Question about RCA D61W20 61" Rear Projection Television
RCA D61W20 Image Turns on and Off, Rat Droppings
Hi, every one, im just trying to find whats going wrong with my TV, just to make sure im not paying a lot to my repair guy.
The image on the TV starts to go on and off and sometimes it goes off and doesnt come back for a while. but the image comes back after a while. During all of this the sound stays on.
Also whenever a turn it on when it was off for a long time I have to wait a while until the image appears, i can see the green light on and the sound stays on but the picture is off and on.
Please if anyone can help me out i will sure appreciate it, my email is [email protected]
I went ahead and open the TV and i found rat droppings and urine on the main board and near the DVI chip, try to clean them and it work fine for a few days, but now suddlenly the screen went red and blury and shut itself off, i unpleged like 3 times and stil made the same error, until i tried to switch the signal input, that made the image come again slowly when i was switching from input sources, you know, from DVI to Com 1 then Com 2.
The problem its not showing up right now, but after all this my TV is showing a light blue/greenish stain on the center of the screen, and sometimes the image is going on and off.
    Sergeant:
    Champion:
  • 301 Answers
Im sure that the rodent contamination is the root cause of your problem. but the blueish stain does it look like a smear? if you that is most likely a phosphur burn in the face if the CRT. it cannot be fixed without replacing the CRT. i suggest living with it or putting tv on the side of the curb.
Posted on Apr 10, 2008
SOURCE:
I've replaced cp150 cp120 cp114 capacitors and now it turns on for about 2 - 3 min and then turns off what else could it be? rca d61w20
It could be the flyback transformer or several other items all on the deflection board. Were any of the caps you replaced domed up on top?
Jun 18, 2011 | RCA D61W20 61" Rear Projection Television
I have the d61w20 rca tv and it will not turn on, whqt could be causing this
i have been a tech for 26 yrs now i have seen so many postings on here about bulging caps and so on but there is only 1 thing to do our workshop has 18000 dollars in test equipment alone there is a great reason for this the amount of vereables that can go wrong with nano electronics there is no easy fix to this problem it needs to be seen by a certified electronics tech this is your best chance of having this tv fixed correctly im not putting down other techs on this site but some things we can fix by computer network some we cant imagine even if this tv was in my workshop right now it would take us over an hour just to find and fix the cause
i hope this helps you sir/mam
sonic boom electronics australia pty ltd.
managing director
Jan 02, 2011 | RCA D61W20 61" Rear Projection Television
The tv i have is a RCA D61W20 and it will not come on . the power light goes on and off three times and nothing
Problem with main deflection board,bad electrolytic capacitors/Hi voltage circuit has bad connections,common to those RCA tv's.
Mar 22, 2010 | RCA D61W20 61" Rear Projection Television
61" RCA Projection TV Model #: d61w20
You could have shorted Yoke and if so you have to replace all 3 yokes another thing that can cause this is Capacitors on Deflection board cp150,cp114,cp120 If cp150 2200uf 16v is puffed up on top then it is bad ,so replace all 3 caps other 2 are 220uf 35v.
Jan 02, 2009 | RCA D61W20 61" Rear Projection Television
D61W20 RCA TV 1080i image problem
Theres most sistem pal/ntsc not a set of this menu seting www.wehot.biz
Jun 06, 2008 | RCA D61W20 61" Rear Projection Television
sounds solder related. I would guess the vertical output IC or flyback needs resoldering, As the vertical will shutdown the picture if the solder looses contact, and the flyback feeds the filament voltages to light the tubes. Solder repair is usually the cause when you lose picture but have sound.
Apr 05, 2008 | RCA D61W20 61" Rear Projection Television
RCA D61W20 61" Rear Projection Television Logo
100 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
