Question about HP Compaq Presario V2000 Notebook
Power cord for my HP laptop
The power cord for my laptop shorted and burned the end of the cord off near where it plugs into the laptop. Not sure what happened or why. My question is, would buying a new power cord be sufficient or do you think there is something wrong with the laptop that caused it. I'd hate to buy a new cord and then have it happen again. Should I have the laptop checked out first?
Thanks
    Problem Solver:
  • 8 Answers
It all depends on the value 2 u of the puter
mostly the power cords r damaged do to misuse droping stuff on them ect........
however this can be tested w/o buying a new cord
try temporarily splicing the cord together however alwase supervise ur splice if the laptop continues 2 function treat ur next cord better
Posted on Apr 06, 2008
Have acer one message says to plug into ac adapter
Check the AC adapter and power cord. It sounds as if either one end of the cord near the transformer box is loose, or the end that plugs into the computer is loose/not connecting properly.
Failing that, make sure the wall socket you have the cord plugged into has power (try plugging something else into it). If everything I mentioned checks out, there could be something wrong with your battery.
Mar 23, 2012 | Acer Aspire One D255 Netbook
Nc6400 no power on
What kind of adapter did you buy? Did it come with 5 - 10 different tips that you try on the end of the power cord until you find one that will fit into your laptop? If so, no wonder you're having problems, those things will burn your board out. AC Adapters have different power requirements (watts) If you have one that has changeable tips, but the watts are constant, you're asking for trouble. Stay away from those one size fits all Ac Adapter Power Cords
Mar 22, 2012 | HP Compaq nc6400 Notebook
The power inpot is blinking and not connecting
The laptop is either in sleep mode or the battery is low. If the laptop doesn't want to wake up, try unplugging the charger cord, then removing the battery (usually by sliding something on the bottom of the laptop to unhook it). Wait for 30 seconds then put the battery back in, plug in the charger and press the power button.
Mar 05, 2011 | HP ProBook 4510s FM849UT Notebook
My HP 9730US will not power up. When I plug the power supply in, the light goes off. The power cord works and is on another computer right now.
try without battery. if not work check the some burning smell near battery connector on laptop back.
the thing is all the dv xxxx models have AC power controller chip burning problem .have a possible to repair that, if not need to repleace the main board.
Dec 05, 2010 | HP Pavilion dv9730us Notebook
The refrigerator keeps blowing the main electric to the whole house
Case Short Circuit in the machine. Please check the power cord, the plug and the connection at the end. Check for any loose/broken wire connections. Also Are you getting any burning smell near the machine when the fuse blows up, If so then wiring in the compressor is short circuited. You have to call a technician as you may not be having tools to check the short circuit.
Sep 16, 2010 | GE Refrigerators
I hav a hp nx6120 but doesnt switch and wen you plug in the charger its no lighting
Take a look at the back of the laptop. Is the gold power pin still there or is it now stuck in in the end of the power brick cord?
HP actually extended the wty on these machines because of the
power pin issues. If the power pin is missing you will need to have the machine serviced. Out of wty, replacement power pins are easy to solder on the board if this is the issue.
If your pin is still there... Your AC cord or power brick may be the next things to check. Connecting them to a meter will tell you if there is power. Try moving the cords to check for shorts in the wires.
If your AC cord and brick are good, try pulling the battery. Your laptop can run off AC only. Batteries with bad cells can sometimes prevent the machine from powering up.
If its still not powering up after all of that, there may be an issue with the motherboard in the machine.
Feb 27, 2010 | HP Compaq nc6120 Notebook
My HP PAillion ze2000 PC Notebook will not charge
I had this problem with my laptop and the way to solve it is.... guess!!
Get a new power cord!!
Dec 31, 2009 | HP Pavilion ze2000 Notebook
My 4520 Acer Laptop will not charge and will not work on AC power alone.......
You First need to test your AC Adapter Cord...
You can test if you have a secondary known working one.. plug that one in to see if same issue occurs.. OR you will need to test the AC Adapter using a multimeter (available at any home improvement store for under $7).. When testing the Plug End on the AC Adapter - Hold The Negative Test Prod Of the Multimeter to the Outer Side Of the Plug Tip, and Put The Positive(red) Test Prod Inside The Plug Tip... See If You Have Power Through The AC Adapter Tip... You Might Need To Slightly Wiggle The Cord Near The Tip End To See If THere Is A Short In The Cord....
If Cord Tests Good....
You Will Need To Replace The Laptops DC Jack...
The DC Jack is the port where your AC Adapter Plugs into on the laptop..
Your Faulty DC Jack Would Need to be desoldered, the motherboard cleaned of all old flux, Re-Tin The Contact Pads and then Resolder a New DC Jack Onto The Motherboard...
Nov 16, 2009 | Acer Aspire 4520-5582 Notebook
No power when cord is plugged in
A possible short on the power input plug at laptop end
Sep 07, 2009 | Dell Latitude D600 Notebook
I am not sure I have the correct cable to connect the HP 2110 to my pc. Where do I plug the cord in?
Do you have a USB cable?
The flat end plugs into a USB port on your computer.
The squarish end plugs into the printer. In the back, If I remember correctly, near where the power plugs in.
Hope this helps.
Jun 23, 2009 | HP PSC 2110 Color Printer
HP Compaq Presario V2000 Notebook Logo
138 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
