My computer keeps shutting down after it has been on for a while. this just started. What could be the problem and is there a fix for this?
I just recently had this happen to myself....CPU FAN Died... Computer had a start up message about Fan not working, seems like an easy thing to fix even for someone who does not know about computer.
Posted on Apr 24, 2008
    Genius:
  • 1,142 Answers
Sure there is a fix..can u tell me that does ur system heat up also along with the shutting down problwm..it can be an issue with the cpu fan
Posted on Apr 06, 2008
The shutdown window keeps coming up and my computer shuts down
you have a virus, scan your pc with nod32, you can download from www.nod32.com
Sergio
Mar 22, 2008 | Computers & Internet
To shut down computer i have to keep power button pressed
use the start menu, click it to open it, you will see shut down button there, if you rest your curser on it it will give you different options
Mar 07, 2013 | Computers & Internet
Computer keeps shutting down
This problem is due to the following:
  • Your computer is overheating
  • Critical problems with your registry
  • Critical state of the system files
  • Hard disk data cable and power cord are loose
  • RAM is not properly connected
  • Problem with the SMPS connections
For fixing computer automatically shuts down issue, you shall remove the motherboard and reconnect all the connections. Take help of a hardware expert while doing the task.
The solution to fix computer automatically shuts down is to download and run a good and reputed Registry Cleaner software, use RegInOut to fix this problem.
Sep 16, 2011 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Hi, My Samsung R580 I3 JBB2-US keeps on shutting down. If I close the lid when I re-open it shuts down & I have to restart or it freezes and I have to force restart. Sometimes when I boot up it...
You can try go to Start - Control Panel - Power Options and check what you want computer do when you close the lid of your laptop. Fix that and restart laptop to apply the setting.
If the boot up not complete and restart by itself, in my opinon, there is something wrong on the start up process, could be hardware malfuctions, could be a software not compatible. Try check the start up process to see.(use Start- Run: msconfig)
If this happen often, you should call the Samsung customer services to find out. Laptop i3 should still under warranty.
Hope this will help.
Thanks for reading
Jul 20, 2011 | Samsung R580 Notebook
It shuts down about a minute after you start it the acer aspire one
canning computer to eliminate malwares, spywares and the viruses from your laptop.
2- Repairing and cleaning Windows registry.
These two tips are found to be very helpful to fix the laptop shutdown problem. Almost all the computer users surf internet which could result in viruses attacking your system. Some of these infections are really pesky and cause the machines to shutdown randomly.
The registry errors, however, are the internal errors and can become a cause of system crashes and freezes. The registry keys shall be in good health to keep a system perfect.
When I noticed my laptop keeps shutting down everytime, I tested the Intel Software Partner, RegInOut to fix the random shutdown problem with my laptop.
Sep 19, 2010 | Acer Aspire One Netbook 8.9" Notebook
My computer is shutting down on its own. Is this
Scanning computer to eliminate malwares, spywares and the viruses from your laptop.
May 15, 2010 | Dell Dimension 3000 PC Desktop
Shuts down going down the road shuts off completely
vehicle shuts down while driving down road and does not start backup for at least 20 minutes, could be a bad crank sensor. if bad it will start and run fine, but it will keep shutting down until fixed.
May 16, 2010 | 1997 Nissan Pathfinder
Fan doesn't shut off ever
I just did a BIOS update on my sisters computer presario f700 and noticed that the update said it would fix some problem with the fan. The update is on Compaq's website under software and drivers. Maybe that would help.
Feb 13, 2010 | Compaq Presario 700 470024-192 Notebook
Car keeps shutting off
After extensive research I have found that in 10 out of ten cases it was the E.C.M or in other words the computer for the vehicle is faulty. You can thank dodge for this problem. What happens is they put a Temperature sensitive device in an area that gets unbelievably hot. Then the Computer overheats and shuts down. In most cases the control panel in the vehicle where the odometer is says "No Bus"
The only way to fix this problem is to put a new computer in. DO NOT buy one from the dealership they are too pricey. Get on off of Ebay. For the extremely mechanical Savy you can do what I did in my durango. I carefully cut the tape away from the main harness then marked everything and cut the harness drilled a hole through my firewall (Just be careful where you drill) fed the harness through and reconnected my computer and mounted it under the dash so when it is extremely hot here in arizona the A/C Keeps the computer cool. With this method I have NEVER had this problem happen to me.
Just don't do this if vehicle is under warranty it will violate the ciditions of the warranty. Hope this helps. I have seen this problem posted to other sites and am just trying to let everyone know what it is and How to fix it.
Oct 05, 2008 | 1999 Dodge Durango
Computers & Internet Logo
116 people viewed this question
David Payne
David Payne
