Question about Bradley BTST02 - Stainless Steel Smoker
Biscuit advance I have had my Bradley BTST02 for about 2 years. It has worked fine until now ... but today the mechanism that advances the wood biscuits is doing it continuously ... not just every 20 minutes or so. Is thewre something I can do myself to correct this ? If not can you tell me where I can get it repaired in Toronto, Ontario, Canada ? Thanks, in advance, for your help ... Charlie Macfarlane ... charlie.macfarlane@sympatico.ca
  • Charlie Macfarlane Apr 07, 2008
    Thanks Alex. I actually did smoke with it ... and just popped the biscuits in one at a time ... and that was alot of work too. I'll call the company about the timer unit ... Charlie
  • 32 Answers
Contact the company to see if the timer unit can be purchsed to replace yourself or if the whole drive has to be replaced. not sure if its battery operated, but if it is , to make do for now you can start everything up , pop out the battery and pop it back in as you need to.....lot of work but you'll be smokin' at least.........
Posted on Apr 07, 2008
Wood chips won't advance
You said, "wood chips won't advance." That may be the problem, the Bradley Smoker doesn't use wood chips. It uses a manufactured wood chip biscuit, that looks like a small hockey puck. These will feed automatically when the smoker calls for them. Loose wood chips won't.
Mar 19, 2011 | Bradley BTST02 - Stainless Steel Smoker
My Royal Alpha 2001 typewriter has been unused for years. I turned it on recently and it worked fine except it would not paper advance with the return button. How do I get the paper to line advance?...
Hi!
I'm going out on a limb here.
I assume the carriage returns but the line does not advance. Close?
- There is a setting for the linespacing which is either 0 (zero), or 1, or 1 1/2 or 2
Likely, this has been inadvertently moved.
- Also, there is a way of disengaging the linespace mechanism to allow typing to be made on unevenly space forms. This might have been moved.
Please feel free to contact me anytime.
Feb 13, 2011 | Royal Office Equipment & Supplies
My carousel tray will not advance. I was looking at slides (the unit has not been used in 10 yrs) and everything was working fine. Then the unit stopped advancing the slide tray. I have lost the owners...
I'm assuming you are talking about a Kodak Slide Projector. If this is so, and it hasn't been used in at least 10 years, then it is probably an earlier-produced model. If the fan & lamp work and just the slides don't advance, then chances are you have a broken solenoid "link". This "link" joins the Cycle Solenoid and the Slide Change Mechanism together. As the projector ages, the link (made of plastic) gets hard, brittle & cracks. This will, in literally one slide change, make the projector go from working to not working.
Parts are still available (www.micro-tools.com), but this repair should not be tackled by the untrained. I recommend you contact a factory-trained dealer to make the repair.
Dec 20, 2010 | Office Equipment & Supplies
Why can't we get smoke out of the Mastercraft smoker. We have tried it at 120 no smoke, 130 degrees it smoked for a bit. we have opened up the vents half way & changed to smaller chips. Now what (the...
On Master Craft Smokers, you need to put the wood chip in when you first turn it on. The heating element will be on trying to bring up the temperature and will start burning the wood. Also open the vents all the way to get the element to turn on more often. 130degrees is very low for smoking anything. Most meat needs to be 170 on the inside to be considered done. Try cranking the temp at the beginning and turning it down after that. After the first couple hours the meat should be considered smoked, then it just needs to cook.
Aug 28, 2009 | Grilling
Player froze up
do a reset and if you can do a cleanup
Feb 22, 2008 | Creative Labs ZEN Vision:M Digital Media...
Film advance lever
Your camera is cocked but since the shutter is not working you cannot release it and hence your film advance mechanism does not work. ME-super will work without batteries in full manual mode so set your shutter to B and try to release it. If the shutter will not release in B mode then the shutter/mirror box will need servicing : rubber components in the mirror box mechanism have perished and need replacing. After that your camera will be fine for another couple of years.
Sep 18, 2007 | Pentax ME Super 35mm SLR Camera
Bradley BTST02 - Stainless Steel Smoker Logo
527 people viewed this question
Top Bradley Grilling Experts
Oloyede Monsuru
ray gallant
Tom Chichester
Are you a Bradley Grilling Expert? Answer questions, earn points and help others
