Question about HP Compaq Presario V2000 Notebook
Wireless connection lost
I have a HP laptop and I seem to have lost my wireless internet connection. I already restarted my modem and contacted my cable provider. It seems that my wireless thing in my computer is no longer there?
  • 655 Answers
Wirless and modem systems both are different, there is no connection between them.
If you were using your modem for internet access then you should chek-out your modem and phone-lines etc. Wirless will not effect.
verify your modem driver is installed correctly and check the settings.
Thanks
Iqbal
Posted on Apr 06, 2008
Earlier today I was connected to the internet fine. I stepped away from my computer for a little bit and now it doesn't connect to the internet. The wireless adapter is showing that it is connected to...
Here are some troubleshooting steps that you can do so you can isolate whether the problem is with the router , the modem or your pc.
1. Disable / enable the wireless connectivity in your laptop.2. Restart the laptop. Then check if it is working. If not, go to the next step.
3. Restart your modem and router by unplugging the power cord on the back of the devices. Wait for the devices to load, then check if it is working. If not, proceed to the next step.
4. Try connecting your laptop to the modem directly by using an ethernet cable. If it did work, the problem is with the router. Its best to call the manufacturer of your wireless router if that's the case.
5. If step 5 still didnt work when you already connected your laptop directly to the modem, the problem is with the modem itself. Call your internet service provider and they'll do troubleshooting steps on their end too.
Hope this was helpful! Have a great day.
May 27, 2011 | Netopia 3-D Reach (TER/GUSB-N1)...
Hello, I have Dell Inspiron 1525 Laptop and wireless Internet doesn't connect. I see the wifi light is ON and I see in Internet connection it shows my profile as connected. But if i browse internet does...
Please connect your computer directly to your DSL / Cable modem and check if your internet is working fine, if not turn off your modem and restart after a minute or two.
Now check again if the internet is working by directly connecting your laptop to your modem. if it is not working, contact ISP. if it is working, turn on your router and check if your wireless connection is working.
If you wireless connection is still not working, please check if you have plugged the modem to the internet / WAN port behind your router.
Also try logging to your router page (refer to manual for procedure) and try changing the wireless channel.
Dec 24, 2010 | Dell Inspiron 1525 Laptop
For no reason, my HP laptop stopped working the internet. It works perfectly otherwise. I hard connected the laptop directly to my wirelessouter as well as my modem, still it will not connect to internet.
Connectivity issues can be many.
I would start my first rebooting the main modem.
Once that is up, reboot the wireless router.
Once that is uo, reboot the laptop.
Try to connect.
If that does not work, eliminate the wireless router and connect the laptop directly to the modem via Ethernet cable and reboot the computer again and see if it works. If it does, then it is something with the wireless router. If it doesn't, i would contact the provider so they can verify that they can see your modem on their network. If they cannot, they will advise you further (hardware/cabling issue). This is all assuming that nothing has been changed on any settings of the laptop, router or modem.
Jul 21, 2010 | HP Pavilion dv6000z Notebook
Lost the internet connection on my laptop that worked before (Linksys wrt310n)
first check if you have internet with the modem if yes then you'll need to reconfigure the router. Contact router's manufacturer to assist you how to set it up.
Sep 14, 2009 | Linksys WRT300N Wireless Router
Router connection fail
do you have internet with the modem? if you do then router is not configure correctly. If you do nothave internet ask you ISP why you are not online with the modem directly.
Sep 11, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Modem is not working
the fact that the computer and modem are not in contact with each other, means that we really don't know that the modem is not connected to the internet. i'll assume you've tried all lan ports on the modem.
did you attempt a connection with another computer? another modem?
Mar 31, 2009 | NetGear DG824M Wireless ADSL Modem Gateway...
Wireless printer stopped printing-wireless router light flashing
Restart your Printer so that it can Look for the Connection again, if you havent done this already.
If this doesnt assist in the problem, please give me the complete Model Number for your printer so i can find the solution
Jan 14, 2009 | NetGear WGT624 Wireless Router
Internet connection light
Help & Support has everything that's in the owner's Guide. Just ask it.
Top left button, above the keyboard, is Wireless On/Off.
If nothing happens, go to CONTROL PANEL / NETWORK CONNECTIONS. R-click on Wireless Network Connection. L-click DISABLE. Wait about 5 seconds, do it again and L-click ENABLE. That should reset the modem and get things going.
After you establish an internet connection, go to START / PROGRAMS / HP / HP (SOFTWARE) UPDATES and install the latest patches. They will include aa newer version of HP Wireless Assistant
Good luck.
Jul 11, 2008 | HP Compaq Presario V5000Z Notebook
HP Compaq Presario V2000 Notebook Logo
140 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
