Question about E-Machines eMachines Desktop PC
My hard drive is not being noticed - E-Machines eMachines Desktop PC
  • Dwayne Stewart May 11, 2010
    Is this a brand new hard drive that you have just installed?
    Scholar:
  • 59 Answers
You need to provide more info, what kind of PC is it in, what OS, is the drive showing up in the BIOS at all, what brand of HD is it, is it going in as a slave drive or master, are you going to boot from it, IDE or sata. if its ide check the jumper settings and IDE chain location you want a slave drive(middle of the ribbon cable) then the jumper has to be set to slave, some PC's will not accept cable select, so avoid it when possible, if its at the end of the ribbon cable it needs to be set to master, make sure your bios is seeing the drive correctly, make sure the ide ribbon has a red line down the side closest to the molex power connector otherwise its upside down which can cause the pc to not see any devices (even if this happens with a cd-rom etc thats on ide) make sure the connector is not backwards on the motherboard, if its sata then make sure data and power cables are tight and sats is enabled in the bios. also any error messages you get would be useful. are you referring to the drive you boot from, then it may have failed, if it is a new drive and you are running windows 2000 or xp then it may need formated, same issue occurred with my new sata drive it didn't show in windows until i opened computer management >disk management and formated it to ntfs (windows xpsp2). vista will probably be the same way, however if you have vista upgrade to xp your pc will run faster and more stable, also if your running vista then the computer management tolls, well I'm not sure exactly where they are, I don't use it much, only when i get a pc in at work with it, and usually its to replace vista with XP.
Posted on Apr 06, 2008
My Toshiba px1394u-3g50 external hard drive is not working, light flashing and not recognised
Try connecting the hard drive to some other laptop and see if its getting recognized. Issue could be either with the hard drive itself of it could be with the usb port which you are using to connect the hard drive to your laptop.
Jan 17, 2012 | Computers & Internet
I have a western digital WD1600 WD Caviar SE Serial ATA Hard Drive in my Desktop PC. Yesterday i noticed a loud clicking when i started up, and shut down my PC. Now today when i started my computer i got a...
better to replaced the hard drive, co'z once you heard a loud sound on it, that means that the drive is now having a physical damage, if you the hard drive still working, it will not stay longer due to physical damage inside of the hard drive.
Aug 30, 2011 | Western Digital Caviar WD1600 (1600YD) 160...
System says there is no hard drive. error code 0142 says hard drive error
This is what the manual says:
Replacing the Hard Drive caution.gif CAUTION: Before working inside your computer, read the safety information that shipped with your computer. For additional safety best practices information, see the Regulatory Compliance Homepage at www.dell.com/regulatory_compliance. notice.gif NOTICE: Hard drives are extremely fragile. Exercise care when handling the hard drive. notice.gif NOTICE: Use firm and even pressure to slide the hard drive into place. Excessive force may result in damage to the connector. This procedure assumes that you have completed the removal procedure Removing the Hard Drive.
  1. Slide the hard drive into the hard drive connector until the drive is fully seated.
  2. Replace the hard drive cover aligning the notches.
  3. Replace the two M2.5 x 8-mm screws to secure the cover.
  4. Install the operating system for your computer, as needed. For information on reinstalling the operating system, see the Setup and Quick Reference Guide for your computer on support.dell.com.
  5. Install the drivers and utilities for your computer, as needed. For information on reinstalling drivers and utilities, see the Setup and Quick Reference Guide for your computer on support.dell.com.
I would say that was a bit harsh and this is what I would do.
Insert your System disk and install a fresh system. During the installation, Windows should be clever enough to detect and format the drive.
If you remove the drive and with a caddy you could try to repair the system with another pc but you may get problems.
Hope this helps.
Nov 04, 2010 | Dell Vostro 2510 Laptop
How to remove my hard drive hp pavilion dv1000
Please follow these steps.
1) First of all, first unplug the power and also remove the battery.
2) Flip over your laptop. Make sure that when you are looking at the laptop bottom that the battery slot is located on the top portion.
3) On the lower right portion is the hard drive bay. You would notice two small screws on its left side. Loosen them up.
4) Lift the left side up and swing it to the right and remove the cover.
5) You would then notice a plastic or mylar tab on the left side lift the hard drive using that tab.
6) Slide the hard drive towards the left and it will be removed from the hard drive bay.
And that is it. That is how you remove your hard drive.
May 02, 2010 | HP Pavilion dv1000 Notebook
IBM Thinkpad A31 2652 wont switch on
This is bad news, the smell you have noticed from the ThinkPad is most likely caused by an electrical short in the power circuit and the cost of repair would not be a cost effective solution, a replacement motherboard may not be available because of the age of this model ThinkPad.
You maybe able to retrieve your data from the hard drive by removing the hard drive and connect to an USB hard drive adapter then connect it to a working computer's USB port. This computer will see this drive as an external USB hard drive and you can copy the data off this hard drive.
Feb 28, 2010 | IBM ThinkPad A31 Notebook
Gateway laptop - whirring, buzzing sound
if it's a continuous whirring sound it is most likely the cooling fan. this is normal. as the computer gets older this will get noticably louder as the fan has to run faster to prevent overheating.
Aug 14, 2009 | Gateway Computers & Internet
Larger Hard Drive in DRC8030N
Yes you can replace the hard drive with a larger one. I have a 500 gig hard drive in mine. You can do the same thing with the DVD drive.
Any more problems, contact me at bigsteve1962@excite.com
Feb 26, 2009 | RCA DRC8030N
Hard disk wear and tear
reinstalling a operating system is unlikely to wear your hard-drive out faster than noticeable, and virus's don't damage hard-drives unless they are causing the hard-drive to overwork thus wearing it out faster
Jan 29, 2009 | Western Digital My Book Essential Edition...
Partision prblem
This is because an 80GB hard drive only has 75GB inside it will not be exact because of the way hard drive manufacturers compute the size. 80GB by name but only 75GB in real hard drive space. much like a if you have a flash drive or a portable uSB you will notice this also.
Dec 27, 2008 | Seagate Barracuda 7200.7 ST380011A 80 GB...
E-Machines eMachines Desktop PC Logo
26 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
