Question about Samsung SCX 4200 All-In-One Laser Printer
Printing is a problem
Hi Guys, lately anytime I print my paper has a thick line on the left side of my paper, I dont know what to do.
  • ymani76 Sep 24, 2008
    A thick broad line is being printed on the left side of the page every time I print and a water mark type image of the same stuff is printing in the middle of the page.
I dont know if this is related but here we go.
I work in IT and one of our HP printers were having the same problem as what you have described. After changing the fuser unit it stopped printing this line down the side of the page. I know the SCX-4200 has a fixed fuser as I have one at home, so if this is the case I would get in touch with Samsung or a local printer repair company
Posted on Jun 01, 2008
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 70 Answers
I think your cartridge is faulty,
Posted on Apr 30, 2008
SOURCE:
Printer is printing with horizontal blank lines
you did not indicate machine or how you are printing.
1- printing from glass or doc feeder?
did you check the small scanning glass on left side?
usually if there is a dot (pen dot or similar) it will come out as a line on docs, this is because the paper is moving while scanning, so it now sees the dot a s a line. Line up the paper w the glass you should see where the problem is comong from.
Sep 06, 2012 | Office Equipment & Supplies
Line through print
Perhaps did not specify paper thickness (check control panel and print driver).
Toner getting low.
Clean registration roller with clean damp cloth.
Aug 17, 2012 | Ricoh Aficio SP C811DN Laser Printer
I've had the printer for about 18 months with no problems. I need to print envelopes for the first time, and can't figure out how to do it. Any help out there?
Load the envelope against the right side of the back paper tray.
Load with the address side facing UP and the rear flaps DOWN on the left.
Pinch the Paper Guide and slide it against the left side of the envelope.
Set the Paper Thickness Lever to the right, return to the left after finishing printing.
The Paper Thickness Lever is located inside where the paper come out of printing.
Specify the settingin the printer driver.
Select Envelope in Media Type
Select DL Env. or #10 Env.
Select Landscape in Orientation.
Jan 18, 2011 | Canon PIXMA MP470 All-in-One Printer
My HP 1320 prints a thick black line down the left side of each page of a document.
Easiest step to do would be replace your toner.
Next Step is 1/2 self test page. This means start a print job and after the paper is picked up open the toner cartridge door and cause a jam. The paper that you see after you remove the toner will show the current print. If the mark is seen on the paper there then it is the toner cart. If you dont see it on the paper then it is most likely your fuser causing the issue.
Jul 27, 2009 | Office Equipment & Supplies
Will not print and keep getting paper thickness error
Did you try moving the paper thickness lever (blue lever on top of the print cartridge holder)? It should be all the way to the left when you start--if it needs to be adjusted the printer message will let you know.
Jun 27, 2009 | Canon i850 InkJet Photo Printer
Epson Stylus Pro 4800 Never Before Seen Banding Problem
Clean the nozzles, align the print heads, turn it off for about an hour. You may need to do this twice, but it works for me.
May 26, 2009 | Epson Stylus Pro 4800 InkJet Printer
Ghosting on prints
Wrong paper type can cause this, also if it is damp or too thick. Also check that you have the correct type of paper (thickness) selected in the driver. Ghosting can also be caused by a faulty drum unit, since you just replaced it maybe there is warranty left on it?.
May 24, 2009 | Brother HL 5140 Laser Printer
Postcard printing
You should find the proper setting under the "Layout" tab of the printer properties. Check the box "Cpombination" and from there you can select "2-IN-1". Make sure you use the bypass tray and select the appropriate thick paper for the weight. Lining up side 1 with side 2 is not guaranteed with paper above 210 g/m2 (thick 3) Hope this helps.
Aug 29, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Is there any debris under the printhead nozzle plate?
Jun 22, 2008 | Epson Stylus Pro 4800 InkJet Printer
Konica Minolta Magicolor 2430DL--black line on right side of paper
Sry but you have to change drum cartridge, the line is caused form drums cleaning system, and it cant be repaired.
Oct 18, 2007 | Konica Minolta magicolor 2430 DL Laser...
Samsung SCX 4200 All-In-One Laser Printer Logo
109 people viewed this question
Top Samsung Office Equipment & Supplies Experts
jasbo
jasbo
Steve Allison
Steve Allison
Lawrence Singapore
Level 1 Expert
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
