Question about GE WBSE3120B Top Load Washer
GE Washer stuck on final spin cycle
Hi any ideas how to solve the GE top loader washer that stays in Final Spin mode? would unplugging it and plugging it back in work?
When i start my washer it stays on the spin cycle
any tips on what might be the problem
Posted on Sep 10, 2010
Mine is also stuck on spin, but unplugging has not helped???
Posted on Aug 11, 2010
  • worshamkim Sep 13, 2010
    Thanks alot . SO far so good
Thank you so much for this information. It worked like a charm. Problem having: Would not come out of the final spin mode. I just unplugged it and plugged it back in as the experts stated and so far so good.
Posted on Feb 24, 2010
Thanks for the suggestion. I was about to pay to get my answer online until I saw the suggestion to unplug and wait. After replugging it did not correct right away. I allowed washer to shut down from the continuous spinning after I replugged. It did and now works like a charm! Thanks again
Posted on May 12, 2012
My GE Prodigy just did the same thing the other day and I just unplugged it and plugged it back in and so far so good.
Posted on Apr 08, 2008
4 Suggested Answers
  • 239 Answers
SOURCE: GE WJSE4150B1WW Model top load problem
It sounds like the timer must have went bad or has a loose connection, If I understand you correctly its stuck in the spin mode. and won't go to rinse or wash cycle, Is that what you are saying, If so Maybe the start button got pushed in to hard or pulled out to hard. If It don't work let me know so we can work on something else so we can get it fixed for you, Happy Holidays bear001
Posted on Dec 14, 2007
  • 5 Answers
SOURCE: My washer wont do the final Fast Spin
http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
Do this - I had the same problem and this fixed it. It takes about 10 minutes.
Posted on Oct 31, 2008
heatman101
  • 43501 Answers
SOURCE: GE top load Profile washer. Spin cycle not
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on Jun 12, 2010
Why does a Kenmore washer not finish the cycle?
Washer Repair - Not Advancing -Repair & Diagnostic ...
? 8:30
https://www.youtube.com/watch?v=IEr9A7uhdN8
Sep 6, 2013 - Uploaded by ApplianceVideo.com
Repair your Kenmore Top Load Washer suffering from these following issues: Will Not Advance Past Rinse ...
Kenmore washer doesn't complete final spin cycle - ApplianceBlog
www.applianceblog.com/.../31894-Kenmore-washer-doesn-t-complete-fi...
May 16, 2012 - 9 posts - ‎2 authors hello, my kenmore washer doesn't complete the final spin cycle. i ... Does it stop in the middle of the final spin cycle or does it not go into the ... FIXED Kenmore Washer - Not finishing the spin cycle
Dec 20, 2014
FIXED Washing Machine Does Not Complete Cycle ...
Mar 14, 2013
FIXED Kenmore washer won't spin out all water from ...
Jun 27, 2009
FIXED GE front load washer WCVH6260F0WW stops ...
Jul 2, 2007
More results from www.applianceblog.com
Nov 05, 2015 | Kenmore Washing Machines
Kenmore front loader stops/freezes in pump out mode just before final spin
For a detailed Washing Machine illustration, click below.
redarrow.gif Top Load Maytag Style
redarrow.gif Top Load Whirlpool Style
redarrow.gif Top Load GE Style
redarrow.gif Front Load Maytag Style
redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
Aug 01, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washer tumbler does not spin in final stage
hi sounds like the gearbox has slipped a cog and stuck that will cause the belt to burn
Nov 01, 2011 | Frigidaire FEX831CS Top Load Stacked...
No rinse, no drain, no final spin
I assume this is a top loader, check the lid switch, you should hear it "click" when the lid is lifted. If no click the switch is broken.
Dec 20, 2009 | Kenmore Washing Machines
I want the washer to fill it up but it goes to final spin
Is it a front loader or top loader? It almost sounds like a front. If so, you have a malfunction in your control panel. You will have to have GE do a test on the circuitry to verify that that's what it is. But if it's a top loader, it most likely has a mechanical timer. If THIS is the case, there's a chance that someone tried to do a second final spin then interupted it before it was done and threw the cycle off. My parents had a HOTPOINT that did that. Just set the timer to the desired starting point, and let it run from there to the end (UNINTERUPTED). This will reset it. Any more problems, let us know.
Dec 16, 2009 | GE Washing Machines
Model 110 washer will not go into a final high speed spin.
hi, i would suggest the timer/programmer is faultyas it is ok on the other cycles, the noises you have described may have caused some damage,
Feb 10, 2009 | Washing Machines
Spin cycle not removing enough water from clothes
your manual states that it can be caused by cold rinses and or spin cycle not getting completed. please try to rinse in hot or warm and see if that does not solve your problem
Dec 20, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
GE Adora front load washer overloaded now won't start
Washers - Resetting Electronic Controls on a Washer
If there is a pause in the washer cycle, the controls will lock up. The pause can occur because of a power failure or it was put in the test mode at the factory.
Also, if the washer was stopped before the cycle was complete or the consumer has pushed the stop/pause button to temporarily stop the cycle and the cycle is not reset. Over a period of 24 hours, the washer will pump out and spin, but will stay in the final spin.
To correct the situation, shut off the circuit breaker for 30 seconds or unplug the washer, then turn the timer knob around and back to any position other than final spin. Verify the water is turned on and restore power. This should resolve the issue.
Apr 23, 2008 | GE WSXH208A Front Load Washer
Dec 13, 2007 | GE WBSE3120B Top Load Washer
GE WBSE3120B Top Load Washer Logo
3,330 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
