.
Feb 20, 2010 | Sony RDR-GX300 DVD Recorder
My go video is locked. How do i unlock it?
You can unlock by pressing and holding the Power switch. Sometimes it will then allow you to eject the disk after it restarts, but not always.
Mar 08, 2009 | GoVideo VR3845 DVD Recorder/VCR
Lock message
Hi!
My DMR-ES10 appears since last month, the same message, and lets myself crazy!
Today, after a desperate try, pressing the buttons, I found the solution:
Simple press the POWER BUTTON and STOP BUTTON of the unit for a few seconds...
VOILá: The UNLOCK message appears in the display and the unit return to operate without the lock message !!!
For Lock again, press the same buttons at same way until appears the Lock message in the display.
This is an undocumented command...
I hope to help you!
Mar 25, 2008 | Panasonic DMR-ES10 DVD Recorder
Sanyo DVD RECORDER displaying "SAFE"
the "LOCK" feature disables the front panel buttons. Press "LOCK" on the remote control to LOCK/ULOCK.
Jan 18, 2008 | Sanyo DRW-1000 DVD Recorder/VCR
Panasonic DMR-EH75VS
On the EH50, you have to go into Setup Display Front Display and change it to Bright or Dim. Automatic turns it off when power is off
Jan 13, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Toshiba DVR recorder incorrect disk message
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}To reset the Toshiba D-VRX4 DVD/VHSrecorder you turn it on and press and hold the "channel up" and"play" button until you get a message that says, "initializingto factory settings.". When done the machine turns off automatically, and you turn it onagain. Every time mine has stopped working this has fixed it. This might work with yours as well.
Dec 03, 2007 | Toshiba D-VR4 DVD Recorder/VCR
Power on no response
Here is the link to the manual if you need it; http://www.p4c.philips.com/files/d/dvdr9... best i could come up with is: unplug machine, then plug it back in while holding down "open/close" and "stop" (Page 49) run through the diagnostics as explained on page 51. This link below gives you available drivers and updates, try updating/reinstalling the driver just in case it is a software issue; http://www.p4c.philips.com/cgi-bin/dcbin... If you still have no luck, please post again. Hope this helps :)
Mar 17, 2007 | Philips DVDR980 DVD Recorder
Here is the link to the manual if you need it; http://www.p4c.philips.com/files/d/dvdr980_051/dvdr980_051_dfu_eng.pdf best i could come up with is: unplug machine, then plug it back in while holding down "open/close" and "stop" (Page 49) run through the diagnostics as explained on page 51. This link below gives you available drivers and updates, try updating/reinstalling the driver just in case it is a software issue; http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=GB&slg=ENG&sct=DVD_RECORDERS_SU_GB_CONSUMER&cat=DVD_HOME_THEATER_CA_GB_CONSUMER&grp=HOME_ENTERTAINMENT_GR_GB_CONSUMER&session=20070317090311_81.47.146.201&ctn=DVDR980/051&mid=Link_Software&hlt=Link_Software If you still have no luck, please post again. Hope this helps :)
Philips DVDR980 DVD Recorder Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
