Question about Hotpoint Aquarius WF000 Front Load Washer
Hotpoint WF250 - clothes largely dry and covered in powder
Hi
Our Hotpoint WF250 has been a problem recently.
Our clothers are harldy getting wet - they're coming out only partly wet and with washing powder and fabric conditioner on them.
Sometimes It makes a sound that reminds me of a siren
Does anyone know how to fix it?
Thanks
  • Anonymous Sep 26, 2008
    Exactly same problem.
    Removed all pieces from inlet to drum, cleaned thoroughly.
    Works wonders now !
    thanks guys !
    President:
  • 1,294 Answers
Plug off the wall. Close your inlet valves behind machine, disconnect inlet hoses & clean the small screens well, the screen on the machine too. Now check to see if the water is coming in a good flow from the faucet, without connecting the hoses; if flow is good reconnect hoses. Open behind, you will see a thin tube coming from the timer side to the bottom filter; disconnect from top and blow into it, air should flow, if not unblock and refit carefully from where you disconnected. Before pushing machine back to the wall, check to see if the exit hose is a correct height, that is about 3 feet from ground level before it goes into the wall standpipe.
Start your machine, try to peep into dispenser or put ear near to see if water is flowing into the dispenser. If you still have problems change your inlet valve, you can do it yourself, only see that the connections are correct..
Posted on Apr 13, 2008
    Genius:
  • 1,554 Answers
Check to make sure the water inlet filter is not clogged with debris.
turn off water and disconnect at washer , look in opening is filter screen clear, some are removable to clean others you have to brush etc....
there are two more places to check but they are inside the washer at the water control solenoid and the inlet , the water pressure sensor may have something to do with this issue.
best to open the top and listen and watch. (3 screws in rear top)
How to Make a Non Working Xbox Disk Work?
    1)Take disk out of Xbox
    2)Try turning off Xbox
    3)Choose one of the methods to try and fix disk Polishing disk
      -Use air first (blow across disk, or use a soft brush to remove any specks from disk before polishing)
      -Get a soft, lint-free polishing cloth (make it damp)
      -Use wet side of cloth to clean shiny side of disk
      -Dry whole disk (dry polishing cloth)
      -Put it in Xbox Using soap or water
        -Use soap or windex-slightly wet paper towel to wipe off disk from middle towards outside
        -Use furniture cleaner Using toothpaste
          -Rub toothpaste on disk, dampen a suitable soft cleaning cloth
          -Rub from centre-then move all the way around to edge
          -Wipe toothpaste off with a wet cloth-wipe any dampness with dry cloth
          -Put it in Xbox Using car polish
            -Get a dry cloth and add a small amount of polish to it
            -Rub in a circle motion, then wipe dry
            -Put it in Xbox Peanut butter
              -Put a dab of peanut butter on a lint-free cloth
              -Don't rub it in a circle motion
              -Put it in Xbox Using rubbing Alcohol
                -Pour out a small amount of rubbing alcohol onto a cotton bud
                -Rub from centre of disk, moving outward to edge
                -Wait for it to dry and try again Wax from candle
                  -Get some melted wax from a normal candle
                  -Gently pour wax on scratches-rub in with soft cloth
                  -Wipe off excess wax with a damp cloth
                  -Let disk dry for 5-10 mins and try again Vanish Oxipowder
                    -Cover entire shiny side of disk with powder
                    -Wait 5-10 mins
                    -Clean powder off completely with soft damp cloth
                    -Place disk in Xbox Other possible fixes
                      -Take disk to game/computer shop
                      -If any of your friends has game, borrow disk from them, install it to hard drive, and hope Xbox recognises it
Oct 20, 2016 | Video Game Consoles & Games
Tip
Allways clean your filter on your washer
by cleaning your pump filter at leased once a month will make your washer perform better and last longer. it will stop problems accuring such as (door will not open ) (the machine will not spin on final spin ) (wet cloths) (un even loads) (dirty cloths) (smell & mould ) another good tip is dry off the rubber door seal after use and sprinkle a little talk powder on it this will stop it staining with mould.
on Nov 06, 2011 | Hotpoint Washing Machines
Hotpoint WF250 clothes coming out soaking wet after spin?
The fast wash cycle is for a reduced capacity load of approximately 3kg , it does not pump or spin long enough for a full capacity load
Jun 15, 2016 | Hotpoint Washing Machines
Hot Point dryer DLB 1550 BALWH not drying clothes
There are several reasons for dryer not drying clothers.
It might help to go through the guide on this website. Hotpoin Dryers are rebadged GE appliance. So should be same.
IF you find a particular area or part that might need replacement then go to this page for parts availabiity
http://www.appliancepartspros.com/parts-for-ge-dlb1550bal.html
http://www.appliancerepair.net/clothes-dryer-repair.html
Apr 17, 2014 | Hotpoint Dryers
No heat
Hotpoint WD63 not spinning correctly
Two things to check.
Remove rear cover.
Remove large black hose onto drum
Remove and clean filter inside hose.
Next--remove top cover and check the brushes in the motor, if they are less than 3 or 4 mm long, then replace them.
Please rate my solution.
Thanks.
Nov 24, 2009 | Hotpoint Aquarius WD63 Front Load...
CLOTHES NOT SPINNING DRY
you have something stuck in the pump..a sock maybe or some other small article of clothing
Jan 11, 2009 | Hotpoint -Ariston VVSR1030HWO Top Load...
Dryer not drying
be sure vent to outside is not blocked or hose behind dryer flattened..quick ck is to dry a load with rear hose disconnected..if problem still there suspect heating element ..ge/hotpoint elements are double strung if 1 coil is open (burnt into) dryer will not get hot eneough
May 19, 2008 | Hotpoint NBXR463EBWW Electric Dryer
Hotpoint Aquarius WF000 Front Load Washer Logo
108 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
