Question about 2wire 2700HG-B Router (2700HGB)
2Wire 1701hg gateway- Broadband Access problem
recently, the "Broadband Access" light on our 2Wire router turned into a lovely shade of red, and we lost the ability to connect to the internet. We tried reinstalling the software, but to no avail. We had an identical model sitting around, so we set up that one in the old one's place. The broadband access light is now green, but we still cannot connect to the internet on any computer, including the one directly attached to the router.
So obviously we are not techs, and we are trying to narrow down what the problem may be. Someone suggested that the WAN settings may need to be changed in order to make the new one work. How would this be done, and is this the solution? Any suggestion would be awesome. Thanks!
    Scholar:
  • 53 Answers
Hi! have you used this other identical 2wire modem before? if this other 2wire modem (is it the same 1701hg?) well you may need to configure the settings first. also 1000 series modems usually have 3 lights on it; power, broadband link, and local network. if these 3 lights are on, you may need to access the modem's user interface. assuming that all lights are green, on your computer directly attached to the 2wire, open up any browser, type in gateway.2wire.net. it will give you the network at a glance page. click on run system setup wizard, type in the system password. on the ppp authentication page, please check if it has your username & password (this is the one that you set up on your internet acct w/ your ISP), the next screen will establish a connection. (please tell me if you've got any error messages...)
Posted on Apr 08, 2008
I want to install a 1701HG gateway to my computer but after I installed I dont have access to the internet? what I have to do to make it work?
check first if you computer communicate with router, from router it can communicate with hub (internet provider) and check if your ip range act as router or a bridge.
Apr 10, 2010 | 2wire (1000-400108-001) Router
Broadband yellow light
I'd hate to say this but the 1701 was abandoned and buried a long time ago :( 2Wire was no longer supporting it when Arris bought them out and Arris will just tell you time for a new one. Even electronics with non-moving parts eventually wear out. If you're renting the 1701 time to buy a replacement and save those monthly fees (typical payoff is 10 months or so). Your ISP will have a list of compatible modems, although you might have to deal directly with their customer service to put a new gateway on your line.
Mar 24, 2017 | Computers & Internet
Set up wireless internet access using HG1701 2wire router
Check with this tip
Detail on this Wlan Router
"Connect power cord to router.
Wall Plate -> Router (using phone cord).
Router -> PC (using network cable).
  1. Power on router, when the lights settle, start the PC.
  2. Start IE in PC, type 192.168.1.254 in the address bar and press enter.
  3. Start configuring using the Telco's suplied info, namely PPPoE username and password. All other function works by default.
  4. The WEP key is the 10 digit number underneath the router (not the 12 digits S/N number).
Jan 18, 2009 | 2wire Wireless-G 802.11g ADSL Gateway
yellow light on broadband keps on flashing , and my phone has a clicking noise
Jan 08, 2009 | 2wire 1800HG Router (RG1800HG00)
Install 2wire 1701hg without installation CD
I have the same modem.
You don't need any installation cd.
Just follow the instructions at this web page:
http://support.2wire.com/?page=view&article=60
Nov 04, 2008 | 2wire (1000-400108-001) Router
Help please
please go here to find the solution to your issue from the 2wire.com website.
http://www.2wire.com/index.php?p=268
Aug 02, 2008 | 2wire (1000-400108-001) Router
Router wont work
Have you tried resetting the router by pressing and holding down on the reset button.
Try unplugging it and wait 20 seconds to plug it back in.
Jun 12, 2008 | 2wire 2700HG-B Router (2700HGB)
Replaced my old 2wire 1800HG with a new one and can't connect it
hi!
first of all, let's try to make the broadband link light turn green. open any browser, go the modem's UI by typing gateway.2wire.net or homeportal/setup on the address bar, follow the onscreen instructions on running the system setup wizard. it should make the broadband link green now. for wireless connection, click on the airport icon, and select on the SSID or network name in the drop down menu. if ssid is not on the drop down menu, click on other. type the SSID in the network name field and wireless security is none. (SSID is the last 3 nos. of the SN)
Apr 22, 2008 | 2wire 1800HG Router (RG1800HG00)
2wire 1701HG Gateway Router VPN Setup
Go to http://gateway.2wire.net and click on the firewall icon. Click on firewall settings and, if prompted, enter your system password to reach the advanced settings page. select the computer that will function as the VPN server. In the left column, select PPTP server. click on Add, then done. or try changing the IP scheme to the 172.16.0.0/255.255.0.0 or 10.0.0.0/255.255.0.0 schemes by accessing gateway.2wire.net, go to home network icon, then advanced settings. but if you manually configure or disable dhcp, be sure to write down the subnet mask & IP assigned to the 2wire then click on save. if all else fails, run it on DMZPlus mode, however this solution will allow all inbound traffic to the computer. if it still doesn't work on DMZPlus mode, the VPN is either using the same IP scheme, is using IPSec 50 or 51, or will not work with the 2Wire gateway.
Jan 30, 2008 | 2wire (1000-400108-001) Router
Wireless router
What is the make and model of your router?
What type of internet access do you have (DSL or cable)?
Are you connecting the computer with a cable or via wireless?
If you have verified that the cable connections are correct then I would try to power cycle next.
1. Unplug the modem, router and turn off the computer.
2. Plug the modem in and wait 5 minutes.
3. Plug the router back in.
4. Turn the computer back on.
Let me know the details for the above questions if we need to go further.
Dec 27, 2007 | 2wire Wireless-G 802.11g ADSL Gateway
2wire 2700HG-B Router (2700HGB) Logo
1,169 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
