Question about Rinnai Toyostove Direct Vent Heater: Laser 30 Toyostove Direct Vent Heater Shipping
Laser 56 small explostion
Ee-2-,reset button-,burner on,off,on.three times and back to ee-2.burner off,manual cl-10 and 5minutes later small explostion.I think the compartment on top expanded.white smoke for a few minutes.I,m on electric heat now and will take toyo out. Do you think it's dead?Jeff in Homer Ak
    Novelist:
  • 126 Answers
Jeff,
Step away form the heater for a moment. All that button pushing got you in trouble. You caused the heater to have a back fire. If you think the "compartment" expanded you are probably correct. You may have blown the heat exchanger and if this is the case don't operate the unit. The heater will go through a cycle each time you push the burner button. It could take as much as 12 minutes for the cycle to complete. The stove may be down but not dead. If the heat exchanger is blown you will need a new one. Once that is on you will probably be good.
Tom Hawkins, Bethel AK
hawkins111@gci.net
Posted on Jan 06, 2009
    Scholar:
    New Friend:
  • 70 Answers
I don't think it is dead. I would have a service tech come out and look at it. The igniter sounds like it's not working properly.What kind of fuel are you useing
Posted on Apr 24, 2008
I have a toyostove laser 56 that blowback exhaust during windy days. Is there an easy fix? Tom
Three times recently I got the EE 2 error. Each time gunk had built up where the tube goes into the firebox. A delicate scraping with a wire solved the problem. Now, what causes the gunk to build up?
Feb 27, 2011 | Rinnai Toyostove Direct Vent Heater: Laser...
I let my tank empty before refueling and now my toyo laser 56 has a ee 2 error on it how can i fix this?
You should check the filter at your oil barrel if you have one there and loosen the small vent screw to bleed the filter and line. You can also check the strainer in the fuel sump but remember to turn off the fuel at the barrel before removing the strainer from the sump. Also press the float reset button on the full sump. You can loosen but not remove the fuel line on the back of the heater if needed to get the fuel flowing. Be sure to place something under it to catch the kerosene and have some rags handy.
Jan 03, 2011 | Rinnai Toyostove Direct Vent Heater: Laser...
You may have an air bubble in the fuel line or the filter (if you have one at the fuel barrel) may be clogged. The filter has a vent screw on top and you may need to vent the filter to get the fuel flowing. There is also a strainer in the fuel sump that may have gotten clogged.
Another thing is to push the red float reset button on the right side of the heater. If the float is latched up you will feel a little resistance and hear the float drop. Only press the reset button momentarily. It is not a primer button.
You can get a bowl and some rags to set under the line where it connects to the back of the heater and then loosen the line to make sure you are getting kerosene to the heater.
The fuel pump makes a loud ticking or thumping sound if it isn't getting any fuel.
Let me know if this helps or you need more advice.
Nov 20, 2010 | Rinnai Toyostove Direct Vent Heater:...
I have a toyostove laser 30 kerosine heater which was displaying an EE 8 message, a repairman came and replaced the blower moto, and it started running agina, but now is showing an EE 13 message which the...
EE13 is for the burner thermister, not the thermostat. It prevents the burner from overheating. It does not reset after it has opened an will need to be replaced. Perform a resistance check on the thermistor. It should be less than 200k ohms after preheating. If it isn't, replace the thermistor. If it is the problem could be the circuit board. Hope this helps. Let me know if you need more assistance. nitensheaterservice@earthlink.net
Oct 26, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
Heater keeps shuting down and displaying EE 6
Check for air leaks in the fuel line. Push the red reset button only once. It's usually a fuel problem. Contamination, air, mixed fuel.
Nov 26, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Toyostove laser 56 error code CL02
The CL means that it is in the automatic clean cycle. The 02 means that it has 2 minutes left. It will automatically do this at 2:00 AM. If you don't have the clock set it will do it whenever it thinks it's 2:00 AM.
Nov 05, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Laser 56 code E22 after slight banging noise upon trying to ignit
You have a fuel problem. The ticking sound is the pump starving for fuel. It's either low fuel, no fuel or dirty filters. It's an easy fix.
Tom Hawkins
Bethel, Alaska
May 14, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Laser 56 EE6
EE 6 happens for several reasons. Most likely in your case when the stove runs for a while after you turn it back on, the code is due to and over heat. The circulating fan and cover need to be spotless. If they are then the code is due to low fuel, no fuel or dirty filte on tankor stove.
Tom Hawkins
Bethel, Alaska
hawkins111@gci.net
Jan 09, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Toyostove Laser 30 has error code EE 22
EE-22 means that the unit has tried three times to ignite. after this it goes into a "lockout" condition. remove the power and the computer will reset itself. it will then try to re-ignite. check for a fuel blockage, dirty filter etc. if there's water in your kerosene it will not fire! kerosene floats on top of water. bleed your system until you get kero and no water. use a gas additive to remove water. dry-gas will work. just empty the bottle's contents into your tank. on your computer type in toyostove error codes. this will take you to toyo's site and explains the error codes.
Oct 20, 2007 | Rinnai Toyostove Direct Vent Heater: Laser...
Rinnai Toyostove Direct Vent Heater: Laser 30 Toyostove Direct Vent Heater Shipping Logo
170 people viewed this question
Top Rinnai Heating & Cooling Experts
paulcarew
blender719
Level 1 Expert
Kenneth Wilson
Kenneth Wilson
Level 1 Expert
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
