Question about Asko W6461 Front Load Washer
Asko W6461 - will not drain
We have an Asko 6461 washing machine that is 5 years old. Today it has decided to stop at the first drain and refil.
The machine makes a loud humming noise and then switches off showing F3. We have checked the manual which says it is a water outlet fault.
We have checked that no objects are trapped and run the machine on spin with the drain undone, and water flows freely.
Any suggestions greatfully received
  • Anonymous May 15, 2009
    Thanks to the wonder of the internet and discovering this useful advice, my husband has now fixed the same problem with our machine. Many thanks!
Thanks for the suggestion.
Having taken the machine out and the back off I removed the pump end with impeller which bless the Swedish was very simple. The outlet pipe appeared to have no hole being completely blocked.
A hard push of the index finger moved the object that finally turned out to be a UK 5p piece. The diameters are exactly the same with the 5p acting as a complete blank.
Removed the 5p, put the machine back and problem solved.
Posted on Apr 09, 2008
    Sergeant:
  • 351 Answers
Is the pump comming on look inside the pump with a tourch there may be somthing stuck behind the impeller
My Asko W6461 spins a great deal of vibration. I have tried to use smaller loads to stop it but it continues. Could it need releveling?
The "inside" of the machine should move pretty much during wash and spin, but if the whole machine is vibrating alot, it could be a levelling problem. Could also be a problem with the shock absorbers, but that is rather uncommon:)
Oct 08, 2013 | Asko Washing Machines
Machine is not spinning
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
May 03, 2011 | Asko W6461 Front Load Washer
Who do you set timer on asko 6461 washer?
the timer you are trying to set is for a delay start. so if you set the timer for 1 hr, the machine will start 1 hr later.
Feb 05, 2011 | Asko W6461 Front Load Washer
Hello, I have an ASKO Washer model W6461 and I notcied a puddle (1/2 cup) under the front right part of the machine after running it once. How do i get the service manual for this machine so i can...
you may find the leak coming from the door seal or the soap drawer while it is filling,if you leen the machine back you will find two T20 screws under the front.you can get the book from asko.com.au
Jun 15, 2010 | Asko W6461 Front Load Washer
Asko washing machine won't drain.
Further on to this F3 problem I had the issue on model W6461. There is a short cut to the fix, instead of taking off the grey pipe from the drain pump (the hose clips are pre crimped in the factory so as stated above are difficult to remove) try this.
Stages as follows:
1) Open drain pump door (bottom left of machine).
2) Remove black pipe and drain residual water.
3) Unscrew coin trap and remove, use a container to hold the water.
4) Leave the container underneath and make sure you have some towels ready (I didn't at the time)
5) Where the washing machine drain hose connects to the outlet or U bend connector remove this and expose the end.
6) Blow into the drain hose as hard as possible......hopefully the blockage will clear through back the coin trap.
Result:
A large lump of sludge, three of my 5 year olds small counter coins and about a litre of water.
Just ran the machine now and fault cleared.
Good luck
Jurgo
Apr 30, 2010 | Asko W660
Need new stabilizer clip/bolts for ASKO washer model W6461
Don't need those bolts except for shipping the washer. They were supposed to have been removed a long time ago.
Sep 18, 2009 | Asko W6461 Front Load Washer
My Asko 6461 washing machine - F3 code
F3 problem, I had the issue on model W6461, however, judging by the amount of F3 issues posted this could work on other ASKO models If the coin trap in the drain is clear of debris, try this. Stages as follows:
5) Where the washing machine drain hose connects to the outlet in the wall or U bend connector remove this and expose the end.
6) Blow into the drain hose as hard as possible......hopefully the blockage will clear back through the coin trap.
7) Pour some water into the open end and blow this back through the drain as well.
Result:
A large lump of sludge, three of my 5 year olds small counter coins and about a litre of water (all over the floor, don't forget the towels!)
Good luck
Jurgo
Jun 15, 2009 | Asko W6461 Front Load Washer
ASKO 1605
Hi Guys
My dishwasher this morning has desided to not work correctly.
Its a ASKO 1302 about 20 years old. It has been a very good machine.
Over the last couple of weeks during the washing cycle, the dishwasher has been making a loader noise than usual.
1. Today, the dishwasher timer, travels all the way through its cycle, but very little washing take place.
2. Soap power is still there, plates not clean!!!!
3. Water is hot
4. At the end of the cycle, there is no water in the dishwasher.
5. I'm thinking the problem could be the pump needs replacing.
What do you think?
Greg
Sep 05, 2008 | Asko 1375 Dishwasher
F3 error
CHeck outlet filter, and draining system. Seems to be something that is stuck in the pump.
Feb 06, 2008 | Asko W6461 Front Load Washer
Asko front load washing machine
ring the asko service number on the inside of your door,1300 002756 ask for spare parts
Dec 15, 2007 | Asko W6461 Front Load Washer
Asko W6461 Front Load Washer Logo
462 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
