Question about Maytag Atlantis MDE7400AY Electric Dryer
Banging noise When my dryer is on it has a banging noise almost like somethiong inside the dryer his hitting when it spins. I remove all cloths and spin and I hear the same sound. One bang per revolution.
  • 2 more comments
  • jemmadallas Apr 14, 2008
    When I start the dryer, I immediately hear a banging noise and it continues throughout the cycle. The sound seems to be coming from the back in the top left corner. It works fine but is very noisy
  • maryglitz Apr 17, 2008
    I have the same problem. At first, I though there was something hitting inside the dryer, like a snap or button, or mayber there was a coin in the dryer. But the dryer makes the same noise with nothing in it. It does sound like it's coming from the back of the dryer. Would love to know what it's all about.
  • Anonymous Jun 02, 2008
    Interestingly enough, about a week after I posted my message about the
    banging noise, it suddenly stopped. I had scheduled an appointment with
    a repairman for later in the week, so I'm glad it stopped before he
    made the house call. I haven't heard a noise since.
    Maryglitz
  • Anonymous Aug 05, 2008
    same probelm.. side of dryer , on left toward back top portion. Bangs 1 x per rev. without clothes in it. What to do ? thanks
  • 525 Answers
You may have had a foreign object slip under a loose drum baffle. Manually rotate the drum to locate wwhich baffle it is in.
Posted on Jun 02, 2008
I had a year old Maytag Neptune dryer that began making banging noises like there were rocks in it. When I looked, I noticed a crack in the seam of the drum. It had cracked, and when the drum spun around, it was spinning unevenly, causing the banging noises. Luckily my husband bought the extended warranty, and Maytag wound up replacing the entire drum. Now it works beautifully. You may want to check for any cracks. The drum is one piece of metal, welded together at the ends.
Why is my tumble dryer making a loud banging noise when on its a white knight model CL3A
Most of the time a tumble dryer will work like a dream but, as with all appliances, occasionally there will be technical problems.
If your tumble dryer is making a banging, whining (or other strange noise) it's best to diagnose and sort out the problem. It could be the result of a number of things, but what you certainly don't want to do is ignore it.
Here are the most common reasons for your tumble dryer making odd noises.
Coins and keys
One of the most common reasons for a banging, rattling or clanking is keys or coins left in pockets - so always check them before you put any clothes in the tumble dryer. More often than not you won't hear anything until the dryer cycle is in full spin.
Uneven surfaces
If the dryer is vibrating or shaking during spinning, check to make sure the dryer's sitting on a level surface. If it's fitted with height adjusters on the front legs, adjust them accordingly to ensure the machine is level as this will often reduce or eliminate the banging sound.
Drum bearings
If the tumble dryer is noisy when its turning and the whole appliance is shaking and rumbling, it could be indicative of a problem with the drum bearings, which help the wheels turn freely and easily.
The drum
If the banging noise is continuous when the drum is turning then it might be problem with the drum itself. If the noise is a metallic one, it could be the result of the drum scraping on something inside the machine. You could always check the drum visually for any marks or dents.
Motor bearings
If the tumble dryer is emitting a high-pitched screaming or whining noise it could be a sign that the motor bearings are wearing out.
Tension pulley wheels
If there's a squeaking noise coming from the dryer it could be the result of wear on the tension pulley wheels. This occurs more frequently on older models...or try this link..
Common Tumble Dryer Problems
Dec 09, 2016 | Dryers
Why does my front loader make a banging noise while spinning?
Ive checked thru the top and back cant notice anythin brohen but when i do spin tbe tub the banging noice is coming from in tbe drum and its pretty wobbley
Aug 28, 2015 | Washing Machines
When drying clothes, there is a loud banging noise, almost like if the clasp to overalls is hitting the inside of the dryer. Right now I am drying towels, so there is nothing metal or hard that could be...
Check all exposed screws, and make sure they are tight. Loose cabinet screws may cause a banging sound. Make sure nothing is loose inside the drum. Remove the lint trap and look below the lint trap holder for any loose items that may have slipped through the cracks.
Check to see if the drum is supported on wheels or rollers. Sometimes these can wear and require replacement.
Good luck and have a nice day
Jul 03, 2010 | Maytag Atlantis MDE6400AY Electric Dryer
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
Banging noise during spin cycle
weight not distabuted in washer move cloths around so its even
Feb 10, 2010 | Washing Machines
Washer sounds like off balance during spin
old duets have nut on rear pulley that becomes loose. remove rear panel and tighten nut. check while spinning by hand if pop is felt. if it rotates smoothly then you may need new shocks on tub
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Makes a loud banging sound when spinning clothes
check springs and shock absorber.try to put more laundry.
Feb 16, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Banging noise as dryer spins, wore hole in side of dryer
I need to know your make and model number in order to give proper advice. Joe
Nov 07, 2008 | Maytag Neptune MDE5500AY Electric Dryer
White knight tumble dryer making banging noises when spinning
I have this banging problem, it sounds like a plastic ball rolling about inside it
Aug 25, 2008 | Dryers
Maytag Atlantis MDE7400AY Electric Dryer Logo
1,576 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
