Whats mean when my printer show me,thefollowing ink tank cannot berecognized,and what I have to do
    Problem Solver:
  • 5 Answers
First of all unplug the power to the printer. Use a cotton swab with denatured alcohol and clean the contacts of the ink tank and the mating contacts on the printer. Wait for the contacts to dry and then install the tank and turn on the printer.
If the tank ran dry before refilling, it may have fried the internal contacts.
Posted on Apr 06, 2008
Wat tank full mp 520
Hi Guy,
I believe that what you mean is 'Waste Ink Tank Is Full' error on Canon MP520.
To fix this problem, first you need to reset waste ink counter of the printer then you should replace the ink absorber with new one.
In order to reset waster ink counter properly, you can read complete procedure how to reset waste ink counter of the printer below:
How To Reset Waste Ink Counter Canon MP520 Multi Function Printer
May 07, 2014 | Canon MP520 All-In-One InkJet Photo...
Ink indicator lights
It's mean "ink out". Not actually "inK", but ink level counter reached zero. If using original ink tank, just replace with new one. If using "hardware resetter", reset ink level counter. If using CIS ink tank, it will be auto reset.
Remember, it's program not actual ink. So, if you reset it, ink level will show full, even if you didn't refill ink tank.
Oct 01, 2013 | Epson Stylus C43SX InkJet Printer
Canon Pixma 9000 pro flash 14 times
Hello, this is what your error means: Ink tank not recognized [1684]
A non-supported ink tank is installed (the ink tank LED is turned off). Install the supported ink tanks, check that the chips on the cartridges are clean.
Oct 07, 2012 | Canon Uv Ink Refillable Cartridges For...
What is the mean of ink absorber full
This is when your printer estimates that the waste ink tank in the bottom of your printer is full. If does this by keeping track of the amount of prints and cleans it has performed. In most instances you will be able to do many more prints before the tank is physically full and you can reset the counter with a simple procedure.
We have written an article and produced a short video showing how to reset the counter here. It is pretty simple and only takes a few minutes.
Sep 14, 2012 | Brother DCP-J125 Inkjet Multifunction...
Status bar keeps showing 'check ink tank'
the ink tank could be empty or wrongly installed. Try a new ink tank or re-install the one you have.
Mar 27, 2010 | Canon PIXMA MP130 All-In-One InkJet...
I have a message showing bk tank - code
Its detecting an incorrect ink tank.
The printer is not happy with one of your tanks. Make sure you have PB inks if it is a PG printer.
More probably the job you are printing requires the other black ink tank. Very important to make sure your status monitor is installed correctly, make sure when you send a job that it displays the ink tank levels and not question marks. You should be able to find out roughly how much ink is left through the driver (status monitor) and also what type of black is installed. If you cant, you have not got the 'Status Monitor' installed.
Mar 09, 2010 | Canon imagePROGRAF W6400 InkJet Printer
Showing Check Ink U051 COL. Have removed the
Hi there
For troubleshooting purposes,
Perform the following:
1. Open the printer and remove all ink tanks.
2. Insert a single ink tank in the printer then close the cover.
3. Confirm whether the printer recognizes the installed tank
properly. If it does, it will indicate it does not detect the other ink tanks, as
they are not currently installed in the printer.
4. Repeat steps 1-3 with another ink tank.
5. If the printer at any time indicates two of the same ink tanks are
installed, the cause will be the last tank installed. For example, if
you inserted an ink tank earlier, and you later inserted another ink
tank, and it said two of the same inks were installed, the cause of
the issue is the last ink tank.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 10, 2010 | Canon PIXMA MX310 All-In-One Printer
ERROR 6502
Error 6502 (Ink tank position sensor error) the sensor is receiving too much light. Possible causes are:
1. The printer cover is open and the sensor is exposed to the light
2. The ink tank LEDs are busted
3. Sensor or its wire connection to the logic board is busted or disconnected
1. Close the printer cover
2. Possible ink tank replacement
3. Change sensor or repair disconnected wires
Sep 25, 2009 | Canon PIXMA MP830 All-In-One InkJet...
I have a problem with my printer epson stylus C90. may i know what todo when parts of my printer are near the end of their life service.?how can i fix it?
It means waste ink pad full or nearly full. Reset waste ink counter using SSC ver 4.30. Find at Don' forget to replace pad, washing or extend outlite pipe to outside of printer.
Jul 23, 2009 | Epson Office Equipment & Supplies
If ink absorber is already full what should i do next?
it is not possible for you it is the problem mantainence wast tank full it mean when we print then chack cartridge is automacily clean then some ink fall under pad this pad is full ink then machine say ink absorber tank is full
you go to aservice centre only support printer canon. Thy clean wast tank and reset your printer
Jul 05, 2009 | Canon PIXMA MP150 All-In-One InkJet...
