Question about Compaq Presario 700 470024-192 Notebook
The presario 700 is failing to boot up.
I installed a new harddrive on the machine as some had prescribed that the had drive was gone but it still boots by it self to some stage and then it shuts off . I did install anothe harddrive and as i was loading the operating system it shut off after about 10 minutes and some says it could be over heating due to a dead battery. Is this possible?
  • deanhelp Apr 08, 2008
    its the same problem. kind of. my paper wait boots up to the compaq screen then shuts off.....help....
  • 520 Answers
Its possible but unlikely.
startup from disk(cd) in first screen choose install windows.in next screen when previous os is found choose install new.
in next screen delete partition then create new partition then format partition and install.
if u have a problem installing after that then ur hd has bad sectors.
if this is the case let me know and can u software to solve it.
the precedure Ive mentioned usually does the trick even with bad sectors unless there are too many bad sectors.
Posted on Apr 08, 2008
Hp presario f700/f750us, cd/dvd player, won't boot from start up but is listed first in boot order, not recognized by windows either, won't read, write or play. tray opens and light blinks. tom...
Check the jumper settings in the back of the drive, by the power cable. Make sure your cd/dvd drive is set to SLAVE, with your primary harddrive as MASTER. Check BIOS settings, specifically your boot order, choose which drive you want to load first (usually HD 0), save and exit.
That's just the basics, though.
Another possibility is that you might just have a paperweight ;)
If so, try another drive.
Hope that helps
Cheers from NZ
May 17, 2011 | Compaq Presario 700 Series DVD-Rom Drive...
My laptop won't boot! What should I do?
No power? Blue Screen Of Death? Blinking cursor? Black screen?
Need more info.
For anything other than a BSOD or error message:
Try unplugging from power, remove the battery, hold the power button 30 seconds. Then reinstall battery, plug in, and turn on.
If you are getting something like 'NTLDR not found' or 'Boot Sector not found', Hard disk blah blah blah etc. you might need a new hard drive or to repair errors on your existing one.
For BSOD, try starting in safe mode. If that fails, try using a bootable antivirus disk to remove any viruses or other junk and reboot.
Reply back with more info or results!
Apr 24, 2010 | Compaq Presario 700 470024-192 Notebook
No complete starting
Unmountable boot volume means your harddrive has gone out.You will have to get a new one and load your os again.Sorry:-(
Apr 08, 2010 | HP Compaq Presario C502US Notebook
Ctrl+Alt+Del to restart error
Is it a black screen right when you boot your computer? If so this could be a fatal disk error and the harddrive has crashed.
There is no easy fix other than to replace the harddrive.
Oct 05, 2009 | Compaq Presario 700 470024-192 Notebook
Compaq Windows XP Home Edition Presario 700 Startup>Start Windows normally>Windows could not start because the following problem is missing or corrupt:WindowsSystem gaoem.fon I don't have a disk...
compaq has a restore directory on the drive
turn on computer boot in safe with command promp
type in restore it should boot
failing that insert original floppy and it will ask you to pick an option '
Jul 31, 2009 | Compaq Presario 700 470024-192 Notebook
My Presario 700 freezes up at random times
sounds like the following
Virus
Spyware
Devices or drivers are conflicting.
Hard Drive is failing
Step one
Disconnect the computer from the internet.
If this is the problem it is more than likley a virus or spyware
If it still freezes proceed to step 2
Step 2
Restart Computer in safe mode, do not connect to the internet.
To restart the computer in safemode turn on computer and press F8 continuosly until a screen of options comes up.
Select Safemode without networking
If computer still freezes up proceed to step 3.
For windows XP
Locate the My Computer Icon and open it. Locate Local Disk C: Or whatever harddrive that has windows installed
RIGHT Click it. It will then open a menu of options, select properties. At the top select tools tab. Click the check now button.
A new window will pop up, check both boxes and press start.
Another window will pop up select yes and restart the computer. Do not press anything and let it work.
Considering the age of you computer it is probably the hard drive in which case should only cost about $45 for another one. search for a harddrive that fits your model on ebay or another trusted site.
It is not very difficult to change the hard drive so dont panic.
Mar 06, 2009 | Compaq Presario 700 470024-192 Notebook
Presario will not stay on and error message appears
Sounds like your harddrive controller on the motherboard has failed.Boot into the bios and see if the harddisk is reconnised if not (which i am sure it is not) the you need a new motherboard ,sorry!
Dec 15, 2008 | Compaq Presario 700 470024-192 Notebook
Computer wont boot after installing toshiba hard drive
You need to format and re install the O.S. system to your new harddisk before you can use it . If you installed already an operating system you can check if the booting setup in the bios is set to harddrive boot maybe the booting is set to cd device
May 30, 2008 | Compaq Presario Notebook
Compaq Presario 700 470024-192 Notebook Logo
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
