Question about Pioneer DEH-P790BT
Display Please help me with info. on how to stop my Pioneer DEH P790bt from switching display background from dark to light every minute or so. This is very annoying. Thanks Todd
    Problem Solver:
Go into your tools menu by pressing the center of the multi knob.(the volume control knob) turn same knob to bring up the entertainment field, press center of knob to set then turn till you get to the prompt about alternating screen. switch to no. done.
Posted on Nov 05, 2008
SOURCE:
Pioneer deh p790bt display only works when open and goes out when faceplate is closed. everything works but no display.
The ribbon cable is bad. This is easily repairable. I think Best Buy still does them or call your local electronics repair shop.
Oct 11, 2013 | Pioneer DEH-P790BT
Pioneer DEH-11 how do I set the clock
1. Switch the source OFF.
2. Enter the Time setting mode.Hold ^ button for 2 seconds
3. Select "Hour" or "Minute"
with the 2/3 buttons.
4. Set as desired time with the
5/° buttons.
As soon as you switch to "Minute", the seconds start counting from 00.
5. Cancel the Time setting mode.
Note:
• Holding down the AUDIO button for 2 seconds also cancels the Time setting mode.
• To turn the time display ON.
The time display disappears temporarily when you perform another operation, but the time
indication returns to the display after 25 seconds.
Note:
• When the sources are OFF, the Time appears on the display. Pressing the CLOCK button switches
the Time display ON/OFF.
Thank You.
Mar 21, 2011 | Pioneer DEH-1100 CD Player
Set time on Pioneer DEH-P4400
Press FUNCTION to select the time.
Press FUNCTION until the time appears in the
display.
2 Select the portion of the time display you
wish to set with 2/3.
Pressing 2/3 will select a portion of the clock
display:
HOUR-MINUTE
As you select portions of the clock display the
portion selected will blink.
3 Select the correct time with 5/?.
Pressing 5 will increase the selected hour or
minute. Pressing ? will decrease the selected
hour or minute.
http://www.generalmanual.com/Players/Pioneer-DEH-P4400-Single-CD-Player.htm
Dec 06, 2010 | Pioneer DEH-P440 CD Player
Display flashing on my deh-p6500
It has what is called reverse mode which flashes to protect the display to turn feature off please follow these steps.
Press the 5 numbered button when power to this unit is turned off while the ignition switch is set to acc or on will cancel the reverse mode and stop the flashing. Hope this helps.
Jan 06, 2010 | Pioneer DEH-P6500 CD Player
Pioneer DEH-14 display not lighting up...... help?
The display only lights up when correctly wired to the lighting system.
Jan 11, 2018 | Pioneer DEH-14 CD Player
How to turn off alternating display.
turn off the unit and push the entertainment button or the display button it will beep once flashing stops lol i had the same problome im not sure what button it is thought doesent hurt to try them all its the second one on the bottom of the unit under the display but the unit has to be off
Feb 17, 2008 | Pioneer DEH-P80MP CD Player
Connecting XM radio to my unit.
You have to tell your XM radio receiver what station to send the FM signal then you tune your radio to that station. Thats how my model worked when i used it.
Feb 01, 2008 | Pioneer DEH-P790BT
Need help with wiring a pioneer deh-5
You do not have the entire Pioneer model number listed, so I cannot provide you with the wiring info for it.
Bu here is the wiring info for your jeep.
Constant 12V+ Pink/Yellow  Switched 12V+ Red/White  Ground Black  Illumination Orange/Brown  Dimmer Black/Light Blue  Antenna Right Front  Front Speakers 6 1/2" Doors Left Front (+) Dark Green  Left Front (-) Brown/Red  Right Front (+) Purple  Right Front (-) Dark Blue/Red  Rear Speakers 5 1/4" Roof Mount Left Rear (+) Brown/Yellow  Left Rear (-) Brown/Light Blue  Right Rear (+) Dark Blue/White  Right Rear (-) Dark Blue/Orange **from the12volt.com
Best of Luck.
Oct 31, 2007 | Alpine CDM-7874 CD Player
Time set
How to change the time on a Pioneer DEH 1500 car stereo:
With the radio off, select the 'clock' (upper left button) to display the time.
Press and hold the 'audio' (upper right button) until the time display blinks.
Use the 'select' buttons to select the hour or minutes and adjust time (right button selects minute digits, left button selects hour digit, up button increases the time, bottom button decreases time). Comment by dognut, posted on Dec 25, 2007 Just a further comment posted by dognut:
After setting the desired time, 'press any
Oct 25, 2007 | Pioneer DEH-1500 CD Player
Pioneer DEH-P790BT Logo
146 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
xxxxxx xxx
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
