My computer will not recognise my philips external hard drive which plugs in via usb
    Genius:
  • 1,142 Answers
Does it recognise other devices..did it come along with any sofware that u need to install and haven't yet???
Posted on Apr 06, 2008
My toshiba external hard drive is not being recognised
This problem occurs when the external drive is removed from the computer before the host computer has finished writing to the drive. This can cause the drive to fail and require formatting. When using a plug in drive you need to allow the system write to complete before removing it. This goes for Flash memory sticks/cards and hard drives.Try restarting the computer with the external drive plugged in and switched on, this may cause the fault to be fixed. Good luck.
Aug 07, 2012 | Toshiba E05A100PBU3XS Canvio 1TB USB 3.0...
My WD external hard drive has suddenly stopped being recognised by my computer
Unplug the power supply from the hard drive, leave for 15 seconds.
Plug power supply back in.
Try another USB cable if that does not work.
Aug 08, 2011 | Western Digital Elements powered by WD 320...
My HP DV9740Us entertainment laptop will only recognize one external hard drive at a time! If i plug in another via usb it won't pick it up in My computer but the computer makes the sound as if it did...
If these drives are internally powered by the USB hub, two devices will not be recognised. ie: you can have as many pendrives as you like and they will be seen, because they draw little power from the hub, however, a larger external hard drive requires more power (some of these in fact have two usb connectors to power them). which is why your laptop will only recognise one drive at a time:
Solution: If you can get an externally powered usb drive, this should work.Another and possibly cheaper way would be to get an externally powered USB hub, which would solve the problem
Jul 28, 2011 | HP Pavilion DV9740US Laptop
Wd3200bmvs-11f9s0 not being recognised by any computer. do the jumper pulgs need to be bridged in any certain way
hello
do this and it should work : unplug the power and USB cords from the external WD drive
wait 20 seconds. plug the power cord into the drive (make sure the other end is plugged into the wall)
wait 20 seconds, plug the one end of the USB into the computer, and the other end into the WD external drive.
in a few seconds, your computer should see and activate the WD external drive.
thanks for using FIXYA -- please make sure to send me 4 thumbs up
May 10, 2011 | Western Digital Passport 320GB External...
Cannot get computer to recognize my simpletech external hard drive. I have windows 7
A problem I commonly have is if the external drive is plugged in to a non powered usb hub the unit does not have enough power and will not be recognised, ensure it is plugged directly into the pc tower or if you have a laptop try an alternate usb port as some may not be powered.
Mar 07, 2011 | SimpleTech SimpleDrive Pininfarina 500GB...
My external hard drive is not recognised by my computer, although it was recognised in the past.
Hi
Please can you try your external HDD in another PC, to rule out issues with the drive itslef
Please also try plugging the drive into a different USB port on the back of the PC
Please can i ask that you leave feedback and vote if this has been useful
Feb 11, 2010 | Iomega HDD External Desktop (32660) 80 GB...
I installed from original CD and my computer running Vista does not find maxtor ll external HD. Is it compatable with Vista? why does it not find the drive?
Start "Device Manager".
Make sure that the USB devices are "ready" and "enabled".
Then, connect the external USB device.
Can you try the Maxtor external device in some *OTHER* notebook?
If it does not work, then the Maxtor device has a problem.
Nov 08, 2009 | Maxtor OneTouch II external hard drive...
External Hard disc isnot recognized by PC
Dear Sir,
Here is the Procedure for Connecting External Drives to Computer.Several brands of computer does not recognise external drives when connected to USB expansion slots,and Slots of front panel,So connect your Ext HDD to back side onboard Slots.Because there is a lack off USB power surge voltage to detect a large capacity exteral drives.Some time it is does not recognise by many computers,when USB power surge voltage is low.
I think it helps,
If you find any difficulty post a feed back we were happy to assist you
have a nice day.
Good luck
Sep 17, 2009 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
WD320 GB 2.0 USB external hard drive is not working.
bad driver chip... call the manufacturer.. have the HDD changed...
Jul 09, 2009 | Western Digital Passport 320GB External...
I have seagate 500gb hard disk which is not recognised by win xp what should i do
If using USB try it on another USB port, if on eSATA then try using USB to see if it will detect it via usb
Have you got another computer you can try it one just to ensure that the hdd is actually working ?
May 25, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Computers & Internet Logo
David Payne
David Payne
